On 2007-04-24 09:09:14 -0700, Cary said:
The problem, as I understand it, was the battery was dead. According to the POH, the battery is used to start the engine and is used as a backup during flight for all the electronic gear (including the FADEC). Although the investigation is still ongoing and other answers may be forthcoming, when they operated the landing gear they exceded the power available from the alternators and the backup system (the battery) was not available so the FADEC (engine computers) stopped. One of the lessons here is that one should not fly an airplane that relies on electricity if you don't have a battery to run the electricity! Actually, if the battery is dead the alternators will never start working. This is the excitation battery system that failed. Its sole purpose is to supply enough current to excite the alternator when the engine is started. After that it is never used again during the flight. The DA-42 has considerable redundancy. Click on the electrical diagram in the article and you can see the problem immediately. This particular airplane has two alternators *and* a generator. If the alternators do not work (as is probable) then the generator kicks in. The generator, however, is not big enough to operate both landing gear and engine -- a possible design flaw. Also, if you are going to have a generator, why not use it to excite the alternators if the excitation system has failed? Apparently the designers assumed that if the generator is being used that the alternators have failed beyond repair, but here it might have been possible to get the alternators working with a full complement of power. On the other hand, maybe the original problem was the alternators were both dead (doesn't seem likely) and that is why the excitation system was dead. So even current from the generator would not have excited the alternators. -- Waddling Eagle World Famous Flight Instructor |
F6F accident | Larry Cauble | Naval Aviation | 4 | October 14th 05 06:19 PM |
Accident db? | [email protected] | Owning | 3 | July 25th 05 06:22 PM |
C-130 accident | Jay Honeck | Piloting | 28 | January 11th 05 06:52 PM |
MU2 accident | Big John | Piloting | 16 | April 13th 04 03:58 AM |
KC-135 accident | Big John | Piloting | 3 | November 19th 03 04:36 PM |
