A tower-induced go-round
Old March 24th 07, 02:21 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default A tower-induced go-round
Lots of places have specific "standard" arrivals and departures for
noise abatement.
Unfortunately, the AFD rarely lists these, AirNav is spotty, but Flight
Guide is pretty good.
An example is KCCB.
To depart 24 to the south, turn south crosswind and follow the flood
control channel.
To depart 24 to the north, left downwind and turn north over the 24.
There are no downwind, straight-out or right departures.
And there is a big sign at the runup area telling you this.
Title 49 US Code, Subtitle VII, Part A, Subpart i, Chapter 401, section
401.3 states:
(a) Sovereignty and Public Right of Transit.-
(1) The United States Government has exclusive sovereignty of
airspace of the United States.
(2) A citizen of the United States has a public right of transit
through the navigable airspace. To further that right, the Secretary of
Transportation shall consult with the Architectural and Transportation
Barriers Compliance Board established under section 502 of the
Rehabilitation Act of 1973 (29 U.S.C. 792) before prescribing a regulation
or issuing an order or procedure that will have a significant impact on the
accessibility of commercial airports or commercial air transportation for
handicapped individuals.
(b) Use of Airspace.-
(1) The Administrator of the Federal Aviation Administration shall
develop plans and policy for the use of the navigable airspace and assign by
regulation or order the use of the airspace necessary to ensure the safety
of aircraft and the efficient use of airspace. The Administrator may modify
or revoke an assignment when required in the public interest.
(2) The Administrator shall prescribe air traffic regulations on the
flight of aircraft (including regulations on safe altitudes) for-
(A) navigating, protecting, and identifying aircraft;
(B) protecting individuals and property on the ground;
(C) using the navigable airspace efficiently; and
(D) preventing collision between aircraft, between aircraft and
land or water vehicles, and between aircraft and airborne objects.
Local actions cannot regulate such things as maximum noise levels of
aircraft in flight, routes, altitudes, or any other flight procedures.
Airport operators do have responsibility for initiating local aviation noise
control procedures. They may propose specific noise abatement plans to the
FAA, and if approved, those plans will be applied in the form of informal or
formal runway use programs, or departure and arrival procedures. These
procedures are published in the A/FD and/or TPP.
An airport operator can post a big sign in a runup area regarding how he'd
like pilots to operate their aircraft, but that alone does not a make it a
"standard" procedure. It is just a request and pilots are free to decline.
Old March 24th 07, 04:05 PM posted to rec.aviation.piloting
noise abatement.
An example is KCCB.
control channel.
401.3 states:
Lots of airports have perfectly reasonable noise abatement procedures that
don't appear in the A/FD. KCCB specifically is a case in point.
It appears the system is broken.
And if they do, the noise complaints, lawsuits and pressure on local
authority mounts to turn that noisy, worthless airport into a WalMart
and stand a good chance of being in conflict with the existing traffic.
So, what you are saying is, if the procedure isn't in the A/FD for
whatever reason, just ignore it, no matter the consequences to the
airport and despite the fact that the rest of the traffic is following
those procedures and doing so invites a conflict because the law is
on your side?
Yep, sure sounds like the way to go to me.
Jim Pennino
Remove .spam.sux to reply.
Old March 27th 07, 11:08 AM posted to rec.aviation.piloting
Steven P. McNicoll
What "system" would that be?
Locally created noise abatement procedures are fine when they simply
identify noise sensitive areas and ask pilots to avoid them. They can be
dangerous when they tell pilots where to fly in a way that appears
mandatory.
on your side?
No, what I'm saying is local actions cannot regulate routes, altitudes, or
any other flight procedures. Do you really think the CCB "noise abatement"
procedure limits exposure to lawsuits? It conflicts with the ODP. What if
a departing aircraft comes to grief while following the noise abatement
procedure?
Old March 27th 07, 03:15 PM posted to rec.aviation.piloting
mandatory.
Not if everyone is following them, which is the whole point.
The system is broken because a perfectly reasonable procedure is not
"official" to the lawyer types like you, who would then ignore it
because they are within their legal rights to do so and cause a
conflict.
There is no difference in practice between a local noise abatement
procedure and an established ATC procedure. The only difference is
in the legal fine print.
on your side?
procedure?
Of course it limits lawsuits; it limits noise lawsuits.
If a departing (or arriving, CCB has procedures for both) aircraft comes
to grief following the noise abatement procedures, it will only be because
some anal legal eagle such as yourself chose to ignore them and caused
havoc in an otherwise peaceful pattern full of students expecting the
rest of the traffic to be following the same procedures.
As much as I hate to say it, I think a rule is needed along the lines
of "unless deviation is required for safety, all local noise abatement
procedures at non-towered airports shall be followed" and that they
all get published in the A/FD just to take care of people like you
who would rather be right than safe.
Jim Pennino
Old March 27th 07, 03:49 PM posted to rec.aviation.piloting
Jose
mandatory.
Having "everyone" is following local noise abatement procedures does not
make them safe.
"official"
It's not always a perfectly reasonable procedure. Sometimes it's
downright dangerous.
Jose
Get high on gasoline: fly an airplane.
Old March 27th 07, 05:15 PM posted to rec.aviation.piloting
mandatory.
make them safe.
Non sequitur.
Having one yahoo not following the same procedure as everyone else
no matter where the procedure comes from is not safe.
If the procedure itself is not safe, it needs to be changed.
This isn't rocket science.
"official"
Yeah, so what?
That just means that a specific procedure needs to be modified and
says absolutely nothing about the desirablity of following noise
abatement procedures in general.
There have been established ATC procedures that were changed because
they were deemed to be dangerous.
How would this be any different?
Look at the procedures for CCB:
http://www.cableairport.com/images/vfr24.gif
http://www.cableairport.com/images/vfr6.gif
See anything unsafe there?
Oh, I'm sure there are some idiotic and unsafe procedures out there
that need to be changed, but that is a totally different issue.
Jim Pennino
Old March 27th 07, 08:33 PM posted to rec.aviation.piloting
Jose
mandatory.
make them safe.
Non sequitur.
Sequitur.
That's not only not true, it is laughable. Not everyone has to depart
right downwind, and having somebody depart straight out or left
crosswind is not unsafe =just= because everyone else is going out right
downwind.
It could be unsafe because there is a mountain in the way. It could be
unsafe because it crosses another arrival path. But if everyone is
excercising normal vigilance, there is nothing intrinsically unsafe
about departing in a direction different from other departures.
That is true. But if two different procedures are safe, the pilot gets
to choose which to execute. And if one procedure (say, the noise
abatement one) is not safe under some circumstances, the pilot gets to
use a different procedure. That's what "pilot in command" means.
And as to the alleged safety of a noise abatement procedure, I won't
trust the yahoos who live under a flight path and don't like airplane
noise to decide for me what is safe and what is not. They may well come
up with a safe procedure. They might not. I don't assume it's safe
just because "somebody" came up with it.
Jose
Old March 29th 07, 01:04 AM posted to rec.aviation.piloting
Steven P. McNicoll
Having some local yahoo publish a "mandatory" noise abatement procedure is
not safe.
Agreed. As the procedure conflicts with the ODP it is clearly unsafe and
Yeah, so what?
Yes.
Old March 29th 07, 12:31 AM posted to rec.aviation.piloting
Steven P. McNicoll
news
A dangerous procedure is rendered safe if everyone follows it?
conflict.
A perfectly reasonable procedure does not conflict with an ODP.
Established ATC procedures do not conflict with ODPs. That seems like a
rather significant difference.
I can think of other reasons, you're short on imagination.
A departing aircraft attempts to follow the flood control channel in poor
visibility and crashes, the pilot's estate sues the airport citing the noise
abatement procedure as the cause.
Since I prefer to be right and safe I would not comply with the CCB noise
abatement procedure.
Old March 29th 07, 04:15 AM posted to rec.aviation.piloting
news
An idiotic comment.
conflict.
Where's the conflict?
Ledalistic backpeddling.
Babbling nonsense.
The procedures are for VFR operations.
How can following a VFR landmark cause a crash?
The terrain to the South is downhill BTW.
Egotisical barracks lawyer crap.
The procedures at CCB have been proven to be safe by decades of use.
Jim Pennino
Round Engines john smith Piloting 20 February 15th 07 03:31 AM
induced airflow buttman Piloting 3 February 19th 06 04:36 AM
Round Engines Voxpopuli Naval Aviation 16 May 31st 05 06:48 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
Predicting ground effects on induced power Marc Shorten Soaring 0 October 28th 03 11:18 AM
