In rec.aviation.piloting Mxsmanic wrote:
Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. Why would anyone need an autopilot to do a 360 in CAVU? You mean your chair didn't bump? What a surprise. -- Jim Pennino Remove .spam.sux to reply. |
![]() "Mxsmanic" wrote... Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. Then you did something wrong because it definitely does happen. BDS |
Tim wrote:
"Mxsmanic" wrote... Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. Then you did something wrong because it definitely does happen. BDS Tim, get with the program, man. Mxsmanic has never flown anything other than Microsoft Flight Simulator. Seriously. Rip |
On Apr 17, 5:18 pm, Mxsmanic wrote:
Tim writes: Yes, it will. Try it - if you're good enough you will see it happen. If not, you have to practice your 360s. It doesn't happen. I did try it, in perfect weather, at 2500' MSL over Southwest Oregon Regional Airport, using the autopilot to make a perfect turn with a constant altitude. No bump. -- Transpose mxsmanic and gmail to reach me by e-mail. Can you set an autopilot to do a 60 degree bank angle turn? Mine won't do that. |
swag writes:
Can you set an autopilot to do a 60 degree bank angle turn? Mine won't do that. It depends on the autopilot. On large aircraft you can, although they usually won't go to 60 degrees. -- Transpose mxsmanic and gmail to reach me by e-mail. |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
