Question to Mxmanic
Old April 14th 07, 06:47 PM posted to rec.aviation.piloting,rec.aviation.student,alt.disasters.aviation
Bertie the Bunyip
Default Question to Mxmanic
On Apr 14, 7:16 pm, Mxsmanic wrote:
writes:
Real people in real airplanes training to become real pilots do real
45 degree bank, constant altitude turns on a regular basis and run into
their real wake.
My research indicates that this is not possible. The wake sinks at a rate
between 150 and 500 feet per minute (roughly). Thus, it would always be well
below the airplane by the time it closes its own circle, unless the airplane
is also descending.
I've seen reports of pilots descending in a 360-degree turn and running into
their own wakes. If they can descend and encounter their own wake, then they
cannot remain at the same altitude and encounter it. It cannot be in two
places at once.
You´re an idiot.
Bertie
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
