![]() "Maxwell" wrote in message ... "Mxsmanic" wrote in message ... The entire air mass behind the aircraft is descending. The downwash descends, and air from above moves down to replace it. While parasitic drag is not associated with lift and thus has no vertical component of its own, any turbulence it creates will still drift downward with the downwash, although perhaps less quickly than the downwash itself, depending on where the turbulence leaves the aircraft. Blazing generalizations,,,,bull****. You can hit your wake at the same altitude, people do it everyday. The answer is simple and right in front of you. You are just too stupid to see it. Thank God a few are still awake here! |
I want to ask you the most important question of your life. The question is: Are you saved? It is no | gasman | Soaring | 0 | August 26th 05 06:39 PM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Question about Question 4488 | [email protected] | Instrument Flight Rules | 3 | October 27th 03 01:26 AM |
