Rolling a Non Aerobat 150
Old March 23rd 07, 01:36 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Cox
Default Rolling a Non Aerobat 150
If you do manage to get out of a spinning aircraft, I wouls estimate close
to a 100% better chance of survival if you have a chute on. I sure would
hate to be the person who was able to get out of the so called "impossible
aircraft to get out of" only to find they didn't have a chute on.
Wear a chute, what can it hurt?
Adam
Adam Cope
www.dcaerobatics.com
703-623-9445
Old March 23rd 07, 01:57 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Don Tuite
Adam
Then there's this:
http://www.aero-news.net/index.cfm?C...-7233c1bb43f8&
(Hope it's not a repost. It's about the 150 rudder bumpers jamming.)
Don
Old March 23rd 07, 02:34 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
Adam
Adam Cope
703-623-9445
I totally agree with this. The " you'll never get out of this airplane
because of the door" routine is something I've heard repeated many times
through my career teaching aerobatics. My standard answer and "lecture"
on this issue is as follows;
For spins, even if the regulations don't call for chutes, I always
recommend wearing them. I always had chutes available for whatever
aircraft we were using for spin training.
A lot has been written and said about the difficulties involved in
getting out of Aerobats, Citabrias, and Decathlons.
There is no doubt that especially with a structural failure, exiting one
of these aircraft could be iffy. That's why any good instructor not only
supplies chutes for spin training, but as well performs a complete
egress brief specific to aircraft type to the point where once the bail
out call has been made, each occupant knows what the exit procedure will
be. This is especially critical in tandem aircraft.
I should mention that even with the most complete egress briefing, there
is STILL an element of doubt that a successful exit from these airplanes
can be executed in the time available under extreme g in a post
structural failure.
The factors involving a successful bail out are so diverse that there
are just no guarantees.
In the Pitts S2 for example, if the upper wing fails, the flying wires
will most likely remain attached and the upper wing will beat the
occupants to death before a bail out can be achieved.
All this being considered, the use of chutes is not only recommended,
but in my opinion a necessary part of every non- standard flight whether
it be aerobatics or spin training.
The bottom line is that wearing a chute gives you a fighting chance for
survival. Not wearing a chute gives you no chance at all.
Its a smart pilot who takes advantage of all available options!
Dudley Henriques
Old March 23rd 07, 03:22 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
john hawkins
close to a 100% better chance of survival if you have a chute on. I sure
would hate to be the person who was able to get out of the so called
"impossible aircraft to get out of" only to find they didn't have a
chute on.
Adam
Adam Cope
703-623-9445
through my career teaching aerobatics. My standard answer and "lecture" on
A lot has been written and said about the difficulties involved in getting
supplies chutes for spin training, but as well performs a complete egress
brief specific to aircraft type to the point where once the bail out call
has been made, each occupant knows what the exit procedure will be. This
can be executed in the time available under extreme g in a post structural
failure.
The factors involving a successful bail out are so diverse that there are
just no guarantees.
All this being considered, the use of chutes is not only recommended, but
in my opinion a necessary part of every non- standard flight whether it be
Dudley Henriques
Dudley,
Could you give some specifics about exiting a citabria?
I used to do aerobatics in one and always wore a chute. I never suspected
that I would have trouble exiting if I pulled the door hinge pins, I thought
the door would vanish and leave me a big hole to climb out.
The only serious instructor I had was in a Stearman and he never discussed
exiting in case of trouble.
Obviously I was completely ignorant. Better to learn late than never.
Old March 23rd 07, 04:14 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Our procedure was to yank the QR pins and turn the handle;
Champion may well have improved the quick release doors by now. Its been
a long time ago for me in the Citabria :-)
I would suggest a good look through the POH and a brief from the
airplane operator for the current scoop on this.
DH
chute on.
Adam
Adam Cope
703-623-9445
failure.
just no guarantees.
Dudley Henriques
Dudley,
Old March 23rd 07, 03:33 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
karl gruber[_1_]
I have an acquaintance that kicked his way out the windshield of a Citabria,
after the wings folded up against the fuselage.
Karl
"Curator" N185KG
"john hawkins" wrote in message
et...
sure would hate to be the person who was able to get out of the so
called "impossible aircraft to get out of" only to find they didn't
have a chute on.
Adam
Adam Cope
703-623-9445
structural failure.
just no guarantees.
Dudley Henriques
Dudley,
thought the door would vanish and leave me a big hole to climb out.
Old March 24th 07, 02:42 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
C J Campbell[_1_]
Karl
"Curator" N185KG
Amazing what you can do with the proper motivation.
Waddling Eagle
World Famous Flight Instructor
Old March 24th 07, 05:22 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Roger[_4_]
On Fri, 23 Mar 2007 19:42:32 -0700, C J Campbell
Karl
"Curator" N185KG
With some forms of motivation being far more effective than others.
Strange the thoughts you can have.
The last conscious thoughts I had as I watched the top of the SUV
disappear out of sight above the top of windsheild in the Trans Am
were, "Boy, I'll bet this is gonna hurt". (this was happening at 50
MPH Plus). Then I was thinking, I can't see a thing with all this dust
from the air bags, followed by "I think I'm spinning through two solid
lanes full of traffic. Maybe it's better I can't see out".
www.rogerhalstead.com
Old March 26th 07, 07:03 PM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
pittss1c
Citabria,
Karl
"Curator" N185KG
I think the important statistic would be to look at the fatal accidents
where the pilot was wearing a parachute, and see how many are unstrapped
and trying to get out when they hit the ground.
In the searches I have done, I don't remember ever seeing this (although
I was focusing on Pitts accidents.
Mike
Old March 27th 07, 02:52 AM posted to rec.aviation.aerobatics,rec.aviation.piloting,rec.aviation.student
Capt. Geoffrey Thorpe
"pittss1c" wrote in message
In the searches I have done, I don't remember ever seeing this (although I
Mike
I didn't find any of those.
And, I was wrong. It _is_ possible to get out of a Cessna 150/172 - even a
Piper PA-28 without a quick release door. (see below)
Notes - most accidents involving Cessna's and parachutes are from jump
operations - you end up plowing though a lot of reports where the word
"parachute" appears but has nothing to do with the cause / outcome.
I ran into several fatal accidents where the occupants of Citabria's were
not wearing 'chutes while doing aerobatics.
Several fatal accidents with and without parachutes happened from aerobatics
at low altitudes.
Some where the occupants got out but not in time - there was no indicaton if
they took too long to start to get out or had too much trouble getting out
(These were Pitts in spins iirc) . In one, the student made it out, but the
instructor was still belted in (Citabria)
Then there was the guy who bailed out of a 150 when he ran out of gas on
final...
Excerpts from accident reports:
Cessna 172: "The pilot, Hodelin F. Rene, stated he arrived at Flowers Air
Charter, on December 3, 1994, at about 1000, and was introduced to his
passenger by Mr. Flowers. Miss Pascale stated she wanted to take several
pictures of a couple of houses in the Cutler Ridge area, and drew a circle
around the area on an aeronautical chart. He went to Terminal One, taxied
his airplane to Flowers Air Charter, and did a preflight inspection. The
passenger did her own preflight inspection, and asked several questions
about the operations of the right passenger door. They departed Opa Locka
Airport and flew to the area previously marked on the map. He leveled off at
5,000 feet agl, slowed the airplane to 70 mph, and asked her where she
wanted to go. She stated she would look outside to make sure. A short time
later, she stated she was going to take off the headset and move the seat
back so she could get a good shot. He then heard what sounded like a yell,
felt wind and noise simultaneously in the cabin area. He looked towards the
sound, she was already partly out of the airplane, and when their eyes met,
she jumped out. "I was in total amazement, shock and just froze for a
moment, not knowing what to do. I could not believe what had happened. After
about ten seconds, I called ATC and requested a descent as I struggled to
close the door." He then informed ATC that he would like to declare an
emergency, that his passenger had jumped out of the airplane."
PIPER PA-28-180: "THE PILOT HAD TRANSMITTED A DISTRESS CALL THAT THE
AIRPLANE WAS HAVING FUEL PRESSURE PROBLEMS. THE AIRPLANE WAS SQUAWKING
TRANSPONDER CODE 7700. IT THEN DISAPPEARED FROM RADAR. THE PILOT HAD EARLIER
LEFT A MESSAGE TO HIS WIFE ON A TELEPHONE ANSWERING MACHINE THAT 'I DON'T
WANT TO LIVE ANY MORE...' GROUND WITNESSES OBSERVED A MAN PARACHUTE FROM AN
AIRPLANE IN THE AREA AT THE TIME OF THE ACCIDENT. THE PILOT'S BODY WAS FOUND
ON DECEMBER 21, 1994.
The National Transportation Safety Board determines the probable cause(s) of
this accident as follows:
THE PILOT'S INTENTIONAL DECISION TO ABANDON THE AIRPLANE AND ALLOW IT TO FLY
UNATTENDED."
Cessna 150E: "THE PILOT WAS COMPLETING A CROSS-COUNTRY TRIP WHEN HE LOST
ENGINE POWER ON FINAL APPROACH. ACCORDING TO THE FAA, HE TURNED THE AIRPLANE
AWAY FROM THE AIRPORT AND PARACHUTED FROM THE AIRCRAFT AT 'APPROXIMATELY 560
FEET AGL. THE PARACHUTE OPENED JUST PRIOR TO GROUND CONTACT, AND THE
AIRPLANE CRASHED IN THE BACKYARD OF A RESIDENCE.' THE PILOT STATED TO THE
FAA THAT HE THOUGHT HE HAD RUN OUT OF FUEL. THE FAA ALSO FOUND THAT, 'THE
AIRPLANE HAD RECEIVED DAMAGE TO ITS WINGS WHILE TAXIING ONE DAY PRIOR TO THE
ACCIDENT.' THE PILOT 'HAD APPARENTLY CONDUCTED HIS OWN REPAIRS TO THE RIGHT
WING' THAT WAS DAMAGED.
AN INFLIGHT COLLISION WITH TERRAIN DURING AN UNCONTROLLED DESCENT AFTER THE
PILOT PARACHUTED FROM THE AIRPLANE. CONTRIBUTING TO THE ACCIDENT WERE FUEL
EXHAUSTION AND THE PILOT'S DISREGARD FOR EMERGENCY PROCEDURES. "
Geoff
Rolling a Non Aerobat 150 Larry Dighera Piloting 98 June 18th 05 12:28 AM
Rolling a Non Aerobat 150 Jose Instrument Flight Rules 1 May 2nd 05 03:59 PM
Rolling a Non Aerobat 150 Jose Piloting 1 May 2nd 05 03:59 PM
Rolling a Non Aerobat 150 Larry Dighera Piloting 1 April 29th 05 07:31 PM
Rolling a Non Aerobat 150 kage Owning 0 April 29th 05 04:26 AM
