Although I have relatively little experience in this aircraft, the silver metal pump handle pumps the flaps down when the flap "lever" is in the down position, and the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) The flap "lever" is beside or immediately above the pump handle - I don't remember for sure.
I never saw anything labeled "Positive Control" on the bird I flew. -- Jim Carter Rogers, Arkansas "Greg Esres" wrote in message ups.com... On the hydraulic flaps, does the position of the silver pump handle have any bearing on whether or not the hydraulic pressure leaks out of the flap, once they are extended? (The POH doesn't say that it does.) There is some mechanism underneath the instrument panel that has some adjustment for the Positive Control. What does it do, exactly? |
pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. Thanks |
On 18 Apr 2007 20:27:36 -0700, Greg Esres
wrote: the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. brushed-aluminum pushbuttojn on left horn of yoke? extra knob on turn-and-sllip? Don |
Don Tuite wrote:
brushed-aluminum pushbuttojn on left horn of yoke? Yes extra knob on turn-and-sllip? Hmmm, I don't think so. There is such a knob on the yoke itself that is aileron trim. I don't think the system uses the panel turn & slip; it has its own internal equivalent of a turn coordinator, according to the documentation I've seen. |
On 19 Apr 2007 09:22:44 -0700, Greg Esres
wrote: Don Tuite wrote: brushed-aluminum pushbuttojn on left horn of yoke? Yes extra knob on turn-and-sllip? Hmmm, I don't think so. There is such a knob on the yoke itself that is aileron trim. I don't think the system uses the panel turn & slip; it has its own internal equivalent of a turn coordinator, according to the documentation I've seen. OK My recollections are nearly 40 years old. Don |
On Apr 18, 8:27 pm, Greg Esres wrote:
the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. Thanks I'd instruction in a lot of Mooneys but I've not seen any that didn't have at least the vac wing leveler autopilot. All the way back in the early days of the C they had the wing leveler, and later offered an upgrade to the electric Pathfinder system. The PC system had a check valve as I recall to prevent leaks in the PC system (which most planes have) from causing vac failures. Up until 1977 Mooneys were certified with full-time autopilots (maybe the only plane so certified). The autopilot was designed to be on all the time unless the pilot actively held down a button to disable it. Turns are made by selecting left/ right on the controller. However, the A/P is easily over powered. -Robert, CFII |
" have) from causing vac failures. Up until 1977 Mooneys were certified with full-time autopilots (maybe the only plane so certified). And they need one. The Mooney has to be the most unresponsive airplane made. It flys like a truck! Karl Bought new 201 in 1977 |
Gosh Karl - I thought the M20 flew pretty nicely when you release the wing leveler. Nothing like a C182 or C206 - hell during the preflight I think we are supposed to check the delivery chute on the tail to make sure it hasn't clogged from the last load of concrete it hauled.
-- Jim Carter Rogers, Arkansas "karl gruber" wrote in message ... " have) from causing vac failures. Up until 1977 Mooneys were certified with full-time autopilots (maybe the only plane so certified). And they need one. The Mooney has to be the most unresponsive airplane made. It flys like a truck! Karl Bought new 201 in 1977 |
karl gruber wrote:
" have) from causing vac failures. Up until 1977 Mooneys were certified with full-time autopilots (maybe the only plane so certified). And they need one. The Mooney has to be the most unresponsive airplane made. It flys like a truck! We like to say they are "stable". ![]() Dave |
Ok - I'll accept the wing leveler (which you overrode with a button on the yoke if you didn't want to fly a Mack Truck). However I've never seen it called Positive Control before - might be a different year model.
-- Jim Carter Rogers, Arkansas "Greg Esres" wrote in message oups.com... the pump handle position didn't matter. (I always unconsciously pulled it back to the top stop whenever I used it however.) That's how I read the POH. However, the flaps seem to creep up sometimes. I never saw anything labeled "Positive Control" on the bird I flew. I thought they all had this? Probably no label....built-in wing leveler. Thanks |
| Thread Tools | |
| Display Modes | |
| FS: 1965 Mooney M20C | Ken Martin | Aviation Marketplace | 0 | August 20th 05 04:09 AM |
| Mooney Down | Teranews | Piloting | 0 | February 17th 05 05:19 PM |
| 64 M20C Turn/Slip replacement | BellSouth.net News | Owning | 3 | September 1st 04 04:07 PM |
| 64 M20c Avionics Cover Sealing? | BellSouth.net News | Owning | 2 | August 23rd 04 04:42 AM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
