Why don't you sump your tanks? It's not just water you should be
concerned about. How do you know you're buying clean fuel? I doubt your FBO would vouch for the cleanliness of the fuel they're selling. Dave M35 Newps wrote: Peter R. wrote: On 3/21/2007 11:10:10 PM, Newps wrote: The new tanks now a days are very flexible. Just for my future reference, what are the signs that a bladder needs replacing? Rubber chunks in the fuel sampler cup? Fuel stains or an obvious leak under the wing? Something else? I rarely sump my tanks, pretty much only after parking outside overnight. Look for the blue stain on the underside of the wing along the wing spar line. Check the fuel vent line thru the inspection hole, the nipple for the vent line is what broke on my tank causing gas to leak out every time the bladder was filled. I put up with that for about 6 months before replacing the tank. Also check the gaskets for the fuel filler and fuel senders. They can get loose and leak. |
chicago area residential airpark and maintenance facility good deals on annual inspections | [email protected] | Owning | 7 | September 15th 05 02:55 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Is a 152 a good start? | AliR | Piloting | 17 | April 20th 05 05:52 PM |
[US: PA/NY/NJ] Governor's Cup off to a good start | Papa3 | Soaring | 0 | April 13th 05 10:36 PM |
'Good' Annual This Year | Ben Smith | Owning | 38 | July 26th 03 05:44 AM |
