City controlled airspace?
Old April 19th 07, 03:27 PM posted to rec.aviation.piloting
Jose
Default City controlled airspace?
In much the same way that flying VFR over a layer of clouds is VFR on top,
no matter how much the pack howls.
"Over the top", your (IFR) clearance is over.
"On top", your clearance is on.
Jose
Get high on gasoline: fly an airplane.
Old April 19th 07, 03:41 PM posted to rec.aviation.piloting
Steve Foley
"Jose" wrote in message
et...
top, no matter how much the pack howls.
Jose
Thank you. That is exactly my point.
Old April 19th 07, 04:09 PM posted to rec.aviation.piloting
Jose
Well, it's not quite the same. In one case people believe there's a
difference, but just don't remember which is which. In the other case,
people don't realize there's a difference in the first place.
Jose
Old April 19th 07, 09:36 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Steve Foley" wrote in message
From the Pilot/Controller Glossary:
VFR-ON-TOP - ATC authorization for an IFR aircraft to operate in VFR
conditions at any appropriate VFR altitude (as specified in 14 CFR and as
restricted by ATC). A pilot receiving this authorization must comply with
the VFR visibility, distance from cloud criteria, and the minimum IFR
altitudes specified in 14 CFR Part 91. The use of this term does not relieve
controllers of their responsibility to separate aircraft in Class B and
Class C airspace or TRSAs as required by FAAO 7110.65.
From FAR Part 1:
1.1 General definitions.
IFR over-the-top, with respect to the operation of aircraft, means the
operation of an aircraft over-the-top on an IFR flight plan when cleared by
air traffic control to maintain "VFR conditions" or "VFR conditions on top".
VFR over-the-top, with respect to the operation of aircraft, means the
operation of an aircraft over-the-top under VFR when it is not being
operated on an IFR flight plan.
Old April 23rd 07, 04:21 PM posted to rec.aviation.piloting
Steve Foley
link.net...
top,
The FAA defines the piece of paper in my pocket as a certificate.
The FAA defines flight over a layer by a VFR Aircraft as VFR-OVER-THE-TOP.
The FAA does not define flight over a layer by a VFR aircraft as VFR-ON-TOP
The FAA does not define the piece of paper in my pocket at a license.
Old April 27th 07, 07:00 PM posted to rec.aviation.piloting
Steven P. McNicoll
The airman certificate in your pocket is by definition a license.
VFR-ON-TOP
Now you're catching on.
Correct, but some people conclude that because pilots' licenses issued in
the US are called "airman certificates" they are not licenses. In much the
same way some states call drivers licenses "operators permits", but they are
no less a license.
Old April 27th 07, 08:05 PM posted to rec.aviation.piloting
Steve Foley
nk.net...
Where is that definition written?
My point here is that if the city is going to write laws, they should use
proper terminology. I once saw a real estate development delayed because one
town required the developer to obtain a certificate of compliance for a
traffic study from an adjacent town. The problem is that the adjacent town
doesn't issue certificates of compliance for traffic studies. By the time
the developer came back to the town with the requirement, there was enough
turnover in the planning board that his development wouldn't be approved by
the present board. They refused to remove the requirement, and refused to
approve a new plan. He ended up going to superior court to have the
requirement removed. The whole thing was political, but I could picture
something similar happening when the anti-airport activists get the local
police caught up in their fight. The neighbors call the cops claiming the
airplanes are being operated by people without 'licenses'.
The cop asks for your license, and you produce your certificate. The
neighbor tells the cop "That's not a license, it's a certificate'". What
does the cop do?
I agree with you that it is a de facto license, however it is not a de jure
license.
Old April 19th 07, 01:41 PM posted to rec.aviation.piloting
Larry Dighera
On Wed, 18 Apr 2007 14:08:18 -0700, C J Campbell
wrote in
200704181408187826-christophercampbell@hotmailcom:
Now that the government issues the certificate and reserves the right
to take it away, it represents a license. It is the same thing, no
The government doesn't licence Constitutional rights.
The FAA certifies that the airmans certificate holder has met
proficiency and knowledge standards.
Wichita Airspace Question and overlapping airspace Owen[_4_] Piloting 1 February 14th 07 09:35 PM
Controlled flight into glass John Piloting 39 January 14th 07 06:17 PM
4CH Radio Controlled RC Helicopter - $83 NYPT Man Rotorcraft 0 July 31st 05 04:22 PM
Two airspace classes for one airspace? (KOQU) John R Piloting 8 June 30th 04 04:46 AM
REMOTE CONTROLLED AIRCRAFT RCPLANE General Aviation 0 December 18th 03 06:39 PM
