Mxsmanic wrote in
: Capt.Doug writes: Typically alternate pucks in the calipers will be powered by different hydraulic systems. The parking brake will use one set of pucks. So setting the parking brake in a large aircraft has some of the same disadvantages as in a small aircraft, if hydraulic pressure is being maintained. Did you retrack the gear into the wheel-wells with elevated temperatures? That could be a major fire hazard. Unfortunately, yes. I only found out that the brakes were very hot by accident, and I was well into my departure by then. into your departure? Bwawhahhwhahwhahwhahwhhahwhahwhahhwhahwhahwhahhwha hwhahhwhahwhahwhahhwha hwhahwhhahwhahwhahwhhahwhahwhahwhhahwhahwhahwhhahw hahwhhahwhahwhahhwhahw hhahwhahwhhawhhahwhahwh! bertie |
Medical running out? | [email protected] | Piloting | 6 | May 28th 06 02:19 PM |
Running dry? | Greg Copeland | Piloting | 257 | August 26th 05 03:47 PM |
Running runup? | G. Burkhart | Piloting | 39 | July 7th 04 11:25 AM |
Running an 0-235 well beyond TBO | Paul Folbrecht | Owning | 8 | March 14th 04 12:30 AM |
Leaving all engines running at the gate | John | Piloting | 12 | February 5th 04 03:46 AM |
