A tower-induced go-round
Old March 29th 07, 04:05 PM posted to rec.aviation.piloting
Default A tower-induced go-round
Larry Dighera wrote:
On Thu, 29 Mar 2007 03:05:04 GMT, wrote in
I was only following orders was decided to be a non-defense for the
actions of those in command back in 1945.
http://groups.google.com/group/rec.a...426456ad1724f2
Newsgroups: rec.arts.sf-lovers
Date: 18 Aug 91 21:50:29 GMT
Local: Sun, Aug 18 1991 2:50 pm
Subject: Nazis (was Card's Article on Homosexuality
In article
(J Eric Townsend) writes:
Who was it that said: "Whenver somebody starts mentioning Nazis
on USENET, you know the discussion has gone on too long."? (Or
something to that effect.)
I said it.
Godwin's Rule of Nazi Analogies: As a Usenet discussion grows
longer, the probability of a comparison involving Nazis or Hitler
approaches one.
--Mike
Mike Godwin, | "Someday, some way."
(617) 864-1550 | --Marshall Crenshaw
EFF, Cambridge, MA |
Yeah, I know.
I hesitated to use that line just because of Godwin's Rule, but it
seems so appropriate for the anal retentive types that insist that
all they have to follow is the CFAR's and their actions are justifiable
irregardless of the consequence of their acts because they are in
command.
I'm open to other analogies, how about:
Just because the law allows you a cell phone doesn't mean it is OK
to carry on a loud conversation in a restaurant/theater.
Jim Pennino
Remove .spam.sux to reply.
  #143
Old March 29th 07, 04:35 PM posted to rec.aviation.piloting
Jose wrote:
No, it is an example of a local procedure where it is possible, and
likely, to cause a conflict if some cowboy decides no one is going
to tell him what to do and ignores it just because he has a legal right
to do so.
The reason the procedure is as it is is to minimize noise over the
housing area to the North, the college to the West, and facilitate
no-radio VFR traffic in and out avoiding the surrounding class D
and class C airspaces.
It has been in place for decades and no one, except maybe you, has
any problem with.
I haven't looked over the procedure in question, and the "problem I
have" isn't with the procedure, it's with the =idea= that a few locals
can dummy up a procedure that is in conflict with generally accepted
flying procedures (like the AIM) and with FAA mandated procedures (like
an ODP if it applies).
Nonsense.
Local procedures aren't a "dummy up" process by "a few locals", they
are based on the known conditions of the airport in question and done
by the airport management.
Also, they are not in conflict with anything, as, as several have
noted, they are not mandatory by any stretch of the imagination.
Further, if you actually read the AIM, you see the patterns in 4-3-3
are recomnended, not mandatory.
Not following the local procedure, while not illegal, is at the
minimum discourteous, and at the worst, dangerous.
If you have a problem with the concept, you need to grow up and learn
to play nicely with others as this has been around since the beginning
of aviation.
That's not what I am advocating.
It most certainly is.
No it isn't. Is this the five minute argument, or did you want the full
half hour?
...you also have to have the maturity
to understand that not everything is covered by a black and white
regulation and that your decisions and actions also require other
inputs besides those regulations to avoid unintended consequences.
I certainly understand that. It seems that you don't. Perhaps this is
just an artifact of Usenet discussion, but your posts are also black and
white - "the local yokels came up with this procedure because they don't
like noise, and you claim it is unsafe to differ from it, no matter what
the FAA says".
Your repeated disparagement of the airport management, which in most
cases has many decades of experience, is noted.
Your inablility to understand that local procedures are formulated
by the airport management and not a mob is noted.
Your inabliity to realize such things have been around since the
beginning of aviation and that the FAA has no objection to it is
noted.
the unintended
consequence could well be a midair with an arriving student following
the local procedure which has been drummed into him by his CFI.
A local procedure that causes an unsafe condition (such as a midair with
an aircraft on a standard procedure) should probably be reconsidered.
There may be situations where nonstandard procedures are warranted.
They should be publicized where pilots would look for them. That would
be the AF/D. To make up a nonstandard procedure which is dangerous when
mixed with standard procedures, and not promulgate it via NOTAM or AF/D
is a problem. It's more than just "legal words".
This is probably the only thing we can agree on.
While you are required to obtain all relevant information to a flight
before takeoff, a lot of local procedures are not in the AF/D which
makes it difficult for everyone to find them.
But, since common sense, and I do believe a regulation somewhere,
requires you to observe the existing traffic and blend in with it
at none-towered airports, there is not much of an excuse not to
follow what everyone else is doing.
Jim Pennino
  #144
Old March 29th 07, 04:48 PM posted to rec.aviation.piloting
Jose
.... as is the "local procedure"
Ditto AIM.
of aviation.
I have no problem playing nicely with others. I have a problem with
others telling me deciding for me what I should do, rather than letting
me decide for myself how I want to play nicely with others.
Or not.
Jose
Get high on gasoline: fly an airplane.
  #145
Old March 29th 07, 05:05 PM posted to rec.aviation.piloting
Steven P. McNicoll wrote:
"Jose" wrote in message
t...
I haven't looked over the procedure in question, and the "problem I have"
isn't with the procedure, it's with the =idea= that a few locals can dummy
up a procedure that is in conflict with generally accepted flying
procedures (like the AIM) and with FAA mandated procedures (like an ODP if
it applies).
TAKE-OFF MINIMUMS AND (OBSTACLE) DEPARTURE PROCEDURES
SW-3
07074
UPLAND, CA
CABLE
TAKE-OFF MINIMUMS: Rwy 6, 300-1 or std. with a min. climb of 240' per NM to
1900.
DEPARTURE PROCEDU Rwy 6, climbing right turn. Rwy 24, climbing left turn.
All aircraft climb direct PDZ VORTAC. Aircraft departing PDZ R-091 CW R-140
and R-231 CW R-280 climb on course. All others continue climb in PDZ holding
pattern (E, right turns, 258? inbound) to cross PDZ VORTAC at or above:
R-281 CW R-090, 6700; R-141 CW R-230, 4000.
Yep, those are the IFR procedures.
Which part of the local procedures being for VFR are you having trouble
understanding?
The 24 IFR departure is identical to the 24 VFR departure to the South
except the IFR departure references a VORTAC while the VFR departure
references a VFR landmark. The path in the area of the airport is the
same in both cases.
The 6 IFR departure does not conflict with any VFR procedure.
The 6 IFR departure takes you immediately into class C airspace, while
the 6 VFR departure takes you away from it.
The 6 IFR departure would be illegal to do without a radio, and if
you did it with a radio, while legal, it would **** of the class C
tower which is expecting you to use the VFR procedure and call them
when you get close to midfield if you intend to cross their airspace.
The tower would direct you to follow a path that is roughly the same
as the VFR departure path though perhaps inside their airspace while
the VFR path keeps you out of it.
Jim Pennino
  #147
Old March 29th 07, 05:15 PM posted to rec.aviation.piloting
Ditto AIM.
of aviation.
Or not.
Doing what the rest of the world expects you to do if there is no
overriding reason not to is the definition of playing nicely with
others.
Doing what you want just because it isn't illegal without any regard
for how it effects others is the definition of arrogance.
Jim Pennino
  #148
Old March 29th 07, 05:22 PM posted to rec.aviation.piloting
Jose
others.
Except that in this case "The rest of the world" is just you.
Jose
  #149
Old March 29th 07, 05:45 PM posted to rec.aviation.piloting
others.
In this case, "the rest of the world" is thousands of other pilots
over several decades, and that is just at one, small, airport.
If you expand that radius to 50 KM, you are now talking about tens
of thousands of pilots and a cumulative time of centuries.
It appears most people don't have a problem with the concept.
Jim Pennino
  #150
Old March 29th 07, 06:01 PM posted to rec.aviation.piloting
Jose
Tens of thousands of pilots have subscribed to your local noise
procedure? They also subscribe to the idea that everyone must follow it
or unsafe conditions result?
Jose
Round Engines john smith Piloting 20 February 15th 07 03:31 AM
induced airflow buttman Piloting 3 February 19th 06 04:36 AM
Round Engines Voxpopuli Naval Aviation 16 May 31st 05 06:48 PM
Source of Induced Drag Ken Kochanski Soaring 2 January 10th 04 12:18 AM
Predicting ground effects on induced power Marc Shorten Soaring 0 October 28th 03 11:18 AM
