Grob Astir AD spar spigots
Old April 22nd 07, 06:25 PM posted to rec.aviation.soaring
Brad[_2_]
Default Grob Astir AD spar spigots
JJ,
Would Rutan style 7725 be a similar cloth to the 92125 European cloth?
Thanks,
Brad
On Apr 20, 5:20 pm, JJ Sinclair wrote:
Todd,
The work must be done in a FAA certifid glider repair station, like
John Murry's or Gehrlein in your neck of the woods. it involves about
20 hours of work + the cost of the kit from Grob. It involves
assembling the ship with wax donuts on the old spigots to determine
the excess lateral slop that must be removed when the new spigots are
installed, then grind and remove the old, then fit the new with
factory jig, scarf spar but and lay up 8 layers of 92125 for the
replacement spar wrap. I would estimat $1800 to $2400 bucks.
JJ
Old April 22nd 07, 09:25 PM posted to rec.aviation.soaring
JJ Sinclair
On Apr 22, 10:25 am, Brad wrote:
JJ,
Thanks,
Brad
Yep, but when working with certified aircraft like the 102, one must
use the specified stuff. The kit I got from Grob had per-cut 92125
sections, everything but resin...............BTW, Williams Soaring
(Rex) just got 50 gallons of L285 epoxy at half the price that Spruce
& Seciality is getting.
JJ
Grob Twin Astir Tailshaking Peter Soaring 11 January 14th 07 11:54 PM
FS: Grob G104 Speed Astir II B KO Soaring 0 March 30th 06 12:09 AM
FS - Grob Speed Astir IIB Fred Soaring 3 February 18th 06 03:22 PM
FS - Grob Speed Astir IIB Steve Leonard Soaring 0 February 17th 06 03:42 AM
Grob Twin Astir 1 Manual / Flughandbuch Sebastian Schroeter Soaring 2 June 14th 04 11:41 AM
