Question to Mxmanic
Old April 18th 07, 05:51 AM posted to rec.aviation.piloting,rec.aviation.student
swag
Default Question to Mxmanic
On Apr 17, 5:18 pm, Mxsmanic wrote:
Tim writes:
Yes, it will. Try it - if you're good enough you will see it happen. If
not, you have to practice your 360s.
It doesn't happen. I did try it, in perfect weather, at 2500' MSL over
Southwest Oregon Regional Airport, using the autopilot to make a perfect turn
with a constant altitude. No bump.
Can you set an autopilot to do a 60 degree bank angle turn? Mine
won't do that.
Old April 18th 07, 06:39 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
swag writes:
won't do that.
It depends on the autopilot. On large aircraft you can, although they usually
won't go to 60 degrees.
Old April 18th 07, 08:28 PM posted to rec.aviation.piloting,rec.aviation.student
swag
On Apr 17, 11:39 pm, Mxsmanic wrote:
swag writes:
won't do that.
so didyou when you did your "test flight?" You won't encounter a bump
from wake turbulence unless you are doing a steep turn ( like 45
degree bank angle which should take 19 seconds to go 360)
Old April 18th 07, 09:45 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
swag writes:
In the sim? No, there was no bump.
You won't encounter a bump from wake turbulence unless you are
doing a steep turn ( like 45 degree bank angle which should
Why would the steepness of a turn matter?
A 2-G turn is rather close to the load limits for many types of aircraft.
Old April 18th 07, 09:59 PM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
"Mxsmanic" wrote in message
swag writes:
What a dumb ****! Are you kidding???
If someone rolled your brain up in to a ball, and rolled it down a razor
blade -
it would look like a B-B rolling down a four lane highway.
Old April 19th 07, 03:13 AM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Maxwell writes:
No.
Old April 19th 07, 03:15 AM posted to rec.aviation.piloting,rec.aviation.student
Maxwell
Maxwell writes:
Well you should have been. Do a little research.
Old April 20th 07, 04:56 PM posted to rec.aviation.piloting,rec.aviation.student
swag
On Apr 18, 2:45 pm, Mxsmanic wrote:
swag writes:
The steepness matters for two reasons
1. the time of the turn matters to whether the wake turbulance is
dissipating
2. the bank angle changes the rate of descent of the wake
So if you are doing a standard rate turn that takes two minutes, you
will not hit youur wake. But if you do a 2g turn (around 45 degrees)
it should take 19 seconds and you will hit your wake.
3. a 2 g turn should not be close to the load limits of any airplane
certificated in the standard (let alone the utility) category. My
airplane ( a P337) is certificated as standard, not utility. the load
limits ar +3.8 flaps up. And is approved for turns up to 60 degrees.
Old April 20th 07, 05:16 PM posted to rec.aviation.piloting,rec.aviation.student
mike regish
A 60 degree bank produces 2 G's. A 45 degree bank produces 1.414 G's.
mike
"swag" wrote in message
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
