"Rip" wrote in message
et... Judah, one of his problems is that he fixates on insufficient information, and then gets frustrated when his assumptions are incorrect. Obviously, MX can only concieve of downwash generated by the wings as they create lift. Apparently, he can't concieve of the UPWASH created by the tail surfaces pushing DOWN, nor the potential for interaction between the two, or other turbulence that may be created in the air mass merely because a large object is plowing through it at a high rate of speed. Rip Or that the wake of a Cessna 150 might not sink as fast as the wake of a fully loaded 747... -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
![]() "Capt. Geoffrey Thorpe" The Sea Hawk at wow way d0t com wrote in message news:WvWdnUKzmpUiF7_bnZ2dnUVZ_rOqnZ2d@wideopenwest .com... "Rip" wrote in message et... Judah, one of his problems is that he fixates on insufficient information, and then gets frustrated when his assumptions are incorrect. Obviously, MX can only concieve of downwash generated by the wings as they create lift. Apparently, he can't concieve of the UPWASH created by the tail surfaces pushing DOWN, nor the potential for interaction between the two, or other turbulence that may be created in the air mass merely because a large object is plowing through it at a high rate of speed. Rip Or that the wake of a Cessna 150 might not sink as fast as the wake of a fully loaded 747... -- Or that the tip vortices might be called that for a reason, or the effects that might have, etc. ad infinitum. Peter |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
