Ridge Soaring accident
Old April 21st 07, 07:37 PM posted to rec.aviation.soaring
Eric Greenwell
Default Ridge Soaring accident
Ian Cant wrote:
Could not agree more about the desirability of good
location aids. Although the personal locator beacon
has the disadvantage of needing manual activation [which
in some situations might not be possible] it also has
the advantage that it can be activated in advance -
for instance, when facing a certain landing in dangerous
terrain, it could be activated on final approach, ensuring
a signal is sent out even if the landing is disastrous
and the ELT fails to activate on impact.
All ELT's have a manual activation switch, so they can also be activated
by the pilot in the situation Ian describes. I hadn't thought about
doing this with mine, but it sounds like a good idea. The post-landing
checklist should have "Check ELT" on it, so the pilot would remember to
deactivate after landing if it's not needed.
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old April 22nd 07, 08:36 PM posted to rec.aviation.soaring
danlj
On Apr 21, 1:37 pm, Eric Greenwell wrote:
Ian Cant wrote:
...Although the personal locator beacon
* "Transponders in Sailplanes"http://tinyurl.com/y739x4
* "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org
The ELT normally has a three-position switch if it's switchable: "on"
"arm" and "off" If you turn it "on" it continuously emits a distress
call and beeps loudly. The distress call will activate search and
rescue efforts, beginning with an attempt to discover whether it's a
false alarm (since most ELT activations are inadvertent). While this
act may seem like a safety measure, the side effects may overload the
emergency response system if all us glider pilots start doing this for
every landing. Rather, perhaps it should be routine to turn it "on"
as the initial step in committing to an off-airport landing, turning
it "off" after landing if all is OK.
And Tom Knauf is right, a GPS-equipped 406mHz personal locator beacon
is cheap life insurance, and less than the cost of the parachute to
which it should be attached, which we also hope not to be needing.
Dan Johnson
Old April 23rd 07, 12:36 AM posted to rec.aviation.soaring
Eric Greenwell
danlj wrote:
(some deletions)
Ian Cant wrote:
it also has
Both Ian and I agree with you, as Ian's comment makes clear the manual
activation is for a potentially disastrous landing, not every landing.
Old April 23rd 07, 03:41 PM posted to rec.aviation.soaring
ContestID67
On the survival kit thread can anyone tell me what items that Dale had
in his survival kit? What items did he use and need? What items does
he feel he should have had with him?
http://www.geocities.com/jhderosa/aviation/survival/
- John
A fine ridge day in PA - the Ridge Soaring Irregulars ride again QT Soaring 0 April 6th 06 04:01 PM
Ridge Soaring Gliderport Thomas Knauff Soaring 0 March 23rd 06 05:25 PM
soaring sim with bald eagle ridge terrain? Frank Soaring 12 January 28th 06 08:53 AM
Coal Mining and Ridge Soaring scurry Soaring 4 August 19th 04 06:02 AM
Ridge video? John Shelton Soaring 1 March 17th 04 12:28 AM
