On Mar 23, 7:14 am, ZL wrote:
wrote: I tried to make my first OLC claim on Sunday and Monday for my 3/17/07 flight and I must say it's been a hassle. My claim was declared "validation not successful". I used a GPS-NAV 20. On Sunday, I converted the .cai file to .igc using AeroExplorer. I then prepared the claim in SeeYou. I went to the OLC site and tried to upload by "Prepared Claim". File was not uploaded. I then tried to upload the claim through SeeYou. No upload. On Monday, I tried the OLC site "Direct Claim" method and the .igc file uploaded ok but it was invalid. I then converted the .cai file to .igc using the Cambridge DOS program. Deleted the previously uploaded file and uploaded the new .igc file again using "Direct Claim". Still invalid. The .cai file passed vali-cam.exe with no problem. I emailed support by replying to the email I received from the OLC Result Notifier but have not yet heard anything. Steve The OLC requires some special handling for logs from legacy Cambridge flight recorders (Model 10, 20, and 25). SeeYou (v3.6 or higher) does that quite easily if you open the *.cai file directly. It will generate the *.igc file with the *.cai file encoded and appended onto the end. The prepared claim should definitely work, not sure if the bugs are out of the direct claim from SeeYou method yet. But you must open the *.cai file with SeeYou, not an *.igc file generated by AeroExplorer or the Cambridge DOS program. The details for doing this manually without SeeYou are found in item 10 on the Help page (Help button is at bottom right of OLC page). This is the same process for OLC 2.0 as last year. Thanks for the info ZL. I didn't try opening the .cai file with SeeYou but I did try the "prepared claim" on the OLC page with a file prepared by SeeYou and the file didn't even start to upload. I also noticed that there is a bit of a contradiction on the OLC page. If you click on Claim Flight, it states under Direct Claim that this is the most simple and safest way of flight claiming. If you click on Information, it states that Method 2 the prepared claim is the safest method. I'll try what you suggested with SeeYou on my next flight. Steve |
Broken P lead? | Jim Burns | Piloting | 16 | October 27th 06 08:06 PM |
surviving a broken wing | Kyler Laird | General Aviation | 0 | August 3rd 06 04:31 PM |
Broken window in jet plane | Eduardo K. | Piloting | 17 | April 13th 06 10:19 PM |
Broken wing | Stubby | Piloting | 27 | January 1st 06 03:04 AM |
Looking for broken Garmin | Larry Goddard | Soaring | 3 | July 5th 04 12:46 PM |
