Don: Be sure to share what you find. I think that I'm only scratching the
surface of some stuff. One thing I found and had never seen before was an equation relating the increase in stress due to a crack. It scares the hell out of me. I'm afraid to use a metal fork in my salad. The equation basically says that the max stress is 2 times the load divided by the area times the square root of the crack length divided by the radius of curvature of the end of the crack!!! If the radius of curvature was equal to the crack length, the max stress is already twice what you would calculate using the applied load and the element cross section. Now put a reasonably sharp crack and see what happens....as the radius approaches 0.001 times the length of the crack......???? "Don W" wrote in message et... Stuart Fields wrote: Don: I've got numerous phone calls to anodizing firms who have confirmed the decrease in fatigue life due to anodizing. I've got a photo of a fatigue failed anodized control tube, none of the non anodized control tubes in any of the other similar helicopters even those with more hours have failed. Further if you consult the excellent text: titled Fatigue Design of Aluminum Components & Structures, Sharp, Nordmark and Menzemer, a chart, page 110, shows decrease in fatigue life due to pre-cleaning as well as the affects of Alodine and a couple of different thicknesses of anodic coatings. Further: In a report authored by Thart, WGJ and Nederveen, the following was stated: "Constant amplitude fatigue tests on anodized unnotched specimens reveal that sulfuric acid and sealed chromic acid anodic layers cause the largest decrease in fatigue strength. Phosphoric and unsealed chromic acid anodic layers do not significantly affect fatigue life. Scanning electron microscopy of fracture surfaces confirms that fatigue cracks initiate at cracks in the anodic layer". Mo Shiozawa, Kazuaki; Kobayashi, Hirokazu; Terada, Masao; Matsui, Akira. Japan Society of Mechanical Engineers, Transactions A. Vol. 66, no. 652, pp. 74-79. Dec. 2000 "The anodized film is fractured at an early stage of the repeated tensile fatigue process, because it is too brittle to accommodate the substrate metal." Mo A P.E associated with the anodizing community said it even stronger. "Never anodize flight critical components" Van's of Van's RV aircraft and the subject was anodizing spars, said that anodizing has been known to reduce fatigue life as much as 50%. Boeing Aircraft has a special process whereby the ameliorate the effects of anodizing on some parts. I had a 36' McGregor catamaran with an anodized mast that I sailed in the open ocean in the South Pacific. Even with the cracks in the anodized layer, the frequency of vibration in the mast was much lower than the 17hz associated with the helicopter. Looking back I would expect the mast on the sail boat to have a much longer life than helicopter parts. More data. The failed control tube was inspected by a laboratory in Canada and they proved that there was no existing flaw prior to the anodizing. The crack started after the anodizing and the control tube with a small load applied, but subject to the vibrations produced by a helicopter, failed in fatigue with very few hours. Experience can be misleading. I've been in the amateur helicopte game since 97 and I'm a retired engineer but I had never heard that the fatigue life of anodized parts could be reduced as much as 50%. Stuart, Very interesting! A lot of things that you run into in engineering are counter-intuitive, and this is apparently one of them. I had not heard of this phenomenon before now. I'll certainly look into this some more when I get some time. Don W. |
![]() Stuart & Kathryn Fields wrote: Don: Be sure to share what you find. I think that I'm only scratching the surface of some stuff. One thing I found and had never seen before was an equation relating the increase in stress due to a crack. It scares the hell out of me. I'm afraid to use a metal fork in my salad. The equation basically says that the max stress is 2 times the load divided by the area times the square root of the crack length divided by the radius of curvature of the end of the crack!!! If the radius of curvature was equal to the crack length, the max stress is already twice what you would calculate using the applied load and the element cross section. Now put a reasonably sharp crack and see what happens....as the radius approaches 0.001 times the length of the crack......???? That is because the load is not equally spread across the part, but is concentrated at the end of the crack. Think about a piece of metal bar in tension with a crack halfway across it. The cross sectional area that has already seperated cannot bear any load at all as it has already failed. The end of the crack is taking a lot of load because the crack pulls apart when it is under tension. Solution: Don't use cracked parts!! (Well duh) Don W. |
Don: Reading in a text book on Fatigue design for aluminum structures,
there is at least one design technique that assumes that there are cracks inherent in the material to start with that are not readily detectable by a visual inspection. The design philosophy progresses from there. This whole area of study is explaining why the time life specs on parts can be very meaningful. It also can allude to the excessive safety factors that can be used in determining time life specs. It looks like I've got a lot more studying to do in this area. -- Stuart Fields Experimental Helo magazine P. O. Box 1585 Inyokern, CA 93527 (760) 377-4478 ph (760) 408-9747 publication cell "Don W" wrote in message ... Stuart & Kathryn Fields wrote: Don: Be sure to share what you find. I think that I'm only scratching the surface of some stuff. One thing I found and had never seen before was an equation relating the increase in stress due to a crack. It scares the hell out of me. I'm afraid to use a metal fork in my salad. The equation basically says that the max stress is 2 times the load divided by the area times the square root of the crack length divided by the radius of curvature of the end of the crack!!! If the radius of curvature was equal to the crack length, the max stress is already twice what you would calculate using the applied load and the element cross section. Now put a reasonably sharp crack and see what happens....as the radius approaches 0.001 times the length of the crack......???? That is because the load is not equally spread across the part, but is concentrated at the end of the crack. Think about a piece of metal bar in tension with a crack halfway across it. The cross sectional area that has already seperated cannot bear any load at all as it has already failed. The end of the crack is taking a lot of load because the crack pulls apart when it is under tension. Solution: Don't use cracked parts!! (Well duh) Don W. |
Don: Reading in a text book on Fatigue design for aluminum structures, there is at least one design technique that assumes that there are cracks inherent in the material to start with that are not readily detectable by a visual inspection. The design philosophy progresses from there. This whole area of study is explaining why the time life specs on parts can be very meaningful. It also can allude to the excessive safety factors that can be used in determining time life specs. It looks like I've got a lot more studying to do in this area. Hi Stuart, If you've ever looked at aluminum under a high power microscope you have seen that it is not a smooth material at all, but consists of "grains" of material more or less mashed together. If it is alloyed with copper, you can see the copper grains around the edges of the aluminum grains. Fatigue of material is an interesting subject. Do you remember the problems introduced at the drive shaft on the Rotorway 162F when people started changing out the chain drives for belt drives? The chain drives needed an oil bath which required oil seals, and a housing all the way around the chain. Since the only way to change the bottom seal when it started leaking is to remove the housing, and that requires removing the chain and drive sprockets it seemed that replacing the chain sprockets and chain with a gilmer belt and tensioner was a good idea--at least until the drive shaft from the motor started failing right on the other side of the support bearing. The problem was/is that the drive shaft is supported by only one bearing below the drive pulley, and the gilmer belt must be kept in much more tension than a drive belt. Consequently the end of the drive shaft is bent ever so slightly by the belt tension. This would be okay except that when it rotates, the direction of the bend keeps changing. The effect is like bending a piece of metal back and forth 50 times per second. Even the fairly thick drive shaft failed in a hundred hours or so given that treatment. The failures puzzled everyone at first, and they called it "fretting fatigue"--I guess because the designers were fretting over it ;-) Don W. |
AA Engine failure at LAX... | .Blueskies. | Piloting | 3 | June 13th 06 11:05 PM |
engine failure | swag | Piloting | 16 | June 8th 06 06:13 PM |
Failure #10 | Capt.Doug | Piloting | 7 | April 13th 05 02:49 AM |
Another Bush Failure | WalterM140 | Military Aviation | 8 | July 3rd 04 02:23 AM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
