Graham,
The software on the FAI site is the EW provided EW Windows Uploader. I uninstalled it and installed the version on the EW site that is optimized for use with an USB to serial converter. My 20 April flight file was transferred from my EW to my laptop and a OLC claim was completed using the "Direct Claim (IGC - file)" process. The IGC security record still doesn't match the OLC computed value. So the mystery continues. Thank you for your assistance. Wayne HP-14 "6F" http://www.soaridaho.com/ "Graham Paul" wrote in message ... Hi, The Upload program for transferring files from the EW model 'B' and 'D', is available under software on www.ewavionics.com. Graham der Pilot Network wrote: ---------------------------------------------------------- Newsgroup: rec.aviation.soaring Subject: OLC posting of EW Model D files Author: Wayne Paul Date/Time: 16:40 23 April 2007 ------------------------------------------------------------ "5Z" wrote in message groups.com... On Apr 23, 9:04 am, "Wayne Paul" wrote: In addition to the OLC-2007 failures I have been experience with files transferred to my laptop using SeeYou, I am having the same problem using the IGC approved EW Windows Uploader. Wayne, after downloading your flight, does it pass the VALI-xxx.exe check? If so, then the error is being introduced during the upload to OLC. If not, then there is a problem with downloading from the FR to your computer. The impression I have based on the above comment is that the problem is during transfer from the FR to your computer. If that is indeed the case, then you must fix that problem before submitting to the OLC unless you just want to set a placeholder for the flight prior to the Tuesday deadline. Then the transfer issue must be resolved and finally you can upload the valid file. Tom, Thank you for your suggestion; however, to the best of my knowledge a separate VALI-xxx.exe program no longer exists for the EW Model D. My last attempt was using the EW Windows Uploader found on the FAI site. (http://www.fai.org/gliding/gnss/freeware.asp) This program produces an IGC file which requires the download and conversion of the EW data file. It would be a shame if this manufacture's product skips the validation process. The process runs smoothly without any indication of a problem. Again, thank you for taking the time to assist me. Wayne ------------------------------------------------------------ -- |
![]() Wayne Paul wrote: The IGC security record still doesn't match the OLC computed value. So the mystery continues. OLC does not "compute" anything. It just confirms the G record is correct by using whatever VALI-xxxx program is appropriate for the file uploaded. If, as you say, there is no VALI-xxxx program available for *you* to run against the downloaded file, then OLC does not have one either. The basic process is as follows: 1. IGC file is downloaded from the FR to your computer. 2. You should ensure it is valid and secure (VALI-xxxx) 3. The file is uploaded to OLC 4. OLC uses a VALI-xxxx program to validate the uploaded file If you were to download the IGC file from OLC, it should be *identical* to the one you uploaded. If even one byte is different, then there is a problem with file upload to OLC. So there is no "direct from FR to OLC" method of submission and validation. Even if some software is hiding the process, at least steps 1, 3, and 4 take place. I hope this helps clarify the process so you can better analyze what is happening. -Tom |
Posting Trouble | Cody Dawg | Piloting | 3 | November 29th 06 08:06 PM |
OLC Posting Problem | jcarlyle | Soaring | 4 | September 28th 06 02:45 AM |
and, since I am posting.... | Dave | Piloting | 9 | November 21st 05 01:36 AM |
Ad posting help | Newps | Aviation Marketplace | 0 | August 16th 05 04:07 PM |
Import/export AeroFly Pro models from/to other standard 3d model files such as *.3ds, *.x, *.lwo,... etc | Simulators | 0 | March 27th 05 08:30 AM |
