#241
![]() "Mxsmanic" wrote .. Snowbird writes: That's your opinion then. I can speak from my own experience, I've been in that situation a few times and the magnetic compass has been a great help. In a jet airliner? (That was the aircraft being discussed.) I see no reference to jet airliners in the OP's post. On the contrary, since he referred to his own flightplanning, that likely implies he flies a light aircraft. An airliner pilot would presumably have the airline's planning department do these chores for him. I'll grant that it would be okay in a tiny aircraft with just you as passenger. It would be as bad as nothing at all in the case of a large airliner with hundreds of people aboard. Your opinion again. That airliner captain would have training and experience in using a magnetic compass, so it certainly would be better than nothing to him. Of course without training and practical experience in using the magnetic compass, its value is limited. But using it happens to be included in the pilot's license curriculum, and for a reason. How often do pilots practice flying with just a compass once they've obtained their licenses? There are such things as proficiency check flights, where the examiner may choose to test the pilot's knowledge on that subject. Pilots obviously want to pass the checkride. Anyway, it's not a particularly difficult skill. |
#242
Snowbird writes:
I see no reference to jet airliners in the OP's post. It was in the posts preceding mine. Your opinion again. That airliner captain would have training and experience in using a magnetic compass, so it certainly would be better than nothing to him. It's better than nothing in the sense that hitting dirt is better than hitting concrete. There are such things as proficiency check flights, where the examiner may choose to test the pilot's knowledge on that subject. Pilots obviously want to pass the checkride. Anyway, it's not a particularly difficult skill. Okay, how many private pilots are compelled to demonstrate flying with just a compass alone for proficiency check flights? And how realistic is such a demonstration; that is, how often are pilots actually in this type of situation in real life? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#243
![]() "Mxsmanic" wrote Snowbird writes: Interestingly, over there he was opposed to new technology and was heavily against the then-new digital cameras, while here he advocates total reliance on electronic digital systems in aircraft. No, I do not. If you examine my posts here, you'll find that I'm opposed to extremes. I'm opposed to relying entirely on systems such as GPS or computerized glass cockpits, and I'm also opposed to the romantic notion that somehow a mere compass is going to get you out of trouble if more complex instrumentation fails. We obviously disagree on what is "extreme". The proposals regarding autoland and pure simulator-based training strike me as highly extreme. In other words, moderation is best in all things. You cannot fly safely with just a compass. You also run a risk of flying unsafely if you rely entirely on a fancy navigation system that is not proven 100% reliable, such as GPS. Your opinion. Aviation authorities accept compass and chart as sufficient for VFR navigation. They also require it as mandatory. To stay safe, you must recognize that anything can fail--and you must also recognize that something as crude as a compass is really no more useful than nothing at all, so you must not assume that having a compass makes you any safer. The magnetic compass is included in the minimum equipment list of any aircraft I know, so obviously authorities disagree with that opinion. A corollary of this is that you must always verify that everything in your aircraft is working. If you think you can get by with malfunctioning equipment, then you don't need that equipment to begin with. If you normally need it and it is malfunctioning and you choose to fly anyway, you may never come back. The first sentence is incorrect, while I agree with the second and third sentence. What you must do is check if the equipment required for the mission at hand is in working order, per the minimum equipment list. You may take off with some malfunctioning equipment, as long as it does not jeopardize the safety of the mission. Regarding the magnetic compass, note that its usefulness is not limited to those "catastrophic blackout" emergency-landing scenarios that some of the posts here suggest. It may be simpler events such as an in-flight restart of the FMS, or a handheld GPS falling on the floor in a small aircraft. In such cases the magnetic compass helps against straying off course until the problem is fixed. |
#244
![]() "Mxsmanic" wrote .. Your opinion again. That airliner captain would have training and experience in using a magnetic compass, so it certainly would be better than nothing to him. It's better than nothing Good, we're making some progress. in the sense that hitting dirt is better than hitting concrete. I don't find that comparison universally valid, so I have to disregard it. For example, if you have to make a gear-up landing, you are advised to do it on concrete rather than grass (or dirt). That's what the literature says anyway. |
#245
Snowbird writes:
I don't find that comparison universally valid, so I have to disregard it. For example, if you have to make a gear-up landing, you are advised to do it on concrete rather than grass (or dirt). That's what the literature says anyway. But both are considered accidents, as opposed to a normal landing with gear, which is not an accident. Thus, while a landing on one surface may do less damage than a landing on another surface, that is not a huge consolation to the pilot who has to land without gear. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#246
"Mxsmanic" wrote
Okay, how many private pilots are compelled to demonstrate flying with just a compass alone for proficiency check flights? And how realistic is such a demonstration; that is, how often are pilots actually in this type of situation in real life? Just about any decent instrument BFR or IPC is going to involve a loss of the DG or HSI in IMC. BDS |
#247
Snowbird writes:
We obviously disagree on what is "extreme". The proposals regarding autoland and pure simulator-based training strike me as highly extreme. They aren't, though. Most training for airline pilots today takes place in simulators, so pure simulator-based training is only one small step away from the current practice. And landing with autoland is much easier than commonly believed--that's the whole idea. It's certainly easy enough that anyone could do it by carrying out instructions given by someone else. This is not the case with hand-flying, which requires a certain amount of practice irrespective of any instruction provided by others. Your opinion. Aviation authorities accept compass and chart as sufficient for VFR navigation. They also require it as mandatory. I don't judge safety on the basis of what others say. I have a much higher standard. The magnetic compass is included in the minimum equipment list of any aircraft I know, so obviously authorities disagree with that opinion. Or they simply haven't bothered to change the regulations, and have little motivation to do so. The first sentence is incorrect, while I agree with the second and third sentence. What you must do is check if the equipment required for the mission at hand is in working order, per the minimum equipment list. You may take off with some malfunctioning equipment, as long as it does not jeopardize the safety of the mission. I suppose if you consider malfunctioning avionics to be acceptable, you can take off with that. I wouldn't. I know that even airlines are careless in this way. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#248
BDS writes:
Just about any decent instrument BFR or IPC is going to involve a loss of the DG or HSI in IMC. But those are only a few of many instruments. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#249
![]() "Mxsmanic" wrote I don't judge safety on the basis of what others say. I have a much higher standard. Please elaborate what that higher standard is and how you claim to achieve it. As a minimum, I will expect you never to have broken anything on those simulated planes you fly. |
#250
Snowbird writes:
Please elaborate what that higher standard is and how you claim to achieve it. I've already explained it. I want all instruments to work, not just those on the MEL. As a minimum, I will expect you never to have broken anything on those simulated planes you fly. That minimum is satisfied. -- Transpose mxsmanic and gmail to reach me by e-mail. |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
