In rec.aviation.piloting Mxsmanic wrote:
swag writes: This is actually a maneuver that's demonstrated and practiced very early in flight training, so I'm sure all pilots and student pilots have experienced this. But your calculations are fairly correnct--a 2 minute turn won't cut it. It's usually demonstrated with a 60 degree bank turn. I'm not sure of the timing, but i'd guess 30 sec or less. Don't you have to descend to catch the wake? Downwash should be moving downward at a few knots and IIRC the vortices do as well, so after two minutes at, say, 12 knots, the turbulence would be almost 2500 feet below you, if you are staying at altitude. I don't see how you could run into it. Real people in real airplanes training to become real pilots do real 45 degree bank, constant altitude turns on a regular basis and run into their real wake. It is just another thing you don't understand because you have no context. -- Jim Pennino Remove .spam.sux to reply. |
writes: Real people in real airplanes training to become real pilots do real 45 degree bank, constant altitude turns on a regular basis and run into their real wake. My research indicates that this is not possible. Your research at what, at your desk in front of Microsoft Flight Simulator? In my experience as a real pilot of real airplanes, it has happened. In the experience of many real pilots of real airplanes, it has happened. The altitude tolerance on a 360 degree turn is +/- 100 feet from start to finish. Once again, you have no context for understanding. snip ignorant nonsense -- Jim Pennino Remove .spam.sux to reply. |
writes: Your research at what, at your desk in front of Microsoft Flight Simulator? No, my survey of the literature. What does your "literature" say about the wake turbulance to be found from a Cessna 172? How about a '47 Ercoupe? In my experience as a real pilot of real airplanes, it has happened. In the experience of many real pilots of real airplanes, it has happened. In the course of my research, it appears to be impossible. The sources I consulted seemed more reliable than a name on a screen. I, and many, many other pilots have experienced it. Yet another difference between simulated and real flight. The altitude tolerance on a 360 degree turn is +/- 100 feet from start to finish. If you are not descending at the same speed as your wake, I don't see how you can run back into it. Because you have no context with which to even begin to understand it. All your protestations do is show how unrealistic your flight simulator and "experience" gained through playing flight simulator is. -- Jim Pennino Remove .spam.sux to reply. |
On Apr 15, 6:25 am, wrote:
In rec.aviation.piloting Mxsmanic wrote: writes: Your research at what, at your desk in front of Microsoft Flight Simulator? No, my survey of the literature. What does your "literature" say about the wake turbulance to be found from a Cessna 172? How about a '47 Ercoupe? In my experience as a real pilot of real airplanes, it has happened. In the experience of many real pilots of real airplanes, it has happened. In the course of my research, it appears to be impossible. The sources I consulted seemed more reliable than a name on a screen. I, and many, many other pilots have experienced it. Yet another difference between simulated and real flight. The altitude tolerance on a 360 degree turn is +/- 100 feet from start to finish. If you are not descending at the same speed as your wake, I don't see how you can run back into it. Because you have no context with which to even begin to understand it. All your protestations do is show how unrealistic your flight simulator and "experience" gained through playing flight simulator is. I always maintained altitude and rate of turn in steep turns with the end result being hitting my own slipstream. Its time mixup got into an aeroplane |
george wrote:
I always maintained altitude and rate of turn in steep turns with the end result being hitting my own slipstream. Its time mixup got into an aeroplane Who'd cleanup the vomit and brown runny stuff??? d:-)) |
On Apr 14, 4:27 pm, "george" wrote:
I always maintained altitude and rate of turn in steep turns with the end result being hitting my own slipstream. As have we all on nice days, and students like to brag about it. Yet Mx is correct, in theory we should not be able to do this. I seem to recall recent magazine (web?) articles where the idea that you can hit your own wake while actually holding altitude, should be downplayed nowadays. You _have_ to descend a little bit to do so, which means that, while you might be within the +/- 100' test scenario, you are NOT holding the same exact altitude. Hmm. Or else it means that the wake doesn't necessarily descend as we're taught. On a warm clear day (which is when I've hit my own wake), I betcha that the wake is being held upward a tiny bit by the heat from the ground. Cheers, Kev |
Mxsmanic,
In the course of my research, it appears to be impossible. The sources I consulted seemed more reliable than a name on a screen. Then what are you doing here? -- Thomas Borchert (EDDH) |
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1 In rec.aviation.piloting Mxsmanic wrote: In my experience as a real pilot of real airplanes, it has happened. In the experience of many real pilots of real airplanes, it has happened. In the course of my research, it appears to be impossible. The sources I consulted seemed more reliable than a name on a screen. Pathetic, to say the least. If you're doing such research, why don't you play devil's advocate to make sure that your 'research' is right, and compare the 'names on a screen' to what is listed in the person's profile for their log, hours flown, experience, how long they've had their tickets, etc. However, since that is also just a 'name on a screen', with your M.O. it is safe to assume you wouldn't count that as reliable either. In the end, all your research is put up by a 'name on a screen'; therefore, you can't trust that to be any more reliable than the people here. Your research, and your logic behind doing such research, is flawed. BL. - -- Brad Littlejohn | Email: Unix Systems Administrator, | Web + NewsMaster, BOFH.. Smeghead! ![]() PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF -----BEGIN PGP SIGNATURE----- Version: GnuPG v1.4.7 (GNU/Linux) iD8DBQFGIVqeyBkZmuMZ8L8RAsreAKCkJx7tKi5SnRoW2LlImx 1gBS89uwCghRK1 Ee30ex9bpkmRixhZD+RV4Hk= =nM57 -----END PGP SIGNATURE----- |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
