the Legend of LAX wrote: They did some flight checks on the new ILS last night. It's getting the new fangled end-fire glideslope. Does that mean it directly projects the gs instead of reflecting it from 1000 feet down the runway? |
john smith wrote:
In article , the Legend of LAX wrote: They did some flight checks on the new ILS last night. It's getting the new fangled end-fire glideslope. Does that mean it directly projects the gs instead of reflecting it from 1000 feet down the runway? For a little background explanation for those who don't know how it works: The antenna sits at the touchdown point (the point where the glide path actually touches the r/w), 750-1250 feet down the runway & offset 250-650 feet from centerline. It projects a beam toward the the landing path at an angle of 1.4 (usually) degrees. We use capture effect now, which is based on the principle that a receiver will lock on to the stronger of two signals & reject the weaker. I have not been to school for the end-fire so I don't know its theory yet, but it does basically the same thing, just using a different method. The antenna sits at about the same point. Instead of being on a tall mast, it sits almost flat on the ground, similar to a localizer antenna. It is used where terrain is not smooth (since the CEGS uses an image antenna as part of its operation & requires smooth ground plane around it to reflect the image). I will try to get some pictures & post them showing the different antennas. -- Dale G Elhardt Cypress Ca "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." http://home.comcast.net/~laxet/ http://www.jetphotos.net/showphotos.php?userid=7702 |
A380 32.jpg (1/1) | Jim Long | Aviation Photos | 4 | February 8th 07 11:57 PM |
A380 16.jpg (1/1) | Jim Long | Aviation Photos | 0 | February 8th 07 06:04 PM |
A380 15.jpg (1/1) | Jim Long | Aviation Photos | 0 | February 8th 07 06:04 PM |
A380 14.jpg (1/1) | Jim Long | Aviation Photos | 0 | February 8th 07 06:04 PM |
A380 13.jpg (1/1) | Jim Long | Aviation Photos | 0 | February 8th 07 06:04 PM |
