Todd,
The work must be done in a FAA certifid glider repair station, like John Murry's or Gehrlein in your neck of the woods. it involves about 20 hours of work + the cost of the kit from Grob. It involves assembling the ship with wax donuts on the old spigots to determine the excess lateral slop that must be removed when the new spigots are installed, then grind and remove the old, then fit the new with factory jig, scarf spar but and lay up 8 layers of 92125 for the replacement spar wrap. I would estimat $1800 to $2400 bucks. JJ |
JJ,
Would Rutan style 7725 be a similar cloth to the 92125 European cloth? Thanks, Brad On Apr 20, 5:20 pm, JJ Sinclair wrote: Todd, The work must be done in a FAA certifid glider repair station, like John Murry's or Gehrlein in your neck of the woods. it involves about 20 hours of work + the cost of the kit from Grob. It involves assembling the ship with wax donuts on the old spigots to determine the excess lateral slop that must be removed when the new spigots are installed, then grind and remove the old, then fit the new with factory jig, scarf spar but and lay up 8 layers of 92125 for the replacement spar wrap. I would estimat $1800 to $2400 bucks. JJ |
On Apr 22, 10:25 am, Brad wrote:
JJ, Would Rutan style 7725 be a similar cloth to the 92125 European cloth? Thanks, Brad Yep, but when working with certified aircraft like the 102, one must use the specified stuff. The kit I got from Grob had per-cut 92125 sections, everything but resin...............BTW, Williams Soaring (Rex) just got 50 gallons of L285 epoxy at half the price that Spruce & Seciality is getting. JJ |
JJ,
Thanks a lot for this information. It was a factory supplied jig that was used for the replacement ? Todd On Apr 20, 8:20 pm, JJ Sinclair wrote: Todd, The work must be done in a FAA certifid glider repair station, like John Murry's or Gehrlein in your neck of the woods. it involves about 20 hours of work + the cost of the kit from Grob. It involves assembling the ship with wax donuts on the old spigots to determine the excess lateral slop that must be removed when the new spigots are installed, then grind and remove the old, then fit the new with factory jig, scarf spar but and lay up 8 layers of 92125 for the replacement spar wrap. I would estimat $1800 to $2400 bucks. JJ |
On Apr 23, 8:46 am, toad wrote:
JJ, Thanks a lot for this information. It was a factory supplied jig that was used for the replacement ? Todd On Apr 20, 8:20 pm, JJ Sinclair wrote: Todd, The work must be done in a FAA certifid glider repair station, like John Murry's or Gehrlein in your neck of the woods. it involves about 20 hours of work + the cost of the kit from Grob. It involves assembling the ship with wax donuts on the old spigots to determine the excess lateral slop that must be removed when the new spigots are installed, then grind and remove the old, then fit the new with factory jig, scarf spar but and lay up 8 layers of 92125 for the replacement spar wrap. I would estimat $1800 to $2400 bucks. JJ Todd, Did you happen to notice the 3/21/05 response date on the Airworthiness Concern Statement? |
![]() Todd, Did you happen to notice the 3/21/05 response date on the Airworthiness Concern Statement? Yes, at least after it was pointed out :-) I think that there might be a typo. The real deadline for comments in May 11th, I think. Todd |
On Apr 23, 10:11 am, toad wrote:
Todd, Did you happen to notice the 3/21/05 response date on the Airworthiness Concern Statement? Yes, at least after it was pointed out :-) I think that there might be a typo. The real deadline for comments in May 11th, I think. Todd Correct, 5/11/2007 is the deadline for comments into the AOPA. Jim |
Grob Twin Astir Tailshaking | Peter | Soaring | 11 | January 14th 07 11:54 PM |
FS: Grob G104 Speed Astir II B | KO | Soaring | 0 | March 30th 06 12:09 AM |
FS - Grob Speed Astir IIB | Fred | Soaring | 3 | February 18th 06 03:22 PM |
FS - Grob Speed Astir IIB | Steve Leonard | Soaring | 0 | February 17th 06 03:42 AM |
Grob Twin Astir 1 Manual / Flughandbuch | Sebastian Schroeter | Soaring | 2 | June 14th 04 11:41 AM |
