"Neil Gould" wrote:
The original question asked whether the altimeter is set to indicate the altitude at the wheels or "at the level...", and if that question has been definitively answered, I missed it. Assuming an aircraft of large vertical dimension... If the point of an altimeter is to directly display to the pilot how far the lowest point on the aircraft is above surface obstructions (or wheels above a runway), then I would presume the altimeter would be calibrated so that when the aircraft rests on the ground it reads the same altitude as that ground level. If the point of an altimeter is to directly display to the pilot the altitude to fly so that the aircraft is as far as possible from other aircraft also obeying 91.159, then I would presume the altimeter would be calibrated so that when the aircraft rests on the ground it reads the same altitude as the ground level plus half the height of the aircraft. And so on for other uses (e.g. keeping the distance of the top of aircraft safely below a cloud ceiling of known altitude). |
the lowest point on the aircraft is above surface obstructions (or wheels above a runway), then I would presume the altimeter would be calibrated so that when the aircraft rests on the ground it reads the same altitude as that ground level. If there's much of a flare, the pilot might be surprised. ![]() Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
The accuracy of the displayed altitude is such that neither of these can be
depended on. In other words, it doesn't really matter because we are not juding flare by indicated altitude nor are we using it to vertically separate planes by merely a few hundred feet. But, I would love to hear from a pilot of a big plane on what occurs when they set the altimeter based on field elevation rather than by barametric pressure. From the lack of better information, I am presuming that there is a noticable difference in the indicated altitude. -- ------------------------------- Travis Lake N3094P PWK "Jim Logajan" wrote in message .. . "Neil Gould" wrote: The original question asked whether the altimeter is set to indicate the altitude at the wheels or "at the level...", and if that question has been definitively answered, I missed it. Assuming an aircraft of large vertical dimension... If the point of an altimeter is to directly display to the pilot how far the lowest point on the aircraft is above surface obstructions (or wheels above a runway), then I would presume the altimeter would be calibrated so that when the aircraft rests on the ground it reads the same altitude as that ground level. If the point of an altimeter is to directly display to the pilot the altitude to fly so that the aircraft is as far as possible from other aircraft also obeying 91.159, then I would presume the altimeter would be calibrated so that when the aircraft rests on the ground it reads the same altitude as the ground level plus half the height of the aircraft. And so on for other uses (e.g. keeping the distance of the top of aircraft safely below a cloud ceiling of known altitude). |
![]() "Jim Logajan" wrote in message .. . Assuming an aircraft of large vertical dimension... If the point of an altimeter is to directly display to the pilot how far the lowest point on the aircraft is above surface obstructions (or wheels above a runway), then I would presume the altimeter would be calibrated so that when the aircraft rests on the ground it reads the same altitude as that ground level. If that was the aim the altimeter would have to be calibrated to read the same altitude as ground level when the aircraft was in a pre-touchdown nose high attitude. |
Deck height | Sean Trost | Home Built | 5 | July 16th 04 03:46 AM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
