Altimeter Calibration Height
Old April 2nd 07, 09:38 PM posted to rec.aviation.piloting
Don Tuite
Default Altimeter Calibration Height
Tangential question for Steven:
I think you work in a control tower. If you work in a center in a
building at ground level, pretend you work in a tower.
You have a barometer there that tells you the sea-level pressure at
the airport. (That is, what a pressure gauge would read if you dug a
hole down to sea level and read the pressure down there.) That's the
pressure you announce on ATIS.
When the barometer was calibrated, did the calibration take into
account the height of the control tower?
Don
Old April 2nd 07, 09:43 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Don Tuite" wrote in message
I presently work in a tower, I used to work in a center.
We don't have a barometer in the tower. We have an ASOS on the field,
that's the source of the altimeter setting we put on the ATIS.
Old April 2nd 07, 09:55 PM posted to rec.aviation.piloting
Newps
the airport.
Yes, every tower has one.
Some facilities use their ASOS some use their instrument in the tower.
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
