Question to Mxmanic
Old April 17th 07, 05:55 PM posted to rec.aviation.piloting,rec.aviation.student
Default Question to Mxmanic
In rec.aviation.piloting Mxsmanic wrote:
writes:
Air does not behave very much like an imcompressible fluid at low air
speeds. Not even close.
That's not what the engineers say.
I am an engineer and have the degree to prove it and I totally agree
with him, so stuff it.
Under some conditions, low air speeds is one of them, air can be
treated like it is an imcompressible fluid.
The difference between TAS and EAS is only about 13% even at Mach 1. Since
small aircraft come nowhere near to Mach 1, for all practical purposes air is
incompressible for most calculations.
Word salad that shows you don't get the concept.
At low airspeed, the equations for incompressible fluid flow are close
enough to what actually happens that they can be used for practical
calculations.
This does not mean that air "acts like an incompressible fluid" in any
way, shape, or form.
Obviously air, being a gas, can be compressed, but taking that into account at
low speeds greatly complicates the calculations, and the final result isn't
significantly different.
Finally, the light comes on...
Well, gee-whiz, you backed into a place where you are finally correct.
Aren't you great?
Jim Pennino
Remove .spam.sux to reply.
Old April 17th 07, 07:19 PM posted to rec.aviation.piloting,rec.aviation.student
rq3
Wrong again, Anthony! There is no King of England.
Rip
Mxsmanic wrote:
writes:
I'm actually the King of England.
The light was always on, but it's hard to see through heavily tinted glasses.
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
