Hershey bar wing vs composite wing - how much drag?
Old March 29th 07, 12:39 AM posted to rec.aviation.owning,rec.aviation.homebuilt
john smith[_2_]
Default Hershey bar wing vs composite wing - how much drag?
"Montblack" wrote:
("Wayne Paul" wrote)
It is much easier to build a laminar flow airfoil and complex shaped
wing to fuselage transition using composite construction. These wing have
a better lift to drag ratio. The decrease in drag aerodynamic drag of
the wing and static drag decrease associated with the wing/fuselage
transition allow faster speeds.
Can you reword this (for some of us "Huh?" lurkers) especially the wing to
fuselage transition part?
How good/efficient are Cherokee, Ercoupe, Cessna (aluminum & rivet) wing
root fairings vs. what could be achieved with complex composite shapes?
Same question with the wing shape - to hold up the same plane, ALL else
being equal?
So ballpark - how much more efficient would the use of complex composite
construction (wings and wing root transition areas) make these planes - ALL
else being equal?
Paul,
Go to airliners.com or any other site that will have "new" and "old"
airplanes. Pay particular attention to the wing-fuselage junction.
On the old airplanes, the fuselage seems to be just stuck to the wing.
On the new aiplanes, there are HUGE fillets fore and aft of the wing.
This really became a design consideration in the mid-1980's.
Old March 29th 07, 05:11 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Montblack
("john smith" wrote)
On the new aiplanes, there are HUGE fillets fore and aft of the wing. This
Wheel pants, gap seals, ....and HUGE new fiberglass fillets (fore and aft).
Are they part of everyday speed-mod packages?
If so, what is the "anecdotal" gain, after installing (just) them?
I've read reports on wheel pants, on gap seals, and on Power Flow exhaust
systems, but not on aftermarket fillets for the GA fleet.
http://www.powerflowsystems.com/
Montblack
airliners ...net? :-)
Old March 29th 07, 01:31 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Nathan Young
On Wed, 28 Mar 2007 23:11:29 -0500, "Montblack"
Knots2U sells a wing/fuselage fairing.
http://knots2u.com/28WR.htm
I have it on my Cherokee, but cannot discern the exact performance
gain as it was added in conjunction with a number of other mods.
fixed wing or rotary wing? Craig Campbell Rotorcraft 23 March 27th 07 06:16 AM
High wing to low wing converts...or, visa versa? Jack Allison Owning 99 January 27th 05 11:10 AM
composite wing, wing spars Dave Schneider Home Built 4 May 21st 04 05:35 AM
Fuel Dip Tube for Hershey-bar Wing Cherokees? Bob Chilcoat Owning 3 May 3rd 04 10:29 PM
Mylar tape wing seals - effect on wing performance Simon Waddell Soaring 8 January 1st 04 03:46 PM
