Recently, Steven P. McNicoll posted:
"Neil Gould" wrote in message et... I think the issue is with your use of the term "indicates altitude", which should be "senses pressure". It's not an issue with me. Altimeters indicate altitude by sensing pressure. Correct, however the "indication" (display) is not the *method* (sensing pressure). So, your assertion: "In other words, an altimeter indicates altitude at the level of the instrument itself." is only valid under a few specific circumstances. [...] Consider that when you tell a pilot that the "altimeter is 30.12", the pilot adjusts the _indicated altitude_ by setting the Kollsman window to that _pressure setting_. When you tell a pilot "altimeter 3012" the pilot simply adjusts the Kollsman setting to 3012. Do you see a difference between my statement and yours, other than the decimal point? Neil |
![]() "Neil Gould" wrote in message t... Correct, however the "indication" (display) is not the *method* (sensing pressure). Who said it was? So, your assertion: "In other words, an altimeter indicates altitude at the level of the instrument itself." is only valid under a few specific circumstances. What would those few specific circumstances be? Do you see a difference between my statement and yours, other than the decimal point? Yes. You say the pilot adjusts the indicated altitude, I say he adjusts the altimeter setting. |
"Neil Gould" wrote in message t... Correct, however the "indication" (display) is not the *method* (sensing pressure). Who said it was? You do when you imply that there is a necessary agreement between what the altimeter senses and what it displays. So, your assertion: "In other words, an altimeter indicates altitude at the level of the instrument itself." is only valid under a few specific circumstances. What would those few specific circumstances be? Jose listed them in response to an earlier post of yours. Do you see a difference between my statement and yours, other than the decimal point? Yes. You say the pilot adjusts the indicated altitude, I say he adjusts the altimeter setting. You actually said, "When you tell a pilot "altimeter 3012" the pilot simply adjusts the *Kollsman setting* to 3012." (emphasis mine). As we described the same action, this distinction is without a functional difference. Neil |
![]() "Neil Gould" wrote in message t... You do when you imply that there is a necessary agreement between what the altimeter senses and what it displays. What implied that? Jose listed them in response to an earlier post of yours. I must have missed that one. You actually said, "When you tell a pilot "altimeter 3012" the pilot simply adjusts the *Kollsman setting* to 3012." (emphasis mine). As we described the same action, this distinction is without a functional difference. I think there's a significant functional difference between adjusting the altimeter setting and adjusting the indicated altitude. |
"Neil Gould" wrote in message t... You do when you imply that there is a necessary agreement between what the altimeter senses and what it displays. What implied that? On 4/2/07, you wrote: "An altimeter indicates altitude at the level of the instrument itself. " and, again: "In other words, an altimeter indicates altitude at the level of the instrument itself. " And so forth. That is not necessarily so. You actually said, "When you tell a pilot "altimeter 3012" the pilot simply adjusts the *Kollsman setting* to 3012." (emphasis mine). As we described the same action, this distinction is without a functional difference. I think there's a significant functional difference between adjusting the altimeter setting and adjusting the indicated altitude. Well, I wrote: "Consider that when you tell a pilot that the "altimeter is 30.12", the pilot adjusts the indicated altitude by setting the Kollsman window to that pressure setting." The "adjustment" in both cases is to the Kollsman setting. The result is a change in the displayed altitude. So, what is different is the structure of the sentence, not the action or intent, unless you think your omission of the resulting displayed altitude is significant. If so, why do you think so? Neil |
![]() "Neil Gould" wrote in message . net... On 4/2/07, you wrote: "An altimeter indicates altitude at the level of the instrument itself. " and, again: "In other words, an altimeter indicates altitude at the level of the instrument itself. " And so forth. That is not necessarily so. Why not? |
"Neil Gould" wrote in message . net... On 4/2/07, you wrote: "An altimeter indicates altitude at the level of the instrument itself. " and, again: "In other words, an altimeter indicates altitude at the level of the instrument itself. " And so forth. That is not necessarily so. Why not? After puzzling the difficulties that several of us have had in trying to explain the differences between "indicated" (e.g. what the pilot sees) -- and "senses" (how the altimeter is calibrated), I can only guess that for you, sitting in the tower, there is no practical difference because you are always at the same altitude. ;-) You can review some of the excellent explanations that Jose and others have provided to answer your question. The original question asked whether the altimeter is set to indicate the altitude at the wheels or "at the level...", and if that question has been definitively answered, I missed it. Neil |
Deck height | Sean Trost | Home Built | 5 | July 16th 04 03:46 AM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
