Question to Mxmanic
Old April 17th 07, 07:17 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Default Question to Mxmanic
Wrong again! Water is respirable at ambient pressures sufficiently high
to provide sufficient PO2 (that's partial pressure of oxygen, my boy).
Unfortunately, the problem is carbon dioxide solubility, which makes
water unusable. However, liquid respiration IS successfully done with
various fluorocarbon compounds.
Come now, Anthony. Try to get at least one fact straight.
Rip
Mxsmanic wrote:
writes:
And no, it is not possible to breathe water, you can only breathe
gases, if you want to be pendantically, semantically correct.
Water is breathable if there is enough oxygen in it, although the effect on
lung tissue over long periods of breathing a liquid has not been determined.
There are some therapeutic uses for techniques similar to this.
Old April 18th 07, 11:15 AM posted to rec.aviation.piloting,rec.aviation.student
mike regish
Actually, there is a liquid formula that deep sea divers can breathe.
Flourine something or other.
But you can breathe water, too. You only get to inhale once, though.
mike
Jim Pennino
Remove .spam.sux to reply.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
