Annual Off to a Good Start
Old March 25th 07, 01:14 PM posted to rec.aviation.owning
Mike Spera
Default Annual Off to a Good Start
Probably because no "airplane parts store" (including the highly respected
discounter o'them all, Chief) carries anything but Phillips.
.stuff snipped
I'm gonna replace stainless with stainless. They are a BIT harder and don't
rust up quite as bad. Stainless to speednut has never been a problem
insofar as I know.
.other stuff snipped
Now that we have broached the subject, where do you find stainless
threaded speed nuts. There are a pile of them used on Cherokees to hold
on the wing/stabilator tips (8-32 I believe). I have never been able to
get a source.
Anyone?
Thanks,
Mike
Old March 25th 07, 09:03 PM posted to rec.aviation.owning
Steve C
My airplane (Diamond DA 40) uses stainless hex head cap screws for all
of the access plates and external fasteners. The only issue is that
they are metric, but Diamond was nice enough to include a set of
extras with the airplane. They are real easy to R&R, just had to get a
3mm hex bit for my electric screwdriver.
Old March 26th 07, 02:42 PM posted to rec.aviation.owning
Gig 601XL Builder
respected discounter o'them all, Chief) carries anything but
Phillips. .stuff snipped
and don't rust up quite as bad. Stainless to speednut has never
been a problem insofar as I know.
hold on the wing/stabilator tips (8-32 I believe). I have never been
able to get a source.
Anyone?
Thanks,
Mike
If one of these places don't have them they probably don't exsist.
http://www.gen-aircraft-hardware.com/
http://www.mcmaster.com/ (Not Aircraft but great none the less)
chicago area residential airpark and maintenance facility good deals on annual inspections [email protected] Owning 7 September 15th 05 02:55 AM
Is a 152 a good start? AliR Piloting 17 April 20th 05 05:52 PM
[US: PA/NY/NJ] Governor's Cup off to a good start Papa3 Soaring 0 April 13th 05 10:36 PM
'Good' Annual This Year Ben Smith Owning 38 July 26th 03 05:44 AM
