A Falco's wing
Old March 26th 07, 10:52 PM posted to rec.aviation.homebuilt
Dale Martin
Default A Falco's wing
The last time I was at Oshkosh I talked to several Falco builders. Some
covered their plywood with dacron and some with fiberglass. The ones
covered in fiberglass were having some cracking problems (around the
tail). There will be a Falco fly-in at Chino Airport in Southern
California on Sep 22 with 13 to 15 Falco in attendance.
Lee McGee wrote:
The certified Bellanca Viking had mahogany plywood wing surfaces, covered
with regular dacron fabric and dope.
Mine was then sanded and finished in Imron, was absolutely mirror-like.
Construction must have been very similar to Falco.
Lee McGee
"Philippe Vessaire" wrote in message
Lou wrote:
Can anyone tell me what covering is used on a Falco?
I'm pretty sure it's plywood, but is it 100% plywood?
Anyone know how thick? Also, is there anything over the plywood like
dacron or fiberglass?
You may cover the wing with fiberglas, it's not realy heavier, bur the
finnish is nicer.
By
Volem rien foutre al païs!
Philippe Vessaire Ò¿Ó¬
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
composite wing, wing spars Dave Schneider Home Built 4 May 21st 04 05:35 AM
High Wing or Low Wing Bob Babcock Home Built 17 January 23rd 04 01:34 AM
End of High wing low wing search for me dan Home Built 7 January 11th 04 10:57 AM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
