Lowrance 2000C ???
Old March 25th 07, 02:38 PM posted to rec.aviation.owning,rec.aviation.piloting
Dave[_5_]
Default Lowrance 2000C ???
I have a couple of questions regarding the 2000C:
1. What are the mounting options? I have never liked yoke mounts.
2. Will it work with a non-Lowrance amplified external antenna (I have
a permanent
unit on top of the fuselage that has worked flawlessly with my
Garmin).
Thanks in advance for any advice.
David Johnson
  #32
Old March 25th 07, 06:46 PM posted to rec.aviation.owning,rec.aviation.piloting
WestCDA
On the mount, they come with a yoke mount and a suction cup mount. It uses
standard RAM ball components, so if you want something else you can use
anything in the extensive RAM catalog of pieces to mount it pretty well any
way you like.
On the antenna, I suggest you contact Lowrance and give them your antenna
specifics. The antenna the 2000c comes with is an amplified unit.
"Dave" wrote in message
a permanent
Garmin).
David Johnson
  #33
Old April 1st 07, 01:50 AM posted to rec.aviation.owning,rec.aviation.piloting
Dave[_5_]
I did some checking and found that the answer is apparently no. The
Lowrance external antenna runs on 3 - 3.3V and has a gain of 8 - 10
dB, whereas the antenna
I use with my Garmin can run on 4 - 24V and has a gain of 26 - 31 dB.
My Garmin puts out 5.8V on the antenna connector center pin with no
load. The Lowrance uses a type MCX connector, whereas the Garmin uses
a BNC. There are some non-Lowrance external antennas available that
will work with the 2000C, but those that I have found are "mouse"
style intended for use on the glareshield (vs mounted on the exterior
of the aircraft).
David Johnson
  #34
Old April 1st 07, 01:22 PM posted to rec.aviation.owning,rec.aviation.piloting
Blueskies
"Dave" wrote in message oups.com...
: On the antenna, I suggest you contact Lowrance and give them your antenna
: specifics. The antenna the 2000c comes with is an amplified unit.
: I did some checking and found that the answer is apparently no. The
: Lowrance external antenna runs on 3 - 3.3V and has a gain of 8 - 10
: dB, whereas the antenna
: I use with my Garmin can run on 4 - 24V and has a gain of 26 - 31 dB.
: My Garmin puts out 5.8V on the antenna connector center pin with no
: load. The Lowrance uses a type MCX connector, whereas the Garmin uses
: a BNC. There are some non-Lowrance external antennas available that
: will work with the 2000C, but those that I have found are "mouse"
: style intended for use on the glareshield (vs mounted on the exterior
: of the aircraft).
: David Johnson
FYI, many folks only use the built in antenna with the 2000C mounted on their yoke, and have no problems with lost
signals. I have mine hooked up with the Lowrance external antenna and have the wires tucked in along the edge of the
windshield. The 'mouse' is tucked in along the edge also, not obtrusive in the least and it causes no problems with my
compass...
  #35
Old April 1st 07, 05:27 PM posted to rec.aviation.owning,rec.aviation.piloting
Walt
a permanent
Garmin).
David Johnson
FWIW (probably not much) I have a Lowrance 1000 and use the yoke
mount. I've never had to use the external antenna as reception is
great, both in a Piper Archer and a Cessna 172.
Since the Lowrance's mount is a RAM mount you should be able to find
the kind of mount you'd like, if you don't want it on the yoke. I've
used the suction cup mount that comes with the unit in my car and it
works very well; stayed on the windshield during a ten-hour road trip
from Bozeman to Denver, although it was pretty useless; kind of hard
to get lost when all you need to do is stay on I-25. But, it was
something to look at going through Wyoming besides treeless hills and
antelope. :)
At any rate the RAM accessories should be varied enough so you can
find the kind of mount you like.
--Walt
Bozeman
  #36
Old April 2nd 07, 12:07 AM posted to rec.aviation.owning,rec.aviation.piloting
Dave[_3_]
Same...
We have never used (or needed ) the ext antenna on ours..
Only time we lost sig was on a looooong x-wind taxi with the yoke
turned hard right....
Welll...
That DOES put the antenna down by one's knee dosen't it?
Dave
On Sun, 1 Apr 2007 08:22:21 -0400, "Blueskies"
: of the aircraft).
: David Johnson
compass...
  #37
Old April 2nd 07, 01:03 AM posted to rec.aviation.owning,rec.aviation.piloting
Blueskies
"Dave" wrote in message ...
: Same...
: We have never used (or needed ) the ext antenna on ours..
: Only time we lost sig was on a looooong x-wind taxi with the yoke
: turned hard right....
: Welll...
: That DOES put the antenna down by one's knee dosen't it?
: Dave
You know, it is pretty amazing all the problems I hear about the Garmins loosing signal lock with the Garmin external
antenna. For more than 3x the price I would think they would have worked out all the bugs before selling it...
  #38
Old April 2nd 07, 11:08 PM posted to rec.aviation.owning,rec.aviation.piloting
Dave[_3_]
Yeah... 'mazin....
The guys here with the Lowrance plug them in, turn them on and go
flyin.....us included...
The Garmin stuff seems to have.... ummm.... issues....
At least they (finally!) took the freakin magnets out of the
antenna...
For 3 X the price, no way are they worth it!
Strange.. the Garmin Marine GPS equipment seems to work very well,
and is priced competitively..
Dave
On Mon, 02 Apr 2007 00:03:32 GMT, "Blueskies"
: Same...
: We have never used (or needed ) the ext antenna on ours..ah..
: Welll...
: Dave
  #39
Old April 3rd 07, 02:05 PM posted to rec.aviation.owning,rec.aviation.piloting
Dave Butler
Not interested in defending Garmin, but I'm just curious. What Garmin
and Lowrance models have equivalent function and a 3:1 price differential?
  #40
Old April 3rd 07, 04:00 PM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert
Dave,
What Garmin
Equivalent is a big word. Have a look at the Lowrance Airmap 600c and the
Garmin 296. Very similar in their capabilities. Yes, the displays are a
little different. So is the stuff that comes with them. But generally, they
do the same thing. At a price difference of at least a factor 2.
Thomas Borchert (EDDH)
Lowrance 2000c 1.7 update Greg Copeland Owning 6 June 26th 06 08:17 AM
Lowrance AirMap 2000c update Stephen Farris Instrument Flight Rules 0 June 4th 06 02:24 AM
Lowrance 2000c update Stephen Farris Products 0 June 4th 06 02:18 AM
No XM Weather For Lowrance 2000c...yet Jay Honeck Piloting 7 April 14th 06 08:31 PM
Lowrance Airmap 2000c Jeremy Lew Piloting 3 May 18th 04 09:01 PM
