Vietnam era F-4s Q
Old August 8th 03, 10:09 PM
Guy Alcala
Buzzer wrote:
On Fri, 08 Aug 2003 08:35:18 GMT, Guy Alcala
In the 1 1/2 year period between the introduction in SEA of the
APS-107D and the APR-36/37 which would you have preferred? The APS-54,
Vector 4, pre-qual/qual APR-25/26 or APS-107D? Especially if you knew
the APS-107D detected missile launch the same way as the year and a
half in the future APR-36/37?
Bob, I thought they'd modified the APR-26 to look at the signal
characteristics instead of just the power level so as to cutdown on false
launch warnings (the NVN 'playing the L-band'), and that this was carried
over to the APR-37?
I don't know the history of the F-4C APR-26 after last quarter of
1967. I remember on the F-105 weasel the Bowman mod that tied the
launch into the APR-25 strobe pointing to the site. No memory of any
changes to the launch detect for the APR-26 on the F-105 in 1969 at
Korat. Seems like I would remember that since it would have been like
the APR-37 my primary system at that time.
The AS light on the APR-36/37 was the simple version of the ALR-31 on
the weasel which I think had been around for a couple years.
You're right and I was misremembering. It seems that APR-37 was essentially
the APR-26 with that modification, but that APR-26 itself wasn't improved.
Here's what I've got, from Jenkins' book on the Thud:
"The Air Force also conducted a quick look evaluation of a potential APR-26
replacement in April [1966]. An HRB-Singer 934-1B missile warning receiver
was installed in 62-4416 and test flown at the Sanders facility, which had a
Fan Song missile guidance simulator not available at Eglin. The 934-1B
differed from the APR-26 in that it analyzed the modulation characteristics of
the C-band [i.e. radar L-band] guidance signal to differentiate between SA-2
missile activity and missile launch modes, while the APR-26 simply looked for
an abrupt amplitude increase. The HRB-Singer set performed well, but the Air
Force was already committed to a large APR-26 procurement and saw no
compelling reason to buy another system to perform the same function. Only
after the Wild Weasel III F-105s were in combat was it learned that the
APR-26's design was based on possibly faulty intelligence regarding the
amplitude increase. This led to numerous incidents of flase lower
threat-level 'activity' indications when 'missile launch' should have been
displayed. The APR-26 was later modified to analyze the guidance signal and
the improved sets redesignated APR-37."
This was separate from the QRC-317 SEE-SAMS/QRC-317A ALR-31, which was
eventually incorporated into the APR-25 ('SPOT SAM') and turned it into the
APR-36 (the 'centered in both beams' A/S light). Jenkins, further on his his
section on the Weasels, also seems to mention the same mod you call the
'Bowman', although not by name. The description certainly fits:
"A separate modification provided the capability to correlate a C-band missile
guidance signal received by the APR-26 to a specific E-F band signal displayed
on the APR-25 azimuth indicator."
BTW, how was this displayed by the strobe? I've seen references elsewhere to
dashed versus solid lines or something similar, but nothing authoritative.
Guy
Old August 8th 03, 10:30 PM
Ed Rasimus
Not to disparage Jenkins, who's done great research on the F-105, but
"potential replacement in April (1966)" doesn't track well with my
experience. I arrived at Korat in May of '66 and at that time the
APR-25/26 was just being initially installed in the operational jets.
We had maybe a dozen airplanes out of 40 or so with the "vector" gear.
Installation of the entire fleet wasn't completed until mid-June. I
hadn't even seen or been briefed on the RHAW gear while in training at
Nellis through April of '66. To be seeking replacement before initial
installation doesn't make any sense.
I'm not a "squeaks and beeps" EW, but here's what I was taught about
the sequence for the SA-2. The initial TDU (Threat Display Unit) light
were for "Lo" indicating a low PRF (pulse recurrence frequency), as
you got lit up with both beams of the Fan Song (Az & El), you got a
"Hi" for high PRF. When missile data upload was taking place, another
frequency was employed (that's where an EW could tell you more) you
got an "Activity" light and when command guidance signals were
received, indicating control signals to the missile airborne, you got
the "Launch" light.
While the "correlate a C-band missile guidance signal to a specific
E-F band signal" tracks with what I said above regarding "launch"
lites, it doesn't equate with what the definition of the AS light was.
The AS (azimuth sector, but colloquially the "aw ****" light) meant
you were illuminated by both the horizontal and elevation beams of the
Fan Song at high PRF. It literally meant that you were the designated
target for that particular missile system. It did NOT relate to a
missile actually being launched.
Yes, different frequency bands displayed different strobes. A Fire Can
was a solid strobe, a Fan Song a three dash line, and something else
(CRS strikes here) for an AI (air intercept) radar.
In the high threat arena, the 25/26 was notorious for degenerating
into a big "spider" in the center of the scope.
Ed Rasimus
Fighter Pilot (ret)
***"When Thunder Rolled:
*** An F-105 Pilot Over N. Vietnam"
*** from Smithsonian Books
ISBN: 1588341038
Old August 9th 03, 01:20 AM
Buzzer
On Fri, 08 Aug 2003 21:09:57 GMT, Guy Alcala
And there we were in June 1966 sitting on the ground at Eglin with the
F-4C WWIV waiting for range time on the SADS and cancelling for rain
when another site was available. Here I thought and was led to believe
the Eglin SADS was the only one available..
The 934-1B
Shame they didn't have to stand up before a couple hundred pilots and
say we see no compelling reason to give you a better system that would
give you more confidence and might save your life! Welcome to the
realities of the Vietnam War..
Only
The original story I heard in June 1966 at the APR-25/26 class at
Keesler and later from the tech reps was the missile guidance signal
was feed into a dummy load. That caused the Activity Light to come on.
Then when they launched and switched to active guidance at a higher
power the Launch Light came on. Another variation on that was they
interrogated the missiles at low power before launch that gave the
Activity and then went high power to guide giving Launch light. No
mention at all of how the missile was quided until I took the
APR-36/37 factory course in 1968 at ATI/ITEK in Palo Alto, CA. Here
they went into the guidance pulse train and what the APR-37 looked at.
They talked like this was recent intel and here the info had been
around for years.
I'm not sure how the ALR-31 was tied into everything else on the
F-105. I saw the circuit boards with a zillion surface mounts ICs on
them and I was in awe. It made the APR-26 and 36 look like crystal
radios. I remember a control box on the left rear panel. Little meter
about 3/4 inch across that indicated beams centered when the needle
centered sticking up in the center. How anyone could see the thing
while flying was beyond me.
I've seen the explanation of the mod somewhere on the net or in a
book. I can't find it now on the net, but I might have it saved to a
CD. Bowman might not be the right spelling, but sounds close to that.
He was an airman at Korat ECM shop when he got the idea. He was kind
of a legend when I got to Korat in Nov 1968. Went on to work for
ATI/ITEK..
I don't remember what the article said. If it worked during self-test
on the weasels I don't remember seeing it. Flashed the strobe on and
off is as close as I can get.
Old August 9th 03, 01:40 AM
Buzzer
Here is one reference:
Bauman Mod
http://www.airandspacemagazine.com/A...8/AS/ctpn.html
I can't confirm that is the scope display..
Old August 9th 03, 04:06 AM
Tex Houston
"Guy Alcala" wrote in message
his
Guy
I suspect it is not "Bowman" but "Bauman" as this sounds very much like the
project he invented at Takhli about 1966-1967.
Regards,
Tex
Old August 9th 03, 07:01 AM
Les Matheson
You got most of it correct. Initial acquisition was usually done by SAM in
Low PRF therefore you got a Low light, Switching to High PRF changed the
light to High. If you were in both AZ and EL sectors you got the AS
(Acquisition Sector) light. Launch for the SA-2 was done on acquisition of
additional signals in a two step process. Lights and tones for warning.
Not the most accurate indicator, but the only one we had.
Different strobe types were for frequency differentiation. Can't say more,
besides I forgot the break points. Too many systems in the head since then.
Les
F-4C(WW),D,E,G(WW)/AC-130A/MC-130E EWO (ret)
"Ed Rasimus" wrote in message
the "Launch" light.
Old August 9th 03, 07:05 AM
Guy Alcala
As noted below, this was the WWIII fit, and they were just starting procurement.
The question was whether they'd confirm
procurement of the APR-26 or go with the HRB-Singer set. Almost no sets of either
type had yet been fitted to trials a/c, and only a few of the APR-25/-26/IR-133 to
the F-100F WWs.
"Hi" for high PRF.
H'mm that seems a bit off. Normally, fire control sets search at a lower PRF, then
track at a higher one. FWIW, the first available site I could find credits Fan
Song C/E with the following PRFs:
PRF 828-1440 Search. 1656-2880 Trk.
Fan Song B and F would show similar differences in PRF, although the specific
numbers would probably be different. You need the lower PRF for search/acquisition
to eliminate second time around range ambiguity, which also allows you to use
longer (hence more powerful) pulses. But you lose range resolution, so once
detected the radar will normally switch to a higher PRF for tracking (same with the
F-4, btw).
So, Low PRF would indicate general search mode, High PRF would indicate tracking
_somebody_ (at shorter range). That at least would be the case with the APR-25.
While you'd undoubtedly BE in both beams while the radar was tracking you or
someone close to the same LoS (as Marshall mentions in his LB II book, tracking
usually had to done manually after pods arrived), the PRF lights wouldn't be
indicating position in the beam per se, but just the radar PRF, a far simpler
procedure. Location in the beam sweep was a later addition -- That was what the
ALR-31 (and the same or similar circuit in the APR-36, attached to the A/S light)
would do. From the Air & Space article Bob referenced:
"Klimec set out to improve on the existing RHAW system, which only told you that a
SAM was looking, or launching, and gave only a general bearing to the radar source.
At this early stage in anti-radar development, before specially designed missiles
that home in on radar signals were available, the target still had to be visually
acquired and attacked with conventional weapons like rockets, guns, or bombs.
"The Fan Song was one of the first electronic scanning radars--it directed its
energy without having to move its antenna. "The way the Soviets built the Fan Song
was to have [one] radar that tracks both the aircraft and the missile," Klimec
says. "It would scan across 20 degrees and then go off the air, because you had to
shut the radar down in order to preclude any kind of problems with the energy
coming back inside and blowing out equipment--and then it would fly back, come back
on again, and scan 20 degrees, and go off the air."
"The radar cycled several times per second and was directed so that a targeted
aircraft was located at the center of the scan sector, which enabled the missile to
be maneuvered freely inside, while the target was simultaneously tracked by the
radar.
"So it dawned on me that if we could detect when the radar came on, and we could
determine when the aircraft was illuminated on the radar in the main beam, and we
could detect when the radar shut down to fly back, we could calculate the position
of the plane relative to the scan sector," Klimec says. It was known that the Fan
Song took about 100 milliseconds to complete a scan, so if an aircraft was
"painted" by the radar 50 milliseconds after the radar turned on, the aircraft was
in the mid-point of the scan sector. "And the aircraft ordinarily did not get to
the center of the sector unless somebody put him there--and since the tracking scan
system could only track one aircraft to make an intercept on one aircraft, if you
found yourself in the center of the scan sector and you found you stayed there,
then you knew somebody had selected you as a target," he says.
"After design engineers devised equipment to verify Klimec's theory, he began
monitoring the Eglin Fan Song simulator's emissions from the top of a hangar. "I
talked on the phone to the radar site and got them to move it a little bit, and we
verified that we could detect when the radar came on to start the scan, we could
detect when it went off the air, and we could detect when we got the large spike of
energy as the main beam came by," Klimec says. Klimec's innovation eventually
allowed fighter crews to know whether or not they were targets and to take action
only if they were."
So, prior to the ALR-31/APR-36, you might be in one or both beams and getting High
PRF, but not be in the center of the Fan Song sweep because it was actually
targeting some other a/c close to the same angle between the radar and you, leading
to unnecessary maneuvers and high pulse rates. You'd also pick up the L-band
guidance signal, again without necessarily being the target.
the "Launch" light.
Right, the guidance used the C-band dish on the left of this picture (the E/F or
G-band tracking antennas are the horizontal and vertical troughs):
http://fas.org/nuke/guide/russia/airdef/fan_song2.jpg
I know, you're misinterpreting what I wrote. The A/S and the above mod are two
separate things. Here's what I'm talking about (again from the Air & Space article
Bob pointed out):
"As tactics were developed in the air, field modifications to the Wild Weasel
systems continued on the ground. A key weakness of the equipment was that if
several SAM sites were displayed on the scope and the light that signaled a launch
was illuminated, there was no way to know which site had fired and from which
direction the SAM was coming. "I heard the crews complaining about that," says
Weldon Bauman, who in 1967 was a junior enlisted technician at Takhli. "And I
thought Well, if I knew more about the signal, then maybe we could do something
about it." Bauman became a Wild Weasel legend for devising a system similar to Bob
Klemic's but that sidestepped cumbersome and lengthy procurement procedures and
could be hot-wired into the aircraft in the field immediately. But to do it, he
first needed access to sensitive data about the nature of SAM site radar emissions,
and after convincing an EWO to escort him into the intelligence section, he got the
information he needed. "I sat down and got the real-time data--the same day then
was real time," Bauman says. "I found out what they were seeing and then went back
and designed a circuit and it worked." When activated, Bauman's modification
cleared the scope of all information except for a blip that indicated the launching
site. Tom Wilson, a former F-105 EWO, marveled at Bauman's ingenuity and his
modesty. "This kid had two stripes, and he was so damn smart it was unreal," Wilson
says. "When I asked him how he came up with the mod, he said, "It was real easy.
Just three little parts wired into the line for the scope, and a switch, and it was
done.' "
Right, see above.
Thanks. BTW, in the case of say a two-ringer growing to a three, did the strobe
extend in from the periphery, or out from the center? I've always assumed it was
the latter (looking similar to a PPI display), but I've never seen a source I trust
which says which it was.
Thanks,
Guy
  #28
Old August 9th 03, 07:32 AM
Juvat
After an exhausting session with Victoria's Secret Police, Ivan
blurted out:
This is great stuff...Thanks for posting it.
You're welcome!
Anyway, are this dates correct?
Yes they are.
This is strange, intro team was some kind of ground personel or
something else?
Yes, staff personel from Eglin AFB (the Tactical Air Warfare
Center_TAWC) and Nellis AFB (the Tactical Fighter Weapons
Center_TFWC).
Their purpose was to aid PACAF in expeditiously phasing the Rivet
Haste aircraft into the combat environment, including orientation,
familiarization, briefing, and evaluating the initial employment of
Rivet Haste jets and crews.
I also have a copy of the Project CHECO report "COMBAT SNAP: AIM-9J
Southeast Asia Introduction," but Guy addressed the issue for you.
Would you mind posting some other details from these both reports?
No problem...anything you're looking for, specifically? The Rivet
Haste report is only 22 pages. The COMBAT SNAP report is about 30 or
so pages long.
Juvat
  #29
Old August 9th 03, 08:02 AM
Guy Alcala
The 934-1B
At the time I'm sure the APR-26 seemed adequate, and they didn't realize its
shortcomings. If the APR-26 was already in low-rate production, it was probably
figured that getting something into action soonest was better than waiting for
something potentially better later. Jenkins describes a whole bunch of concurrent
programs and fits which they were experimenting with, and just getting some F-105F
Weasels completed and functional so they could test them was very difficult. There
were a lot of systems that were better on paper, but which proved difficult if not
impossible to make work in the time required. He also covers the APS-107 which was
rejected for the Wild Weasel II (F-100F) program and later considered as a
potential system (APS-107B internal for the F-105D along with the navy's ALQ-51
jammer (which later were installed in RF-101s), as well as the Bendix DPN-61
DF/homing system (the Az-el antennas) and various competing systems.
Only
The latter would seem to make more sense assuming that the VPADF were really
'playing the L-band' to make us think they'd launched when they hadn't. I wonder
if our receivers would be sensitive enough to detect a dummy load at the time --
after all, the whole point was to warm everything up without warning everyone in
the area that they were ready to go (like a radar in standby).
No
around for years.
snip
It may well have been recent. They only got the missile prox. fuse and some
guidance data in Feb. 1966, from a Firebee drone that they flew around trolling for
SAMs, relaying the data to an RB-47 just before the drone was destroyed. And then
we got our hands on complete SA-2 systems after the Six Day War.
Guy
  #30
Old August 9th 03, 08:05 AM
Guy Alcala
Bauman Mod
Thanks.
One would hope not;-)
Guy
FA: Vietnam The Helicopter War Large HC Book 189p Disgo Aviation Marketplace 0 February 6th 04 05:19 PM
Dogfights in Vietnam Mike Military Aviation 11 July 30th 03 09:47 PM
Australia tries to rewrite history of Vietnam War Evan Brennan Military Aviation 34 July 18th 03 11:45 PM
Trying to make sense of Vietnam air war Otis Willie Military Aviation 0 July 6th 03 11:13 PM
Vietnam search to continue to find remains of Waterford pilot Otis Willie Military Aviation 0 July 2nd 03 10:30 PM
