Question to Mxmanic
Old April 17th 07, 09:10 AM posted to rec.aviation.piloting,rec.aviation.student
Default Question to Mxmanic
On Apr 16, 11:33 pm, Mxsmanic wrote:
Virtually no compression occurs at the speeds of a Cessna. Compression is
only an issue at high speeds. At low speeds, air behaves very much like an
imcompressible fluid.
Air does not behave very much like an imcompressible fluid at low air
speeds. Not even close.
Under some conditions, low air speeds is one of them, air can be
treated like it is an imcompressible fluid.
And that is only to simplify airflow calculations.
-Kees.
Old April 17th 07, 07:17 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Wrong again! Water is respirable at ambient pressures sufficiently high
to provide sufficient PO2 (that's partial pressure of oxygen, my boy).
Unfortunately, the problem is carbon dioxide solubility, which makes
water unusable. However, liquid respiration IS successfully done with
various fluorocarbon compounds.
Come now, Anthony. Try to get at least one fact straight.
Rip
Mxsmanic wrote:
writes:
And no, it is not possible to breathe water, you can only breathe
gases, if you want to be pendantically, semantically correct.
Water is breathable if there is enough oxygen in it, although the effect on
lung tissue over long periods of breathing a liquid has not been determined.
There are some therapeutic uses for techniques similar to this.
Old April 18th 07, 11:15 AM posted to rec.aviation.piloting,rec.aviation.student
mike regish
Actually, there is a liquid formula that deep sea divers can breathe.
Flourine something or other.
But you can breathe water, too. You only get to inhale once, though.
mike
Jim Pennino
Remove .spam.sux to reply.
Old April 17th 07, 05:52 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
And it's darned difficult, just like the man said.
Hey, here's an idea, why don't you go get us some empirical data from
personal experimentation, and then get back to us with some actual
information!
Rip
Mxsmanic wrote:
writes:
If air truely behaved like an incompressilble fluid at low air speeds,
it would be difficult, if not impossible, to breathe while jogging.
It's possible to breathe water, which is indeed incompressible for all
practical purposes.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
