Step Down or Track Glide slope on GPS overlay approach
Old April 15th 07, 04:45 PM posted to rec.aviation.ifr
Dave Butler
Default Step Down or Track Glide slope on GPS overlay approach
Mooney wrote:
I think what we are saying is that even though Jeppesen says the VNAV
GS ensures being above the step-down fixes and GARMIN wrote approved
software to make sure the GS needle properly indicates the Jeppesen-
provided vertical guidance, the pilot needs to explicitly note whether
the step-down fixes have been passed and not follow the GS unless it
is consistent with these restrictions. So, it is ok to fly the
glideslope, but you must perform these checks as the approach
progresses.
Seems like a good double check yet lets me keep the stablized
approach. The other issues of MDA vs DA and the possible advantage of
entering VFR earlier if you dive & drive are noted. Thanks to everyone
who responded.
Google for "constant angle non-precision approach" for lots of
discussion about the pros and cons.
Dave
Dual glide slope, $95...priceless! Jack Allison Owning 20 October 22nd 06 03:45 AM
Can a failed Glide Slope also void the Localizer approach? Jim Carter Instrument Flight Rules 17 August 24th 06 09:01 PM
Glide Slope Antenna Ground Plane JKimmel Home Built 6 August 1st 06 01:28 AM
En route glide slope? Andrew Gideon Piloting 17 November 21st 04 05:49 PM
Effect of airbrake blade height on glide slope Mike Soaring 1 January 30th 04 08:24 PM
