The TC responds to bank/roll and to turn rate.
As for the effect of speed on rate of turn, ask the baseball pitcher about whether he would have missed the building had he slowed down and then banked steeply? The rate of turn decreases and the radius increases with increased air speed (TAS) and the radius is 4 times greater if you double the speed, so it is lost cause, unless you have the power of an F16, you can't maintain a turn at an 85° bank in level flight. Typical autopilot systems just do a 25° bank angle and let the rate work itself out. "Roy Smith" wrote in message ... | "Robert Barker" wrote: | | Working on getting my PPL and I'm trying to figure out the difference | between standard rate turns versus constant rate turns and their | relationship to speed. | | IIRC, a standard rate turn is 3 degrees per second and turn you 180 degrees | in 1 minute. The rule of thumb for the bank angle to achieve this is to | divide the airspeed by 10 and add half the resulting answer - i.e., standard | rate at 100kts is about 15 degrees of bank... (So, if that's a standard | rate turn, what's a constant rate one? Something other than 3 degrees a | second?) | | A standard rate turn is a specific KIND of constant rate turn. It's a | constant rate turn whose rate happens to be 3 degrees per second. | | Ask your instructor to show you a chandelle or a lazy eight -- those are | maneuvers from the commercial checkride which are NOT constant rate; the | rate of turn changes throughout the maneuver. Be warned, your instructor | may be hesitant to show you these because the last time he did them is | probably the day he took his commercial checkride and he's forgotten how to | do them :-) | | But there's an indicator of rate of turn on the turn coordinator that | indicates the standard rate turn. The mark doesn't move. The turn | indicator is a gyro instrument just like the attitude indicator which also | indicates bank. Question: How can the TI always hit the same mark for a | standard rate turn independant of airspeed if, in fact, I'm turning at | different bank angles as indicated on the AI? | | Because the TC isn't an ATTITUDE gyro, it's a RATE gyro. Actually, a | modern TC is designed to measure a mix of roll (bank) rate and yaw (turn) | rate. There's a lot of clever engineering that went into designing how | these little wonders work. |
Jim,
Typical autopilot systems just do a 25° bank angle and let the rate work itself out. Uhm, with the proliferation of rate-based AP systems (both from S-TEC and King), that statement simply doesn't hold true anymore for GA aircraft. It may have been true way back (can't imagine it, really, though, 25 degrees seems very steep), but it certainly isn't any longer. The S-Tecs (at least the 50) do 90 percent of standard rate, the King KAP 140 is similar. -- Thomas Borchert (EDDH) |
![]() "Thomas Borchert" wrote in message ... Jim, Typical autopilot systems just do a 25° bank angle and let the rate work itself out. Uhm, with the proliferation of rate-based AP systems (both from S-TEC and King), that statement simply doesn't hold true anymore for GA aircraft. It may have been true way back (can't imagine it, really, though, 25 degrees seems very steep), but it certainly isn't any longer. The S-Tecs (at least the 50) do 90 percent of standard rate, the King KAP 140 is similar. -- Thomas Borchert (EDDH) Thanks to everyone who replied! Grabbed some coffee and my calculator this morning and ran thru some numbers... It seems obvios now, but not sure what I was basing my "intuition" on... |
A Q on horizontal turns | Ramapriya | Piloting | 14 | January 7th 05 11:46 PM |
Why is a standard hold right turns? | Roy Smith | Instrument Flight Rules | 51 | August 28th 04 06:09 PM |
Newbie question on Rate of Climb | Wright1902Glider | Home Built | 0 | August 17th 04 03:48 PM |
Standard rate turn in Boeing 757? | Garyurbach | Piloting | 43 | June 17th 04 11:04 PM |
Lapse Rate Question | Waduino | Soaring | 0 | October 1st 03 07:32 PM |
