Standalone Flight Recorders for Club Use
Old April 23rd 07, 07:02 PM posted to rec.aviation.soaring
Mark Hawkins
Default Standalone Flight Recorders for Club Use
John,
I sent an email direct to you but my guess is that it got lost as
spam. Do you have a source for those nify lexan boxes you have for
the EWMR on your webpage? Our club is getting one as well and that
would be a nice thing to have. The surgical tubing idea is VERY good
as well.
Thanks for the info.
-Mark
On Apr 23, 10:51 am, ContestID67 wrote:
We have been flying with the microRecorder for a few flights now and
have these comments;
1) The antenna needs a good clear view of the sky. I put the antenna
under my turtledeck in my fiberglass glider and found that I missed a
few GPS fixes during the flight. Nothing major and wouldn't have
invalidated the flight. No problems when I mounted the antenna to the
canopy. This problem did not occur on the Cambridge-302A version so I
can only imagine that the EW GPS receiver isn't quite as sensitive as
the Cambridge.
2) I was using the defaults for the configuration. After two flights
separated by 20-30 mins I found that there was only one log file
(which contained both flights). I am unsure if this could be a
problem for multiple flights with different pilots. Looking into this
I found that there was a 90 min auto-off timer. I reset this to 10
mins.
Otherwise the unit is working out well.
- John
Amendment 9 to the Technical Specification for IGC Flight Recorders Ian Strachan Soaring 0 July 1st 06 06:50 PM
IGC-approval levels for some types of Flight Recorders Ian Strachan Soaring 42 March 19th 05 05:42 PM
Updates to IGC approval documents for GNSS flight recorders Ian Strachan Soaring 2 September 27th 04 01:32 PM
Commercial - Mounts for GPS Flight Recorders Paul Remde Soaring 0 March 13th 04 02:03 PM
Approved IGC Flight recorders mat Redsell Soaring 2 March 5th 04 03:35 PM
