#101
L'acrobat wrote:
I hate to disagree, but it is my understanding that F-111s were tasked to strike Indonesian C3I targets if the E.Timor op had been seriously opposed by the Indon Military. There were reports of this but we won't know officially until 2029 when the papers are released by the National Archives. In a speech in 2000, General Cosgrove said that we came "dangerously close" to a shooting war with Indonesia but he didn't elaborate. Subsequent media reports were hard to either prove or disprove. There was speculation that the TNI, which was totally opposed to giving up East Timor, might not behave and it was not inconceivable that elements might resist the INTERFET deployment, and perhaps even stage a coup. F-111s and extra F/A-18s were forward deployed to Tindal in the lead up to the INTERFET deployment (plenty of TV footage at the time). Indonesia claimed that RF-111s conducted overflights of East Timor and made a very public threat to shoot down any "spy planes" entering Indonesian airspace. F/A-18s started carrying white missiles the day that threat was made. It is known that Indonesian F-16s, F-5s and A-4s were airborne the night the ships sailed from Darwin, and reportedly made probing moves towards the group. There were also some missile boats out of Kupang. The Type 209 subs was in the Timor Sea (but there were also two Collins subs around, and RAAF and RNZAF Orions, so they weren't a real problem). What's not known is exactly how close we came. One media report later said that F-111s were "bombed up" ready to "knock out Indonesian communications as far back as TNI headquarters on the outskirts of Jakarta if necessary". Another report said that the commander of the naval taskforce came within less than a minute of giving the order to fire on Indonesia aircraft. How much of this is fact won't be known until 2029. It's not difficult to work out that if the TNI had gone off the rails then things could have got very ugly very quickly. While INTERFET wasn't militarily or politically in a position to make an opposed landing, the aircraft in theatre would at least have been in a position to cover the taskforce as it retreated to Darwin. Cheers David |
#102
"Defender in Tas" wrote in message
om... Let me guess, ex-army? No, but hardly relevant. It is actually. Seeing as you take a pro-army/tanks stance at the expense of strategic common-sense. My pro-army, pro-tanks stance is not at the expense of strategic commonsense (no hyphen), nor is at the expense of the RAAF or RAN. I would like it to be at the expense of the enormous, and growing, social welfare budget, but that's another issue. I believe the defence budget should be dramatically increased. And I also believe a balance in capabilities must be maintained, with due regard to the likely threats and contingencies that our forces must face. It's incredibly misleading for you to suggest that my support for the probable retirement of the F-111 around 2006 is linked to my support for acquiring new tanks. I apologised for giving the false impression that I favoured using the $300 million (a conservative estimate as some are now reporting it to be $500m) to be saved from retiring the Pigs on raising two new infantry battalions. Personally, I believe the number of infantry battalions at present is adequate. I was quite clear in stating my views on what we should be doing regarding our air combat capabilities. I don't claim to know a whole lot. Then you should try asking questions instead of making statements. Oh, so you're the local expert? Some might say that. The ADA are reasonably knowledgeable. But they sometimes fill in the blanks with opinions that aren't factually correct. You're saying you're more knowledgeable than the ADA? Ummm, yep. I believe - stated that it was for this very reason, perhaps amongst others. So why weren't they sent according to you? Its not "according to me", and its none of your business. The reason the F-111s were not sent to the Gulf was because "its none of your business". So not only are you an expert, you are also privy to information of the highest confidentiality? This is becoming very amusing. It is. For me. (And probably a few others who are lurking). Here's a question - what's the point having a good strike aircraft if the enemy has already knocked them out on the ground? With what? With SU-27s should 'they' acquire them, or whatever combat aircraft 'they' may possess. The F-111s have great range but it would be pure folly to say they would operate our of Amberley in any crisis centred around, say, East Timor, Irian Jaya, or Indonesia generally. Folly to you. and we've already determined that you're a bit thin on knowledge of this topic. Check a map. For operations in those areas, even the long-legged F-111s would need to be much closer than Amberley to be effective. Otherwise, you're looking at a much lower sortie rate, less time over target and a lower bomb load. They would be deployed - most likely - to Tindal, as some were during Interfet. That was to shorten response time, not because they didn't have the reach. They have the reach, but there's more reasons to it than response time. There, were you? Surely, Tindal would be within range of SU-27s operating out of Indonesian air bases, and possibly other combat aircraft, with or without AAR? I haven't got the data in front of me. So I can't say. It is. The F-111 scarcely has a defence - its EW equipment is non-existant Utter bull****. Ok, what's the truth? That the F111 has EW equipment and its getting more. Can you say "Echidna"? "Its getting more." (Should have been an apostrophe after the "t" but I'll let you off.) I have heard of Echidna, also aware that this has not yet transpired to any new equipment on these aircraft. A sure sign of a Usenet newbie is spelling flames. I suggest you lurk awhile longer and work out who is who in the zoo before you make a bigger goose of yourself. Ok, we have some Rapiers (to be retired), and RBS-70s, and Tindal is laid out with widely located protective aircraft shelters, but do our F-111 pilots train to launch on air-to-air missions? None of your business. Also, can you say "Hawk 127"? Actually, I just remembered that there was a public article about a Pig shooting down an F16 at Red Flag a few years ago. Make of it what you will. The Hawk 127 is primarily a trainer, with a secondary ground attack role. Its a "Lead In Fighter" ****tard. The PC9 is a "trainer". Riddle me this dickhead, why does the configuration of the Hawk 127 cockpit closely match that of the F/A-18, and why is the Hawk 127 capable of employing AIM9s? It would take some time to prepare either of the Hawk squadrons - or flights thereof - to deploy for active service. Yeah, about the same amount of time it would take the gunnies to pull some white Sidewinders out of J Group and attach 'em to the rails. Clown. I would imagine Yes, keep imagining........ lots. It fills the gaps in your knowledge. that in such a scenario every operational fighter squadron would already be in action. Throwing a lead-in fighter training squadron into the fray is a desperate move. As for the F-111 notionally shooting down an F-16 at Red Flag, I read that article, and I have to say it's always good to see an underdog get on top now and then. I support the Western Bulldogs in the AFL (feel free to laugh) and every now and then we get a win. Now and then just doesn't cut it. What was the F111B designed to do? What did the F14 end up doing? What is an AIM120? Can you add two and two? There would be no point having the F-111s take-off to defend the airbase Of course not. Your point? That the F-111 is a strike aircraft only, Its a strike aircraft *primarily*. Its also a bloody good Recon platform, but I guess you didn't know *that* either. not a multi-role fighter. Even though it was conceived as one. Yes, I was aware of it, partly because one of our RF-111Cs was used to spy on Tasmania during the dams dispute. I don't blame the RAAF for that disgraceful decision. Nor should you. It wasn't unlawful and it wasn't "spying on Tasmania"? Let's get one thing straight - the F-111 - as a strike and recon platform - will be a great loss. However, it is an unavoidable one due to the limited defence budget and need to maintain balanced defence capabilities. It's expense can not be justified. Its early retirement will be the expensive waste that cant be justified. Can you say AGM142? It was never conceived to be the latter, Yes it was. Can you say "TFX"? Or "F111B"? and that was fine. But in this day and age, with the current operational demands on the ADF and the limited defence budget, my contention is that the high (and growing) cost of this single capability cannot be justified for retention. But your contention is based on incomplete knowledge of the subject. Best you reconsider. It was never conceived to be a multirole fighter, at least as we view fighters in this category today. You can't have two bob each way, either it was, or it wasn't. And the fact is, it was. A carrier-borne interceptor was conceived but ultimately failed, losing out to the F-14. (I don't rate that aircraft as a multirole fighter, do you?) Obviously you don't know much about F14s either. The F-111 was selected for Australian service to replace the Canberra - a bomber. Thanks for the history lesson. I miss the old B20, the view from the Bombardier's possie had to be seen to be believed........ and the bang from the cartridge starts! What a noise! And it's air to air capabilities were never strong. Perhaps. But that doesn't mean they're non-existant. Especially with modern data-links and AIM120s. Multi-role fighters less-than-optimum strike aircraft make. True. But Australia with its current defence budget and given our likely threats and contingency demands, cannot afford such an expensive strike aircraft. And we can't afford to be stuck with a short-legged single donked fighter that can't haul bombs. Otherwise we will end up, literally, "defending" Australia instead of defending Australia and her interests. Of course, ideally, if the defence budget was at a level that would make me happy, I would like to see the F-111s retained, further upgraded and supported by AAR aircraft with booms, and the RAAF also operating at least 6, if not 8, operational squadrons of tactical fighters - perhaps half primarily for air-to-air (the F-15), and half primarily for battlefield air interdiction / CAS with a second role of air-to-air (the Hornets, or F-16s, or take your pick of a few others). But now I'm dreaming. F16's legs are too short. And they've only got one (semi-reliable) donk. True. In my "ideal" world force structure presented above I would favour the Hornet over the F-16, but a next generation fighter such as the Typhoon or the Rafale would also be a good choice. No they wouldn't. Come back when you've got a clue. -- De Oppresso Liber. |
#103
"Graham" wrote in message
... "Brash" wrote in message u... "David Bromage" wrote in message .. . The RAAF's 35 F-111 warplanes - Australia's front-line strategic strike force - could be retired from service from 2006, a decade earlier than originally planned, if the Government accepts a controversial option put forward by the Defence Department. A key issue is whether early retirement for the long-range F-111s could leave a gaping hole in Australia's front-line defences early next decade. http://www.theaustralian.news.com.au...6866971%255E60 1,00.html Bring on the leased F15E's. We've done it before. Would the new super hornet Suit? IMHO, a bit short in the legs. But a better option than Vipers. -- De Oppresso Liber. |
#104
.. . L'acrobat wrote: I hate to disagree, but it is my understanding that F-111s were tasked to strike Indonesian C3I targets if the E.Timor op had been seriously opposed by the Indon Military. There were reports of this but we won't know officially until 2029 when the papers are released by the National Archives. In a speech in 2000, General Cosgrove said that we came "dangerously close" to a shooting war with Indonesia but he didn't elaborate. Subsequent media reports were hard to either prove or disprove. There was speculation that the TNI, which was totally opposed to giving up East Timor, might not behave and it was not inconceivable that elements might resist the INTERFET deployment, and perhaps even stage a coup. F-111s and extra F/A-18s were forward deployed to Tindal in the lead up to the INTERFET deployment (plenty of TV footage at the time). Indonesia claimed that RF-111s conducted overflights of East Timor and made a very public threat to shoot down any "spy planes" entering Indonesian airspace. F/A-18s started carrying white missiles the day that threat was made. It is known that Indonesian F-16s, F-5s and A-4s were airborne the night the ships sailed from Darwin, and reportedly made probing moves towards the group. There were also some missile boats out of Kupang. The Type 209 subs was in the Timor Sea (but there were also two Collins subs around, and RAAF and RNZAF Orions, so they weren't a real problem). What's not known is exactly how close we came. One media report later said that F-111s were "bombed up" ready to "knock out Indonesian communications as far back as TNI headquarters on the outskirts of Jakarta if necessary". Another report said that the commander of the naval taskforce came within less than a minute of giving the order to fire on Indonesia aircraft. How much of this is fact won't be known until 2029. It's not difficult to work out that if the TNI had gone off the rails then things could have got very ugly very quickly. While INTERFET wasn't militarily or politically in a position to make an opposed landing, the aircraft in theatre would at least have been in a position to cover the taskforce as it retreated to Darwin. Cheers David As you say, its mostly speculation and rumour. One thing that I know for certain is that the inter-service rivalry in the TNI is so strong that I would be surprised if the TNI-AU (Air Force) would have gone into a shooting match at the behest of the TNI-AD (Army), against the orders of the government. It would have been a prime opportunity for the TNI-AU to curry favour with the powers-that-be in Jakarta and stick it to the TNI-AD. -- De Oppresso Liber. |
#105
![]() "Brash" wrote in message ... "Defender in Tas" wrote in message om... Let me guess, ex-army? No, but hardly relevant. It is actually. Seeing as you take a pro-army/tanks stance at the expense of strategic common-sense. My pro-army, pro-tanks stance is not at the expense of strategic commonsense (no hyphen), nor is at the expense of the RAAF or RAN. I would like it to be at the expense of the enormous, and growing, social welfare budget, but that's another issue. I believe the defence budget should be dramatically increased. And I also believe a balance in capabilities must be maintained, with due regard to the likely threats and contingencies that our forces must face. It's incredibly misleading for you to suggest that my support for the probable retirement of the F-111 around 2006 is linked to my support for acquiring new tanks. I apologised for giving the false impression that I favoured using the $300 million (a conservative estimate as some are now reporting it to be $500m) to be saved from retiring the Pigs on raising two new infantry battalions. Personally, I believe the number of infantry battalions at present is adequate. I was quite clear in stating my views on what we should be doing regarding our air combat capabilities. I don't claim to know a whole lot. Then you should try asking questions instead of making statements. Oh, so you're the local expert? Some might say that. Only you believe that gate guard, only you. 'Defender in Tas' may not know much on the subject,but at least he isn't a gate guard (in a service only slightly less military than Telstra) with delusions of grandeur. To you 'Defender in Tas', 'Brash' is an Airfield Defence Guard in the RAAF, the lowest of the low, they can't hack the hard yards in the Army and aren't smart enough to find a better job in the RAAF - but he is a laugh with his self important nonsense. |
#106
![]() "JD" wrote in message om... (Defender in Tas) wrote in message . com... Let me guess, ex-army? No, but hardly relevant. It is actually. Seeing as you take a pro-army/tanks stance at the expense of strategic common-sense. My pro-army, pro-tanks stance is not at the expense of strategic commonsense (no hyphen), nor is at the expense of the RAAF or RAN. I would like it to be at the expense of the enormous, and growing, social welfare budget, but that's another issue. I believe the defence budget should be dramatically increased. And I also believe a balance in capabilities must be maintained, with due regard to the likely threats and contingencies that our forces must face. It's incredibly misleading for you to suggest that my support for the probable retirement of the F-111 around 2006 is linked to my support for acquiring new tanks. I apologised for giving the false impression that I favoured using the $300 million (a conservative estimate as some are now reporting it to be $500m) to be saved from retiring the Pigs on raising two new infantry battalions. Personally, I believe the number of infantry battalions at present is adequate. I was quite clear in stating my views on what we should be doing regarding our air combat capabilities. My two cents; Spend more on the Navy and Air Force. Cut back the army. **** off the idea of tanks, bushmasters, APCs. Remove 1 Armd, 5/7 RAR, 8/12 Mdm Regt and associated support elements from the ORBAT. Move 3 RAR up to Enoggera. Buy ASLAVs, More choppers. Make all reservists infantry. Or accept that our army really isn't going to do anything, so just **** it off and let the Yanks have their base here. Hmmmmm -- you missed your vocation :-) but idea has merit and will help the balance of payments ;-) |
#107
![]() "JD" wrote in message om... My two cents; Spend more on the Navy and Air Force. Cut back the army. Realistically, in the current environment I think we should be spending rather more on ALL the services. This no doubt means an increased budget allocation which would reflect in increased taxes. The money has to come from somewhere, so it may be the only real option. We don't spend enough on defence in the current somewhat hostile environment. **** off the idea of tanks, bushmasters, APCs. It's difficult to envisage a local scenario that would benefit greatly from heavy armour. That said, since we have a somewhat capable (depite the length of it's teeth) MBT, I'd probably just stick with that. New Leopards might make the turret heads feel good but I don't presently believe it would significantly increase our defence capability. The M113's are getting *well* past their use-by dates. I think they need to go, give them to the reserves to train in, but they really need to be replaced by ASLAV ASAP. The Bushmaster seems to me to be a poor mans ASLAV, if we had more ASLAV you wouldn't need to bugger about with it. Remove 1 Armd, 5/7 RAR, 8/12 Mdm Regt and associated support elements from the ORBAT. Why throw them away? But a review of their role and positioning would seem to be essential. Move 3 RAR up to Enoggera. Yep. Buy ASLAVs, Yep. Lots of. It's a *big* country if you have to walk it. We need to improve our force mobility *significantly*. This *must* include the ability to *logistically* support a more highly mobile fielded force as well. This is an even bigger can of worms.. More choppers. Yes, and that should include a Cobra or Apache equivalent. But troopie and heavy lift stuff too. It's noted that the RAAF are considering *not* retiring the Caribou fleet for something newer, so "Wallaby Airlines" can fill *some* of the roles of the transport helo with only the most basic of prepared strips (though this becomes harder in the 'wet'.) But we *need* more helos too. Make all reservists infantry. I'd say make *most* of them infantry, a core of 'ready replacements' for more specialised roles is not without merit, this is essentially the role of the RAAF Reserve and Naval Reserve. Or accept that our army really isn't going to do anything, If it's done right, they *shouldn't* have a lot to do *here* but we can't assume that. It's likely that OS deployments are on the increase however and that will probably be largely infantry and special forces. so just **** it off and let the Yanks have their base here. Or keep it and let the Yanks have a base. The choices need not be mutually exclusive, however I doubt the Yanks really want or need a base here. If something flares up they could probably occupy one of the 'bare bones' bases fairly quickly without the cost and provocativeness of establishing a permanent presence. Just my 1c worth (I'm somewhat less qualified than others here) The CO |
#108
"Paul Krenske" wrote in message
On Sun, 10 Aug 2003 23:23:47 GMT, "Thomas Schoene" wrote: The F111's would be unable to self target apparently but would act as a "Arsenal Aircraft" for F18's. The F18's pass over the information through some sort of datalink to the missiles and the F111 drops em. Apparently quite similar to Malaysias idea to use 2 seat f-18s as controll birds for 4 ship flights of flankers. The new digital fire control and data systems theoretically allow it to happen, I do not personally believe it should be a starter though. Instead the F111's should be smashing the Airbases not running air superiority patrols. You'll pardon me if I'm still skeptical. That sort of engage-on-remote datalink is the sort of thing being planned for the F/A-22; I really doubt that it already exists in the F-111C. Do you have a source for this capability? I'm also skeptical about the Malaysian concept being significantly automated (even having shared datalink) -- mixing US and Russian systems like that is very hard. I could believe that the Hornets might serve as pathfinders or mini-AWACS, but they would almost certainly be limited to passing data via voice. The Flankers would have to acquire and engage their own targets, which is a very different prospect from what you describe for the F-111. Note the arsenal plane concept with RPV's is alive and well though. DARPA is seriously proposing some low performance patrol RPV's (mach 9 semi stealthy) with 4-8 AMRAAMs (or the ER follow on) running the patrol loops taking targeting information from manned fighters and possibly directly from AWAC's. Oh sure, I believe it's possible in the future. But you seem to be saying that this capability already exists now. If DARPA is playing wiht it in the US, that's because it's still very raw technology. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
#109
On Mon, 11 Aug 2003 13:19:07 +0800, Bernd Felsche
wrote: (Paul Krenske) writes: Note the arsenal plane concept with RPV's is alive and well though. DARPA is seriously proposing some low performance patrol RPV's (mach 9 semi stealthy) with 4-8 AMRAAMs (or the ER follow on) running the I don't think you can deliver any munitions reliably from mach 9 :-) Bugger, .9 and I am almost certain I typed the . as well. patrol loops taking targeting information from manned fighters and possibly directly from AWAC's. -- /"\ Bernd Felsche - Innovative Reckoning, Perth, Western Australia \ / ASCII ribbon campaign | I'm a .signature virus! X against HTML mail | Copy me into your ~/.signature / \ and postings | to help me spread! |
#110
![]() Brash wrote: "Defender in Tas" wrote in message om... ill. The Hawk 127 is primarily a trainer, with a secondary ground attack role. Its a "Lead In Fighter" ****tard. The PC9 is a "trainer". IIRC the RAF refers to them as a 'fast jet trainer'. Riddle me this dickhead, why does the configuration of the Hawk 127 cockpit closely match that of the F/A-18, and why is the Hawk 127 capable of employing AIM9s? Can't comment on the exact detail of that but basically simple. BAe can sell them innocently enough as 'trainers', whereas the customer knows their true potential. Nice selling feature. PB |
IFR Flight Plan question | Snowbird | Instrument Flight Rules | 5 | August 13th 04 12:55 AM |
NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 05:12 AM |
Canadian IFR/VFR Flight Plan | gwengler | Instrument Flight Rules | 4 | August 11th 04 03:55 AM |
IFR flight plan filing question | Tune2828 | Instrument Flight Rules | 2 | July 23rd 03 03:33 AM |
USA Defence Budget Realities | Stop SPAM! | Military Aviation | 17 | July 9th 03 02:11 AM |
