Question to Mxmanic
Old April 17th 07, 05:47 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Default Question to Mxmanic
Anthony, you've got the issue of compressibility precisely backwards. No
surprise.
Rip
Mxsmanic wrote:
Rip writes:
I don't know, but I'm going to find out! I can envision an aircraft with
light wing loading, like a Cessna for instance, compressing the air
locally as it creates lift. After passage of the wing, the lift created
downwash would rebound upward, kind of like skipping a stone on the
water.
Virtually no compression occurs at the speeds of a Cessna. Compression is
only an issue at high speeds. At low speeds, air behaves very much like an
imcompressible fluid.
The end result is that the downwash stays at a constant altitude,
or sinks MUCH more slowly than theory would indicate.
The downwash does not stay at a constant altitude. It sinks. It has to,
otherwise the aircraft couldn't stay in the air.
Old April 18th 07, 11:16 AM posted to rec.aviation.piloting,rec.aviation.student
mike regish
Actually, he doesn't.
mike
"rq3" wrote in message
. net...
surprise.
Rip
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
