Why The Hell... (random rant)
Old April 5th 07, 12:08 AM posted to rec.aviation.student,rec.aviation.piloting
Tim
Default Why The Hell... (random rant)
Mxsmanic wrote:
writes:
A sensor to find true north in an airplane in flight doesn't exist.
GPS finds true north. And, just incidentally, you can find true north by
looking at the sky. ANS will do that, and people can do it, too.
Not all planes have GPSes. In fact, most don't. Many of the haldheld
units fail. The failure rate for compasses is quite low. The FAA is
not likely to revise its requorements for a compass any time soon.
Thus, the reliance on magnetic north.
The isogonic lines on a chart take care of all the problems of where
the actual north/south magnetic poles are.
Documenting them doesn't really eliminate them.
Wrong again, bucko, there is nothing better for finding north in an
airplane in flight.
GPS is better, and more accurate, to name just one.
Not really. It is unreliable. Its signals can be disrupted - rendering
them useless. I don;t want my only source of reference taken away at
anyone's whim.
The only ways to find true north are celestial navigation and a true
gyro compass.
You can find true north by looking at the sky, or with GPS, or with ANS
(automated looking at the sky), or with an INS. The latter usually has to be
on the ground, although some systems support align-in-motion with a longer
setup time.
Not likely in most GA planes on most flights. Usually one is busy
flying and has no time for that stuff. Not possible on cloudy days.
You can't use celestial navigation unless you have a clear sky, an
almanac, a precise clock, and the necessary instruments to measure
celestial angles and the training to be able to use it all.
You need a precise clock to do just about any navigation. The need for the
rest is debatable, depending on how resourceful you are.
GPS could be used to indirectly find either type of north, but it
doesn't work without power, which is an important concideration
when flying a real airplane without a pause button.
Unless the airplane is a glider, you have power.
Bull****. Can you say piper cub (to name one counter example)
There is no need for electric power in a plane.
Inertial navigation requires an initial set up against something
else, constant updating measured in minutes, and again, power.
One third correct: it requires power, but engines provide power. It doesn't
have to be set up against anything else to find true north. It doesn't need
to be constantly updated; the whole idea is to be fairly autonomous.
Not in the real world. On a computer maybe...
compass is still the best, most reliable way to find north. (true or
magnetic)
  #62
Old April 5th 07, 12:24 AM posted to rec.aviation.piloting
Kev
On Apr 4, 5:57 pm, "flynrider via AviationKB.com" u32749@uwe wrote:
I was reading Lindbergh's book about his transatlantic flight and at one
point, both his whiskey compass and Earth Inductor Compass were just wobbling
around uselessly. Eventually, they both started working again on their own,
but he was guessing at his heading for nearly an hour.
I can relate. I have a video that I took on a cross country flight, of my
mag compass doing rapid 360s. It lasted about 5 min. and there were no
magnetic anomolies listed on the chart in that area. There were also no UFO
sightings reported that day :-))
There are lots of old iron mines around my area, and pilots sometimes
comment about their compasses going screwy for a minute or so
(assuming they noticed at all). The early settlers thought the woods
were haunted at first because of this effect... until they figured out
it meant money ;-)
Kev
  #63
Old April 5th 07, 01:11 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Tim writes:
That depends on what category of aircraft you're looking at.
Many of the haldheld units fail.
How many? I've never seen one fail, although I'm sure it happens
occasionally. They don't even have any moving parts.
So is their accuracy, even when they are functioning perfectly.
them useless.
Magnetic bearings are constantly disrupted, everywhere on Earth.
anyone's whim.
But a compass cannot give you the information that a GPS gives you. It can
hardly tell you anything at all.
You have an engine turning. That's power. And it can fail, just like
electrical power.
Even in the real world. The purpose of INS is to have a way of navigating
without any external references; it's a very advanced and accurate
implementation of dead reckoning.
It's useless for truth north unless you have a chart _and_ you know where you
are. Even for magnetic north, it can be substantially off. And just knowing
which way is north doesn't help you much, anyway.
  #64
Old April 5th 07, 01:29 AM posted to rec.aviation.student,rec.aviation.piloting
Peter Dohm
Anyone out there who (honestly) uses only his mag compass as his
primary navigation equipment, let's hear from you. And using the
whiskey compass to set the DG doesn't count - we're talking navigation
by charted heading and mag compass. Tried rolling out on and holding
an accurate heading using only your whiskey compass lately? Fun,
isn't it...That's why they invented the DG.
Yes, but we're talking about using magnetic course as the main
navigation theme. Setting the DG from the whiskey is just a part of
that overall theme.
Bottom line, if the mag compass was demoted to emergency heading
reference, we could accept the mag var problem and use true heading
for day to day use. Heck, most whiskey compasses swing as much as the
local variation inflight, anyway!
The arguments presented in this thread for using True North are
actually starting to override my own sense of historical inertia.
Your comment above is icing on the cake. Very interesting
discussion. Especially since, as you pointed out, it's just a math
problem, not a radical change.
Kev
I agree with the first part of your statement, that the whiskey compass is
well suited as the on board reference and cross check for other instruments.
That's actually the point I was trying to make, but I didn't carry the
logical argument far enough.
Hopefully, I will only ever have to use the whiskey compass alone as a
navigation aid for pilotage in VMC. If however, after I resume flying, I am
ever caught in IMC with only a whiskey compass; I hope that I can recall the
advice of one of the instructors here, possibly Mr. Campbell, on an earlier
thread--that the whiskey compass is least unstable when heading or turning
to the south when in the northern hemisphere.
Peter
  #65
Old April 5th 07, 02:11 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Nomen Nescio writes:
The category that has wings and goes up in the sky.
You mean like a 747-400? It has two GPS receivers, three IRUs, two VORs and
two ADFs. One rarely falls back upon the magnetic compass.
  #67
Old April 5th 07, 03:05 AM posted to rec.aviation.student,rec.aviation.piloting
In rec.aviation.piloting Mxsmanic wrote:
writes:
Utter nonsense; you have no clue.
It doesn't matter, you go by the chart.
airplane in flight.
gyro compass.
setup time.
Jim Pennino
Remove .spam.sux to reply.
  #69
Old April 5th 07, 03:21 AM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
writes:
So you need a chart, which means that a compass alone isn't much use.
RANT! wise purchaser Owning 2 March 27th 07 10:04 PM
Random thoughts 2 Bill Daniels Soaring 6 September 1st 06 05:37 AM
A Jeppesen rant Peter R. Piloting 4 January 17th 05 03:54 AM
Why didn't GWB [insert rant] Jack Military Aviation 1 July 15th 04 11:30 PM
Random Hold Generator... Tina Marie Instrument Flight Rules 0 November 5th 03 04:21 PM
