Tom L. writes:
It doesn't have to continue to sink forever. It can stabilize its position at some point. It will sink indefinitely unless some other force acts to stop it. In theory, it will sink until it reaches the ground. In other words, in theory, an aircraft lays down a swath of downwash from the time it leaves ground effect on the runway until the time it lands in ground effect again. The entire swatch theoretically touches down on the ground eventually. E.g. if the vertex radius is 15 feet and sink rate 20 fpm, we hit the wake after a 30 second turn. Twenty feet per minute is too slow. The downwash will move at at least a few knots, and even three knots is 300 fpm. -- Transpose mxsmanic and gmail to reach me by e-mail. |
In rec.aviation.piloting Mxsmanic wrote:
Tom L. writes: It doesn't have to continue to sink forever. It can stabilize its position at some point. It will sink indefinitely unless some other force acts to stop it. In theory, it will sink until it reaches the ground. Do you get your physics from Microsoft Physics Simulator. snip remaining babble -- Jim Pennino Remove .spam.sux to reply. |
On Tue, 17 Apr 2007 00:19:02 +0200, Mxsmanic
wrote: Tom L. writes: It doesn't have to continue to sink forever. It can stabilize its position at some point. It will sink indefinitely unless some other force acts to stop it. In theory, it will sink until it reaches the ground. This is not happening in vacuum, the force that acts to stop it is encountered as soon as the disturbance is created. The questions is how long does it take for that force to stop disturbed air. That would be related to how much energy is in the vortices (in their rotation). Smaller aircraft probably creates vortices with less energy. E.g. if the vertex radius is 15 feet and sink rate 20 fpm, we hit the wake after a 30 second turn. Twenty feet per minute is too slow. The downwash will move at at least a few knots, and even three knots is 300 fpm. I've seen numbers from flight tests indicating several hundreds feet per minute for big aircraft, but I've never seen any numbers for small aircraft nor I've ever seen a theory that could explain or calculate everything measured in the flight tests. Can you point to such test results or a complete theory? It seems that you have access to at least one of them. Thx - Tom |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
