Mxsmanic wrote in
: In the course of my research, it appears to be impossible. The sources I consulted seemed more reliable than a name on a screen. If you write the names on the screen down on a piece of paper, the two sources will become equally anonymous, then. |
On Apr 14, 7:16 pm, Mxsmanic wrote:
writes: Real people in real airplanes training to become real pilots do real 45 degree bank, constant altitude turns on a regular basis and run into their real wake. My research indicates that this is not possible. The wake sinks at a rate between 150 and 500 feet per minute (roughly). Thus, it would always be well below the airplane by the time it closes its own circle, unless the airplane is also descending. I've seen reports of pilots descending in a 360-degree turn and running into their own wakes. If they can descend and encounter their own wake, then they cannot remain at the same altitude and encounter it. It cannot be in two places at once. You´re an idiot. Bertie |
mike regish writes:
If the local air mass is rising, it will slow the sink or even raise the vortex. And it will raise the aircraft, too, so the result is the same. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Not if you are maintaining altitude via altimeter.
mike "Mxsmanic" wrote in message ... mike regish writes: If the local air mass is rising, it will slow the sink or even raise the vortex. And it will raise the aircraft, too, so the result is the same. -- Transpose mxsmanic and gmail to reach me by e-mail. |
In rec.aviation.piloting Mxsmanic wrote:
mike regish writes: If the local air mass is rising, it will slow the sink or even raise the vortex. And it will raise the aircraft, too, so the result is the same. Except in a real airplane with a real pilot, the pilot is maintaining altitude +/- 100 feet. -- Jim Pennino Remove .spam.sux to reply. |
Mxsmanic,
My research indicates that this is not possible. Hoho! Well then, I guess us pilots who routinely encounter this, e.g. during something as mundane as a rental checkout, must all be delusional. -- Thomas Borchert (EDDH) |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
