On 04/09/07 17:48, Ron Natalie wrote:
Mxsmanic wrote: Which types of pumps are used in most modern small aircraft? Dry engine-driven pumps followed by wet engine-driven pumps. Electric pumps and direct electric driven come last. There's also the manifold-powered suction backup unit (Precise Flight). How many small aircraft have redundant pumps and gyros? There are a lot with the backup systems either manifold or electric. As for dual gyros, air-driven gyros rarely fail. Are any small aircraft using RLGs? I don't know of any certificated ones suitable for light aircraft. How hard is it to spot a pump failure? I've gotten the impression from what I've read here and elsewhere that vacuum pumps may fail gradually and insidiously, whereas (presumably) an electric motor fails in a much more obvious way. Nope you have the wrong impression. The dry pump fails instantly. A flag, light, or well place gauge will tell you instantly. The issue is that if it fails and you don't notice the lack of vacuum, it takes a few minutes as the gyro slowly spins down and becomes unstable to notice. Does a failure involve the gyro coming to a stop, or can it just slow down and thereby cause problems? Precisely. But how does that help you if the AI has failed? The GPS wouldn't tell you the attitude of your aircraft. The altimeter/vsi tells me if I am climbing or descending. and the airspeed indicator... The altimeter tells you where you are; the VSI and ASI tell you where you are going. The GPS tells me if I am turning (as does the Turn Cordinator, but the turn coordinator is a bit more finicky, Finicky? It's very accurate, if that's what you mean. It's provides an easy way to determine if your wings are level (assuming coordinated flight) among other things. I think it's a wonderful back-up for an inop DG. and turns are more difficult because you can't really count on the whisky compass while turning, Really? I can. I can turn to a heading using the wet compass. You just have to know how to use it. you do timed turns, but with the GPS you just watch it's simulation of the HSI). Instrument pilots do a decent amount of practice with the gyros simulated failed. Well, instrument pilots are required to show proficiency. Some practice more than that though... -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
Wet vs Dry Vacuum Pump | Fastglasair | Owning | 7 | December 17th 04 11:46 PM |
Wet Vacuum Pump | smackey | Owning | 6 | February 24th 04 07:03 PM |
Reverse Vacuum Damging to Instruments? | O. Sami Saydjari | Owning | 8 | February 16th 04 04:00 AM |
