Richard Riley writes:
It is perfectly capable of flying an entire mission, from engine start, to cruise flight, to touchdown and engine stop, autonomously. That does not surprise me. I recall reading about proof-of-concept studies along these lines when I was a kid, and I'm sure the field hasn't stood still since then. The principle is pretty straightforward, although the devil is in the details, as usual. In the US, at least, we are required to have a set of mark 1 pilot eyeballs on it at all times to maintain separation. And the pilot has to have a class 2 medical and a commercial certificate. So the pilot is a regulatory requirement ... not a technical one. Visual separation is only needed because other aircraft in the area are not autonomous and in communication with yours. But imagine, say, Class A airspace in which all aircraft are similarly equipped. Nothing up there but other aircraft of the same breed, and no obstacles or terrain. It would be much easier to fully automate things there. Later, it could be automated at lower altitudes and in different flight phases. Unfortunately, this implies either severe restrictions on small GA aircraft, or extremely expensive upgrades to those aircraft to make them compatible with automated aircraft. The other option--making autonomous unmanned aircraft capable of maintaining visual separation--is probably not feasible technically and economically. Already, RVSM requires autopilots. The trend will probably continue, with pilots becoming more and more peripheral to the flying task. There may come a time when the only real flying that pilots will be permitted to do is private GA. All commercial aviation will be handled by robots, and if human "pilots" are present at all it will only be as emergency attendants. In some ways, this is easier for aviation than for road vehicles, although it's easier still for trains, I think. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
news ![]() Richard Riley writes: It is perfectly capable of flying an entire mission, from engine start, to cruise flight, to touchdown and engine stop, autonomously. That does not surprise me. I recall reading about proof-of-concept studies along these lines when I was a kid, and I'm sure the field hasn't stood still since then. The principle is pretty straightforward, although the devil is in the details, as usual. In the US, at least, we are required to have a set of mark 1 pilot eyeballs on it at all times to maintain separation. And the pilot has to have a class 2 medical and a commercial certificate. So the pilot is a regulatory requirement ... not a technical one. Visual separation is only needed because other aircraft in the area are not autonomous and in communication with yours. But imagine, say, Class A airspace in which all aircraft are similarly equipped. Nothing up there but other aircraft of the same breed, and no obstacles or terrain. It would be much easier to fully automate things there. Later, it could be automated at lower altitudes and in different flight phases. Unfortunately, this implies either severe restrictions on small GA aircraft, or extremely expensive upgrades to those aircraft to make them compatible with automated aircraft. The other option--making autonomous unmanned aircraft capable of maintaining visual separation--is probably not feasible technically and economically. Already, RVSM requires autopilots. And you don't even know why. bertie |
Mxsmanic wrote:
: :Unfortunately, this implies either severe restrictions on small GA aircraft, ![]() :automated aircraft. The other option--making autonomous unmanned aircraft :capable of maintaining visual separation--is probably not feasible technically :and economically. I would not expect it to be THAT technically difficult. The question is trusting the technology that does it and what happens when you take a casualty. Oddly, we insist on having a fragile human as a backup to technology when it's the human that is the most failure prone part of the overall system. :There may come a time when the only real flying that pilots will be permitted :to do is private GA. All commercial aviation will be handled by robots, and :if human "pilots" are present at all it will only be as emergency attendants. It's largely that way now for large modern airliners. Driving them around on taxiways still requires a human being, but the airplane can pretty much do everything else by itself. It's my understanding that F/A-18s can take off and land all by themselves (and this from an aircraft carrier, which is a bit more difficult than using one of those big concrete ribbons on solid ground). I gather that the automated cat sequence is used but the automated trap sequence is typically not. Fighter pilots are not a particularly trusting lot... :-) :In some ways, this is easier for aviation than for road vehicles, although :it's easier still for trains, I think. I believe we still have a requirement for trains that they have a 'dead man' throttle. Somebody has to be holding the control or the train will stop itself. -- "The reasonable man adapts himself to the world; the unreasonable man persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man." --George Bernard Shaw |
Fred J. McCall writes:
I would not expect it to be THAT technically difficult. Not difficult so much as expensive. If every aircraft can be guaranteed to carry the necessary equipment, it should be possible to get it all to work. But stuff like this is going to be really expensive, and how many owners of small GA aircraft could afford avionics that cost several times more than the airframe? And if everyone isn't using it, that leaves loopholes through which accidents can occur. So you either have to sterilize the airspace in which it is used, so that no unequipped aircraft enter it, or you have to force everyone to become equipped before they fly. If you restrict the system to Class A or something, you might have a useful compromise, but extending it to the entire airspace would be problematic. Technically, though, it should work just fine, as long as everyone has the gear. The question is trusting the technology that does it and what happens when you take a casualty. Oddly, we insist on having a fragile human as a backup to technology when it's the human that is the most failure prone part of the overall system. Only because that's not entirely true. Human beings aren't that fragile, for one thing. For another, they are very, very good at dealing with completely unexpected and unanticipated situations, whereas digital systems fail catastrophically when confronted with anything that their designers did not foresee. An automated system might not see anything wrong with flying an aircraft inverted if it comes upon a situation that it isn't programmed to handle, whereas a human pilot immediately sees that there's something unacceptable going on, and moves to correct it. For situations that you've anticipated and designed for, the computers will always outperform the human beings. But for situations that you've neglected to plan for in your design, a human being is the best possible fail-safe mechanism. This is why pilots will be in cockpits long after the cockpits are completely automated. Only when experience proves that the digital systems are reliable enough to not cause unacceptable rates of accidents will the pilots be removed. That point can eventually be reached. Notice that you have a timer on your microwave oven, not merely an on/off switch. That's because the digital timer system is reliable enough nowadays that it doesn't require a human back-up for unanticipated situations. But we are still a long way from that in aviation. It's largely that way now for large modern airliners. Driving them around on taxiways still requires a human being, but the airplane can pretty much do everything else by itself. That's not what all the "real" pilots say here in this newsgroup. They stridently insist that it cannot be done. But, like you, I know that it can be done, and it is being done now. It's my understanding that F/A-18s can take off and land all by themselves (and this from an aircraft carrier, which is a bit more difficult than using one of those big concrete ribbons on solid ground). I gather that the automated cat sequence is used but the automated trap sequence is typically not. Fighter pilots are not a particularly trusting lot... :-) It's good to be cautious. I didn't know that the aircraft could do that, but it's interesting to learn. Somehow I'd expect fighters to be the last aircraft to fully automate ... although it's also true that the weakest component in a fighter aircraft is the pilot (because the performance of the aircraft has to be limited in order to keep the pilot alive). I believe we still have a requirement for trains that they have a 'dead man' throttle. Somebody has to be holding the control or the train will stop itself. For regular railways, yes, but for things like subways, sometimes the system is fully automated, with no human beings at all. Subways have fewer variables than outdoor railways, though. I've heard that there are "dead man's throttles" on some aircraft, too, but I don't have much in the way of details. Traditionally pilots have been so busy in the cockpit that they couldn't really doze off, but with increasing automation it becomes a concern. It's easy to fall asleep on a long flight where the FMC is in control for several hours at a time. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: Fred J. McCall writes: I would not expect it to be THAT technically difficult. Not difficult so much as expensive. If every aircraft can be guaranteed to carry the necessary equipment, it should be possible to get it all to work. But stuff like this is going to be really expensive, and how many owners of small GA aircraft could afford avionics that cost several times more than the airframe? And if everyone isn't using it, that leaves loopholes through which accidents can occur. So you either have to sterilize the airspace in which it is used, so that no unequipped aircraft enter it, or you have to force everyone to become equipped before they fly. If you restrict the system to Class A or something, you might have a useful compromise, but extending it to the entire airspace would be problematic. Technically, though, it should work just fine, as long as everyone has the gear. The question is trusting the technology that does it and what happens when you take a casualty. Oddly, we insist on having a fragile human as a backup to technology when it's the human that is the most failure prone part of the overall system. Only because that's not entirely true. Human beings aren't that fragile, for one thing. For another, they are very, very good at dealing with completely unexpected and unanticipated situations, whereas digital systems fail catastrophically when confronted with anything that their designers did not foresee. An automated system might not see anything wrong with flying an aircraft inverted if it comes upon a situation that it isn't programmed to handle, whereas a human pilot immediately sees that there's something unacceptable going on, and moves to correct it. For situations that you've anticipated and designed for, the computers will always outperform the human beings. But for situations that you've neglected to plan for in your design, a human being is the best possible fail-safe mechanism. This is why pilots will be in cockpits long after the cockpits are completely automated. Only when experience proves that the digital systems are reliable enough to not cause unacceptable rates of accidents will the pilots be removed. That point can eventually be reached. Notice that you have a timer on your microwave oven, not merely an on/off switch. That's because the digital timer system is reliable enough nowadays that it doesn't require a human back-up for unanticipated situations. But we are still a long way from that in aviation. It's largely that way now for large modern airliners. Driving them around on taxiways still requires a human being, but the airplane can pretty much do everything else by itself. That's not what all the "real" pilots say here in this newsgroup. They stridently insist that it cannot be done. But, like you, I know that it can be done, and it is being done now. It's my understanding that F/A-18s can take off and land all by themselves (and this from an aircraft carrier, which is a bit more difficult than using one of those big concrete ribbons on solid ground). I gather that the automated cat sequence is used but the automated trap sequence is typically not. Fighter pilots are not a particularly trusting lot... :-) It's good to be cautious. I didn't know that the aircraft could do that, but it's interesting to learn. Somehow I'd expect fighters to be the last aircraft to fully automate ... although it's also true that the weakest component in a fighter aircraft is the pilot (because the performance of the aircraft has to be limited in order to keep the pilot alive). I believe we still have a requirement for trains that they have a 'dead man' throttle. Somebody has to be holding the control or the train will stop itself. For regular railways, yes, but for things like subways, sometimes the system is fully automated, with no human beings at all. Subways have fewer variables than outdoor railways, though. I've heard that there are "dead man's throttles" on some aircraft, too, but I don't have much in the way of details. No there aren't, fjukktard bertie |
Mxsmanic wrote:
:Fred J. McCall writes: : : I would not expect it to be THAT technically difficult. : :Not difficult so much as expensive. If every aircraft can be guaranteed to :carry the necessary equipment, it should be possible to get it all to work. But every aircraft doesn't have to carry it. You handle it the way the disparity in equipment between big airliners and little general aviation aircraft is handled now. :But stuff like this is going to be really expensive, and how many owners of :small GA aircraft could afford avionics that cost several times more than the :airframe? And if everyone isn't using it, that leaves loopholes through which :accidents can occur. But you know whose fault they are. If they don't have the appropriate equipment, they are required to operate VFR. You could go further and ban them from certain TCAs. :So you either have to sterilize the airspace in which it is used, so that no :unequipped aircraft enter it, or you have to force everyone to become equipped :before they fly. You wouldn't have to do either, any more than you have to require everyone to have collision avoidance radars and such now. :If you restrict the system to Class A or something, you :might have a useful compromise, but extending it to the entire airspace would :be problematic. Why? :Technically, though, it should work just fine, as long as everyone has the :gear. And even if everyone doesn't. Just like things work fine now when everyone doesn't have all the gear. : The question is trusting the technology that does it and what happens : when you take a casualty. Oddly, we insist on having a fragile human : as a backup to technology when it's the human that is the most failure : prone part of the overall system. : :Only because that's not entirely true. Human beings aren't that fragile, for ![]() They're a hell of a lot more fragile than the rest of the technology in the cockpit. :For another, they are very, very good at dealing with completely :unexpected and unanticipated situations, whereas digital systems fail :catastrophically when confronted with anything that their designers did not :foresee. Humans tend to fail catastrophically when confronted with anything that the designers of their training did not foresee. :An automated system might not see anything wrong with flying an :aircraft inverted if it comes upon a situation that it isn't programmed to :handle, whereas a human pilot immediately sees that there's something :unacceptable going on, and moves to correct it. Yes, if you assume that the folks setting up the automated system are idiots you can assume all sorts of things. :For situations that you've anticipated and designed for, the computers will :always outperform the human beings. But for situations that you've neglected :to plan for in your design, a human being is the best possible fail-safe :mechanism. This is why pilots will be in cockpits long after the cockpits are :completely automated. Only when experience proves that the digital systems :are reliable enough to not cause unacceptable rates of accidents will the ![]() Experience right now indicates that human beings make really lousy fail-safes for automated systems. This is because they are not 'in the loop' when something goes wrong and by the time they catch up with the situation it is usually too late to take corrective action. This is why automated systems frequently wind up not being used and aircraft flown 'by hand' even though it is not required. :That point can eventually be reached. Notice that you have a timer on your :microwave oven, not merely an on/off switch. That's because the digital timer :system is reliable enough nowadays that it doesn't require a human back-up for :unanticipated situations. But we are still a long way from that in aviation. Not really, no. Just how much of the air traffic currently up there do you think is NOT being flown by automated systems? : It's largely that way now for large modern airliners. Driving them : around on taxiways still requires a human being, but the airplane can : pretty much do everything else by itself. : :That's not what all the "real" pilots say here in this newsgroup. They :stridently insist that it cannot be done. How many 'heavy' pilots are there here? If they're insisting on 'hand flying' things, it is for the reason I noted earlier. Humans are very bad at sitting and WATCHING and maintaining their concentration so that they can catch things if the automation should fail. :But, like you, I know that it can :be done, and it is being done now. : : It's my understanding that F/A-18s can take off and land all by : themselves (and this from an aircraft carrier, which is a bit more : difficult than using one of those big concrete ribbons on solid : ground). I gather that the automated cat sequence is used but the : automated trap sequence is typically not. Fighter pilots are not a : particularly trusting lot... :-) : :It's good to be cautious. I didn't know that the aircraft could do that, but :it's interesting to learn. Somehow I'd expect fighters to be the last :aircraft to fully automate ... although it's also true that the weakest :component in a fighter aircraft is the pilot (because the performance of the :aircraft has to be limited in order to keep the pilot alive). Listen to in cockpit tapes of the Blue Angels sometime. You'll hear the pilot go "Hit it!" and then in the background you'll hear "Bitchin' Betty" going "Caution ... caution ... caution ... " as they perform some maneuver too close to the ground or that exceeds the usual flight standards. -- "Insisting on perfect safety is for people who don't have the balls to live in the real world." -- Mary Shafer, NASA Dryden |
But every aircraft doesn't have to carry it. You handle it the way the disparity in equipment between big airliners and little general aviation aircraft is handled now. With human beings, you mean. But the whole idea in this case is presumably to eliminate the need for human beings, providing some sort of 100%-reliable automatic separation of traffic. But you know whose fault they are. If they don't have the appropriate equipment, they are required to operate VFR. You could go further and ban them from certain TCAs. Only the latter would work. If you want a fully reliable system, everyone in the airspace using it has to have the equipment. If people want to fly without the gear, they'll have to be segregated into different airspaces. That is done to some extent now, but it would have to be vastly more strict as separation becomes more and more automated. Right now, ATC can fill in the gaps, but if the objective is to eliminate the need for ATC (at least for purposes of separation), that sets the bar a lot higher. You wouldn't have to do either, any more than you have to require everyone to have collision avoidance radars and such now. Right now you have ATC to provide separation. Why? Because any airspace using the new technology would have to be forbidden to anyone who isn't equipped to use it, which would squeeze out a lot of GA traffic. And even if everyone doesn't. Just like things work fine now when everyone doesn't have all the gear. They work fine now because human beings fill in the gaps from the ground. Even then, there are sometimes incidents. They're a hell of a lot more fragile than the rest of the technology in the cockpit. I suppose it depends on how you define fragility. Human beings are self-contained systems and highly versatile. Technology can fail because of a single capacitor, but a human being with a broken arm might still be able to land safely. Humans tend to fail catastrophically when confronted with anything that the designers of their training did not foresee. They may fail, but not usually castrophically. If a human being has not been trained to limit bank angles to x degrees, he still won't invert the aircraft, because he can inductively reason that inverted flight is a bad thing, even without training. A computer, on the other hand, with no understanding of what is "reasonable" or not, would cheerfully roll the aircraft until it is inverted, if it isn't programmed in advance to stop at some point. Yes, if you assume that the folks setting up the automated system are idiots you can assume all sorts of things. The designers don't have to be idiots, they only have to be imperfect (and they are). Experience right now indicates that human beings make really lousy fail-safes for automated systems. They are still preferable to letting the automated systems fail unattended. Just how much of the air traffic currently up there do you think is NOT being flown by automated systems? Most of the smaller GA traffic. Anyway, these automated systems are operating within their design envelopes, so they work very well. They only fail (usually catastrophically) when they are pushed outside the design envelope, which can happen in emergencies. How many 'heavy' pilots are there here? Very few, I think, but of course it's impossible to know for sure on USENET. Many of them appear to have no clue concerning heavies, so I presume they are not pilots of large airliners. Listen to in cockpit tapes of the Blue Angels sometime. You'll hear the pilot go "Hit it!" and then in the background you'll hear "Bitchin' Betty" going "Caution ... caution ... caution ... " as they perform some maneuver too close to the ground or that exceeds the usual flight standards. But in that case they are obviously flying the aircraft by hand. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: Fred J. McCall writes: But every aircraft doesn't have to carry it. You handle it the way the disparity in equipment between big airliners and little general aviation aircraft is handled now. With human beings, you mean. But the whole idea in this case is presumably to eliminate the need for human beings, providing some sort of 100%-reliable automatic separation of traffic. But you know whose fault they are. If they don't have the appropriate equipment, they are required to operate VFR. You could go further and ban them from certain TCAs. Only the latter would work. If you want a fully reliable system, everyone in the airspace using it has to have the equipment. If people want to fly without the gear, they'll have to be segregated into different airspaces. That is done to some extent now, but it would have to be vastly more strict as separation becomes more and more automated. Right now, ATC can fill in the gaps, but if the objective is to eliminate the need for ATC (at least for purposes of separation), that sets the bar a lot higher. You wouldn't have to do either, any more than you have to require everyone to have collision avoidance radars and such now. Right now you have ATC to provide separation. Why? Because any airspace using the new technology would have to be forbidden to anyone who isn't equipped to use it, which would squeeze out a lot of GA traffic. And even if everyone doesn't. Just like things work fine now when everyone doesn't have all the gear. They work fine now because human beings fill in the gaps from the ground. Even then, there are sometimes incidents. They're a hell of a lot more fragile than the rest of the technology in the cockpit. I suppose it depends on how you define fragility. Human beings are self-contained systems and highly versatile. Technology can fail because of a single capacitor, but a human being with a broken arm might still be able to land safely. Humans tend to fail catastrophically when confronted with anything that the designers of their training did not foresee. They may fail, but not usually castrophically. If a human being has not been trained to limit bank angles to x degrees, he still won't invert the aircraft, because he can inductively reason that inverted flight is a bad thing, even without training. A computer, on the other hand, with no understanding of what is "reasonable" or not, would cheerfully roll the aircraft until it is inverted, if it isn't programmed in advance to stop at some point. Yes, if you assume that the folks setting up the automated system are idiots you can assume all sorts of things. The designers don't have to be idiots, they only have to be imperfect (and they are). Experience right now indicates that human beings make really lousy fail-safes for automated systems. They are still preferable to letting the automated systems fail unattended. Just how much of the air traffic currently up there do you think is NOT being flown by automated systems? Most of the smaller GA traffic. Anyway, these automated systems are operating within their design envelopes, so they work very well. They only fail (usually catastrophically) when they are pushed outside the design envelope, which can happen in emergencies. How many 'heavy' pilots are there here? Very few, I think, but of course it's impossible to know for sure on USENET. Many of them appear to have no clue concerning heavies, so I presume they are not pilots of large airliners. And the ones that are you ignore. Fjukktard Bertie |
MEDICAL CERTIFICATION FOR UNMANNED AIRCRAFT PILOTS | Mike[_7_] | Naval Aviation | 1 | March 30th 07 04:23 AM |
Which aircraft certification is required for R&D? | Netgeek | Home Built | 5 | November 23rd 04 05:59 AM |
Aircraft certification questions. | psyshrike | Home Built | 40 | November 22nd 04 06:10 PM |
Aircraft certification questions. | psyshrike | Owning | 42 | November 22nd 04 06:10 PM |
certification of composite aircraft | sebastian | Home Built | 6 | March 25th 04 03:48 PM |
