Altimeter Calibration Height
Old April 2nd 07, 09:23 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Altimeter Calibration Height
"Neil Gould" wrote in message
et...
Perhaps you misunderstood Jose's example, but I believe he's correct;
while an altimeter senses the pressure at the level of the insturment, it
*indicates* the calibration set by either the shop (e.g. compensating for
the altitude of the installation) or the pilot via the Kollsman window.
I understood it, I didn't say he was wrong.
Old April 3rd 07, 10:26 AM posted to rec.aviation.piloting
Neil Gould
Recently, Steven P. McNicoll posted:
et...
insturment, it *indicates* the calibration set by either the shop
(e.g. compensating for the altitude of the installation) or the
Perhaps I misunderstood your response.
Jose stated:
[...] An altimeter indicates whatever it is set to indicate.
and:
If you don't get an altimeter setting, you will (likely) set the
altimeter so that the hands indicate the airport elevation as
indicated on your charts, even though you and the instrument are a
hundred feet higher.
If you do get an altimeter setting, you'll set it for that. Then the
question becomes (since the altimeter doesn't know that it's in a
tall airplane) whether, at calibration in the shop, it was set to
indicate actual instrument altitude or to indicate something else
(like instrument altitude minus a hundred feet).
To which you replied:
In other words, an altimeter indicates altitude at the level of the
instrument itself.
How do you reconcile your comment against Jose's statements? Both
statements will only be true under a very limited set of circumstances
that I would think excludes "In other words...".
Neil
Old April 3rd 07, 11:49 AM posted to rec.aviation.piloting
Steven P. McNicoll
et...
et...
Jose stated:
and:
instrument itself.
You snipped part of Jose's message:
"Also, even if the static port and the instrument themselves are separated
in altitude, it would be the instrument altitude's pressure that is sensed,
since the "column of air" is connected, and ends at the instrument."
instrument itself.
Old April 3rd 07, 03:05 PM posted to rec.aviation.piloting
Jose
instrument itself.
No. Correctly it would be "In other words, an altimeter =senses=
=pressure= at the level of the instrument itself."
Sensing pressure and indicating altitude are two different things.
Jose
Get high on gasoline: fly an airplane.
Old April 3rd 07, 03:26 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Jose" wrote in message
t...
An altimeter senses pressure in order to indicate altitude.
Old April 3rd 07, 03:33 PM posted to rec.aviation.piloting
Jose
Now we're getting somewhere. The pressure is sensed based on the laws
of physics. The altitude is indicated based on calibration and Kollsman
setting.
Jose
Old April 3rd 07, 04:04 PM posted to rec.aviation.piloting
Maxwell
t...
Now we're getting somewhere. The pressure is sensed based on the laws of
setting.
Maybe I'm missing something here, but would it simplify to say:
That if you mount an altimeter at the 100' level of a 200' tower,
equiped it with a static tube 100' long,
that the altimeter will read the same regardless if end of the tube,
is stationed at the top or bottom of the tower.
Old April 3rd 07, 04:48 PM posted to rec.aviation.piloting
Steven P. McNicoll
t...
setting.
Correct.
Old April 4th 07, 12:20 AM posted to rec.aviation.piloting
Matt Whiting
setting.
Right and the altitude indicated has little to do with the altitude of
the instrument.
Matt
Old April 3rd 07, 04:31 PM posted to rec.aviation.piloting
Neil Gould
correct; while an altimeter senses the pressure at the level of the
Jose stated:
and:
the question becomes (since the altimeter doesn't know that it's
in a tall airplane) whether, at calibration in the shop, it was
set to indicate actual instrument altitude or to indicate
something else (like instrument altitude minus a hundred feet).
instrument itself.
circumstances that I would think excludes "In other words...".
separated in altitude, it would be the instrument altitude's pressure
that is sensed, since the "column of air" is connected, and ends at
the instrument."
That part was snipped because it didn't alter or directly address what an
altimeter indicates.
instrument itself.
I think the issue is with your use of the term "indicates altitude", which
should be "senses pressure". The altimeter "indicates" via the display
(dial or digital), and the display is adjustable both during
installation/calibration and by the pilot to adjust for atmospheric
pressure. Consider that when you tell a pilot that the "altimeter is
30.12", the pilot adjusts the _indicated altitude_ by setting the Kollsman
window to that _pressure setting_. We don't watch the Kollsman (the only
"indication" of "altitude" consistent with the controller's information)
when trying to land. ;-)
Neil
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
