Question to Mxmanic
Old April 16th 07, 07:06 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Question to Mxmanic
Rip writes:
Please provide a reliable reference for that staement.
Every reference I can find mentions it.
Old April 16th 07, 07:19 PM posted to rec.aviation.piloting,rec.aviation.student
Rip
Mxsmanic wrote:
Rip writes:
Quote one.
Rip
Old April 17th 07, 04:17 AM posted to rec.aviation.piloting,rec.aviation.student
Tim[_4_]
"Mxsmanic" wrote...
Rip writes:
Interestingly, MSFS will simulate this very effect in a C172 or a Baron in a
level 360 degree turn.
I wonder why the software would imitate something that cannot happen in real
life?
BDS
Old April 17th 07, 05:29 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Tim writes:
Will it? It doesn't simulate wake turbulence generally, why would it simulate
this?
life?
So do I.
Old April 17th 07, 02:30 PM posted to rec.aviation.piloting,rec.aviation.student
Tim[_4_]
"Mxsmanic" wrote...
Tim writes:
in a
simulate
this?
Yes, it will. Try it - if you're good enough you will see it happen. If
not, you have to practice your 360s.
real
life?
So do I.
An interesting dilemma - either MSFS is bogus or Mx is wrong... has hell
frozen over?
BDS
Old April 17th 07, 04:10 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Tim writes:
frozen over?
Many of the MSFS developers are pilots, for better or for worse.
Old April 17th 07, 06:46 PM posted to rec.aviation.piloting,rec.aviation.student
swag
On Apr 17, 9:10 am, Mxsmanic wrote:
Tim writes:
frozen over?
I believe that the explanation to why all pilots have experienced this
is that the vortices of a tight turn descend much more slowly than the
vortices generated in straight flight. All of the experimental data
that I can find on vortex descent rate has been done on planes in
straight flight (or in wind tunnels which is the same thing). All of
the reasons espoused in this thread for vortices to have any downward
velocity can be used to explain why numbers should change when the
wings aren't level.
The other factor that has been ignored is how fast a steep turn
executes. A 2g coordinated turn at 100 knots will complete in 19
seconds. (That's close to a 45 degree bank angle in most small
planes.) The formula to play with different loading factors and
speeds is:
rate of turn= omega = g*sqrt(n^2-1)/V
Old April 17th 07, 07:40 PM posted to rec.aviation.piloting,rec.aviation.student
Judah
Mxsmanic wrote in
Name 3
Old April 17th 07, 07:48 PM posted to rec.aviation.piloting,rec.aviation.student
Mark Hansen
On 04/17/07 11:40, Judah wrote:
Mxsmanic wrote in
Name 3
It's funny. Anthony's always said that real pilots don't know what they
are talking about, yet he seems to feel the ones that worked on the MSFS
game do.
Old April 17th 07, 11:18 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Tim writes:
It doesn't happen. I did try it, in perfect weather, at 2500' MSL over
Southwest Oregon Regional Airport, using the autopilot to make a perfect turn
with a constant altitude. No bump.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
