On 3/21/2007 3:55:17 PM, "Jim Burns" wrote:
What's that? Oh it DIDN'T leak! Good for you! You showed those bloody engineers! Ha! Take that! Man, that is painful to read. -- Peter |
Yep... no doubt literally. I just finished helping an A&P install a new set
of seat rails in a C182. My wife said my hands looked liked I'd been petting a porcupine. The edges of the lightening holes are wonderful exfoliating devices, I can't imagine what they can do to you when you're armpit deep into one. Jim "Peter R." wrote in message ... On 3/21/2007 3:55:17 PM, "Jim Burns" wrote: What's that? Oh it DIDN'T leak! Good for you! You showed those bloody engineers! Ha! Take that! Man, that is painful to read. -- Peter |
![]() Peter R. wrote: On 3/21/2007 3:55:17 PM, "Jim Burns" wrote: What's that? Oh it DIDN'T leak! Good for you! You showed those bloody engineers! Ha! Take that! Man, that is painful to read. The new tanks now a days are very flexible. They won't stand up by themselves whereas the old one do, they were very stiff. It is not necessary to make sure the new tanks are warm before rolling them up. There are no sharp edges to worry about, at least in the Bonanza and I don't recall any in the 182. It took about 5 minutes to attach the snaps. All wiring and fuel transmitter is accessed thru the top of the wing. The Cessna is a bad deal in this respect. The key is to replace the fuel transmitter screws with bolt head screws. |
On 3/21/2007 11:10:10 PM, Newps wrote:
The new tanks now a days are very flexible. Just for my future reference, what are the signs that a bladder needs replacing? Rubber chunks in the fuel sampler cup? Fuel stains or an obvious leak under the wing? Something else? -- Peter |
We've got a 50 hour recurring AD on the Aztec to look for fuel stains under
the trailing edges of our wings. Keep your bladders full, I understand the most common failure is around the fill tube where they can dry out prematurely if not full of fuel. Jim |
Blue stains under the wings and debris in the fuel sample is what I've
been advised to keep an eye out for. There's a really nice 182 at my field that was just painted and had a new leather interior installed shortly before one of the tanks started leaking. Some fuel even got into the interior. I hope it didn't leave any permanent stains. What a pity it didn't happen before all the new work was done. Dave M35 Peter R. wrote: On 3/21/2007 11:10:10 PM, Newps wrote: The new tanks now a days are very flexible. Just for my future reference, what are the signs that a bladder needs replacing? Rubber chunks in the fuel sampler cup? Fuel stains or an obvious leak under the wing? Something else? |
On 3/22/2007 9:32:41 AM, dave wrote:
Blue stains under the wings and debris in the fuel sample is what I've been advised to keep an eye out for. Thanks, Jim and Dave. -- Peter |
![]() Peter R. wrote: On 3/21/2007 11:10:10 PM, Newps wrote: The new tanks now a days are very flexible. Just for my future reference, what are the signs that a bladder needs replacing? Rubber chunks in the fuel sampler cup? Fuel stains or an obvious leak under the wing? Something else? I rarely sump my tanks, pretty much only after parking outside overnight. Look for the blue stain on the underside of the wing along the wing spar line. Check the fuel vent line thru the inspection hole, the nipple for the vent line is what broke on my tank causing gas to leak out every time the bladder was filled. I put up with that for about 6 months before replacing the tank. Also check the gaskets for the fuel filler and fuel senders. They can get loose and leak. |
Why don't you sump your tanks? It's not just water you should be
concerned about. How do you know you're buying clean fuel? I doubt your FBO would vouch for the cleanliness of the fuel they're selling. Dave M35 Newps wrote: Peter R. wrote: On 3/21/2007 11:10:10 PM, Newps wrote: The new tanks now a days are very flexible. Just for my future reference, what are the signs that a bladder needs replacing? Rubber chunks in the fuel sampler cup? Fuel stains or an obvious leak under the wing? Something else? I rarely sump my tanks, pretty much only after parking outside overnight. Look for the blue stain on the underside of the wing along the wing spar line. Check the fuel vent line thru the inspection hole, the nipple for the vent line is what broke on my tank causing gas to leak out every time the bladder was filled. I put up with that for about 6 months before replacing the tank. Also check the gaskets for the fuel filler and fuel senders. They can get loose and leak. |
chicago area residential airpark and maintenance facility good deals on annual inspections | [email protected] | Owning | 7 | September 15th 05 02:55 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Is a 152 a good start? | AliR | Piloting | 17 | April 20th 05 05:52 PM |
[US: PA/NY/NJ] Governor's Cup off to a good start | Papa3 | Soaring | 0 | April 13th 05 10:36 PM |
'Good' Annual This Year | Ben Smith | Owning | 38 | July 26th 03 05:44 AM |
