In other words, an altimeter indicates altitude at the level of the
instrument itself. That seems reasonable. But what if the instrument itself is 100 ft tall? Or maybe just 30 inches tall? Which point on the altimeter should one pick and why? To answer that question, one must understand that an altimeter does not sense altitude, it senses pressure. The pressure would be some sort of average over the entire height of the sensing surface, whose exact value would depend on the construction of the device. That pressure would likely be equal to the ambient pressure at some altitude within that range. By painting appropriate numbers next to the pointer, one could get the altimeter to indicate altitude. It is the choice of numbers that is the issue, as that is arbitrary, and not subject to the laws of physics, only to the laws of the FAA. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
Deck height | Sean Trost | Home Built | 5 | July 16th 04 03:46 AM |
Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 04:56 PM |
Height records? | Paul Repacholi | Soaring | 2 | September 7th 03 03:14 PM |
Cloud Height Indicator | Bob Bristow | Home Built | 0 | August 11th 03 07:42 AM |
Seat height problem | Slav Inger | Piloting | 7 | July 22nd 03 02:31 PM |
