Altimeter Calibration Height
Old April 4th 07, 12:20 AM posted to rec.aviation.piloting
Matt Whiting
Default Altimeter Calibration Height
Jose wrote:
An altimeter senses pressure in order to indicate altitude.
Now we're getting somewhere. The pressure is sensed based on the laws
of physics. The altitude is indicated based on calibration and Kollsman
setting.
Right and the altitude indicated has little to do with the altitude of
the instrument.
Matt
Old April 4th 07, 03:26 PM posted to rec.aviation.piloting
Jose
Right and the altitude indicated has little to do with the altitude of the instrument.
Well, that's a little extreme. They are related like integrals to the
same function: +C
Jose
Get high on gasoline: fly an airplane.
Old April 4th 07, 05:49 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Matt Whiting" wrote in message
news
instrument.
Right. That's why changing the altitude of the instrument, as is done by
climbing or descending, has so little effect on the indicated altitude.
Old April 4th 07, 11:11 PM posted to rec.aviation.piloting
Matt Whiting
news
instrument.
I can just as easily change the Kollsman setting and change the
indicated altitude without changing the altitude of the instrument at
all. Or I can wait for the ambient pressure to change and watch the
indicated altitude change without moving the instrument. Thus the
instrument doesn't indicate the altitude of itself, it indicates the
pressure it is experiencing.
If the altimeter truly indicated the altitude of the instrument, then it
would only change when the altitude of the instrument changed. Since
that isn't the case, it follows logically that the altimeter isn't
indicating its own altitude, but rather something else ... pressure.
You can write whatever on the dial you want to, that doesn't change what
is being indicated. I could write 10 oranges, 20 oranges, 30 oranges,
etc, around my speedometer, but that doesn't make my speedometer
indicate oranges.
Matt
Old April 4th 07, 11:43 PM posted to rec.aviation.piloting
Jose
Thus the instrument doesn't indicate the altitude of itself, it indicates the pressure it is experiencing.
No, it indicates the altitude (in feet, for example). It just does so
incorrectly.
Jose
Old April 6th 07, 12:40 PM posted to rec.aviation.piloting
Steven P. McNicoll
news
the instrument.
I can just as easily change the Kollsman setting and change the indicated
altitude without changing the altitude of the instrument at all. Or I can
wait for the ambient pressure to change and watch the indicated altitude
change without moving the instrument. Thus the instrument doesn't
experiencing.
Do you have a webcam? I'd like to see you typing with your foot in your
mouth.
Deck height Sean Trost Home Built 5 July 16th 04 03:46 AM
Volkslogger Calibration Ray Lovinggood Soaring 5 September 13th 03 04:56 PM
Height records? Paul Repacholi Soaring 2 September 7th 03 03:14 PM
Cloud Height Indicator Bob Bristow Home Built 0 August 11th 03 07:42 AM
Seat height problem Slav Inger Piloting 7 July 22nd 03 02:31 PM
