Altimeter Calibration Height
Old April 3rd 07, 04:55 PM posted to rec.aviation.piloting
Steven P. McNicoll
Default Altimeter Calibration Height
"Neil Gould" wrote in message
et...
I think the issue is with your use of the term "indicates altitude", which
should be "senses pressure".
It's not an issue with me. Altimeters indicate altitude by sensing
pressure.
The altimeter "indicates" via the display
(dial or digital), and the display is adjustable both during
installation/calibration and by the pilot to adjust for atmospheric
pressure. Consider that when you tell a pilot that the "altimeter is
30.12", the pilot adjusts the _indicated altitude_ by setting the Kollsman
window to that _pressure setting_.
When you tell a pilot "altimeter 3012" the pilot simply adjusts the Kollsman
setting to 3012.
We don't watch the Kollsman (the only
"indication" of "altitude" consistent with the controller's information)
when trying to land. ;-)
Correct.
Old April 3rd 07, 06:42 PM posted to rec.aviation.piloting
Neil Gould
Recently, Steven P. McNicoll posted:
et...
which should be "senses pressure".
pressure.
Correct, however the "indication" (display) is not the *method* (sensing
pressure). So, your assertion: "In other words, an altimeter indicates
altitude at the level of the instrument itself." is only valid under a few
specific circumstances.
[...] Consider that when you tell a pilot that the "altimeter is
Kollsman window to that _pressure setting_.
Kollsman setting to 3012.
Do you see a difference between my statement and yours, other than the
decimal point?
Neil
Old April 3rd 07, 07:14 PM posted to rec.aviation.piloting
Steven P. McNicoll
t...
pressure).
Who said it was?
What would those few specific circumstances be?
decimal point?
Yes. You say the pilot adjusts the indicated altitude, I say he adjusts the
altimeter setting.
Old April 3rd 07, 07:37 PM posted to rec.aviation.piloting
Jose
pressure.
Yes, but there's a very important step in between, and that step is the
one that answers the original question.
Jose
Get high on gasoline: fly an airplane.
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
