TBO and airworthiness
Old April 11th 07, 06:16 PM posted to rec.aviation.owning
Newps
Default TBO and airworthiness
Robert M. Gary wrote:
On Apr 10, 9:12 pm, Jim Stewart wrote:
Does an engine past TBO make an aircraft
non-airworthy? I can't seem to find a
straight answer on the web.
Assuming you can find an IA willing to sign an annual then no.
Have you found that to be a problem? I haven't. My mechanic flies his
180 on pipeline patrol and is 1000 over TBO on his 470. Another friend
also flies pipeline in his PA12 and went 3600 hours before he topped it
and 7000 hours before he finally majored it, that's a lot of 100 hour
inspections.
Old April 11th 07, 09:06 PM posted to rec.aviation.owning
Robert M. Gary
inspections.
Yes, many IA's I've worked with refuse to sign after 200 over TBO. Its
probably a liability issue.
-robert
Old April 12th 07, 02:48 PM posted to rec.aviation.owning
Matt Barrow[_4_]
"Robert M. Gary" wrote in message
inspections.
Sounds like a competency issue - on what basis did they 'fail" the aircraft?
Old April 12th 07, 03:07 PM posted to rec.aviation.owning
Dave Butler
Its probably a liability issue.
aircraft?
They don't have to fail anything. If it's not returned to service, the
owner is at liberty to find another IA who is willing to return it to
service. An IA is not obligated to explain why he chooses not to return
an aircraft to service.
Old April 12th 07, 02:43 PM posted to rec.aviation.owning
Matt Barrow[_4_]
Pardon?
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Restricted Airworthiness Brad Mallard Aviation Marketplace 1 May 20th 04 05:18 PM
Airworthiness Cert Still Valid? Carl Orton Owning 12 February 13th 04 10:21 PM
Teaching airworthiness Roger Long Piloting 28 October 2nd 03 09:08 PM
Airworthiness certification of an experimental Ace Pilot Home Built 0 July 16th 03 03:26 PM
